Revell 1/72 Junker Ju 88 A-4/D-1, My Wifes 2nd build.
Daishi12
Post by Daishi12 »
Just received this morning my wifes 2nd ever model kit, Revell 1/72 Junkers Ju88 A-4/D-1 from our new friends at http://www.emodels.co.uk
First impression was that delivery was very quick and a lot of communication from Emodels with regard to order status. Kit arrived well packed in a bubble pack envelope with cardboard strengtheners around the kit.
Side artwork :-
Bagged kit :-
W.I.P.
Revell 1/72 P-47M
Daishi12
Re: Revell 1/72 Junker Ju 88 A-4/D-1, My Wifes 2nd build.
Post by Daishi12 »
Bagged Kit :-
Kit laid out on sprue :-
Decal sheet :-
Initial impression of the kit is that it is quite clean with few ejector pin or sink marks. I think that this is one of the older Revell moulds as it actually contains the crew figures :)
W.I.P.
Revell 1/72 P-47M
UKscalemodeller
Post by UKscalemodeller »
Yes this is the older tool. I have both this and the new tool (which is beautiful but more than twice the price in some places).
I plan to do mine as a what-if RAF coastal command aircraft.
I look forward to seeing it done.
Daishi12
Post by Daishi12 »
I'd like to see your Coastal Command variant.
W.I.P.
Revell 1/72 P-47M
Daishi12
Post by Daishi12 »
Quickly started the kit :)
W.I.P.
Revell 1/72 P-47M
UKscalemodeller
It might be a while as I have a beriev Be2, Stug 40 and the Bf109Z on the bench at the moment. Hopefully within the year.
Blimey, she doesn't hang about does she?
Daishi12
Post by Daishi12 »
Nope she doesn't, I'll posting some build pics of an Albatross D Va in a bit, have just finished the wing rigging
W.I.P.
Revell 1/72 P-47M
Daishi12
Post by Daishi12 »
2nd Day of build.
Engines assembled :-
The exhaust manifolds were a bit of a mare to install and needed a few dry runs to get right.
Engines primed (Tamiya fine surface primer)
Engines then base coated with Tamiya Gun Metal with exhaust manifolds painted in a mix of Tamiya silver and hull red.
W.I.P.
Revell 1/72 P-47M
Daishi12
Post by Daishi12 »
Engines now dry brushed with Tamiya silver and exhaust manifolds dry brushed with Revell Panzergrau
and then wing assembly.. taking a break for the night now
W.I.P.
Revell 1/72 P-47M
RED
Post by RED »
cracking along with this build - good stuff
Shaun
spit
109
harricane
superbug
abrams
M41 walker
....... and many more
Daishi12
Post by Daishi12 »
Just a little bit of work tonight on the build,
engine nacelles assembled and interiors painted (Revell gunship grey)
also tail planes glued in position.
We would have done some more work but have just brought home a 9 week old kitten.
W.I.P.
Revell 1/72 P-47M
DC87
Post by DC87 »
Looking good so far.
Daishi12 wrote:We would have done some more work but have just brought home a 9 week old kitten.
Aw that's lovely - make sure to post pics in the pets topic thread.
Dan C
Filling the workbench with:
Sopwith Snipe late post war
WW1 RFC SE5a
WW1-1/32 Snipe
Looking good mate
Daishi12
Post by Daishi12 »
Just got my wife a new modeling knife as well .... a £3 hobbyists craft knife from Maplins, it's very good
W.I.P.
Revell 1/72 P-47M
HobbyModeller
Post by HobbyModeller »
very good build :) word of warning - when I built this kit there was only room for one bomb on each wing because the two pylons were too close together,
Daishi12
Post by Daishi12 »
Thanks for the tip, we have found that the bomb pylon doesn't quite follow the wing profile so there will need to be a bit of filling on the pylon.
W.I.P.
Revell 1/72 P-47M
HighestAce
Post by HighestAce »
Are there any further updates to this build? I also would like to see this model finished. Absolutely no pressure intended
Doug Collins
HighestAce
Doug Collins
HighestAce
HighestAce@hotmail.com
I like it so far!
