Backdrop for photography
Gb64c
Post by Gb64c »
Recently I shot several pictures of an AFV, and most came out very dark and I want to correct this.
I used an automatic digital panaonic that typically takes stunning photos and has done pretty well so far with the AFVs.
My backdrop (3 sides) was a white sheet and I had my Daylight flourecent lamp over it over it for the first time, There was plenty of light.
So, I am wondering if white is was too bright and the appature was reduced due to the white bright.
I noticed several fellows use a light blue and Mike uses a blue and white mix, is that becouse they prefer blue or does it make for a better picture, light wise.
If any one has suggestions on a backdrop or camera settings, let me know.
Thanks and Merry Christmas from the desert kingdom of Bahrain :cheers2:
Greg
gb64c
Fait Accompli
Re: Backdrop for photography
Yep it'll be the white effecting it, I get better when I just photo on my cutting mat
Whizzo
Post by Whizzo »
Always remember that an automatic setting on a camera will make it try to balance the scene to the same as a "gray" card. If the scene is bright (I.e. White) the camera's internal algorithm will adjust it to the darker side to mimic the standard neutral gray making the shot darker. Take it from a Canadian, that's why you over expose outdoor winter shots to prevent the snow from ending up gray rather than white.
Fred
A Canadian living the Texas life :pistols:
1/48 Airfix CT-155 Hawk (Mk115)
1/48 Airfix Sea Harrier FRS.1
CJSomerset
Post by CJSomerset »
yep every one above is correct, if you can select the spot where your camera meters the light ( called spot metering!) you can put it onto the model. This will help but probably won't give a perfect result. You need to put your camera into manual mode and then adjust the exposure to taste.
