1/72 J2M3 Raiden
EasyEight96
Malaysia
1/72 J2M3 Raiden
Post by EasyEight96 »
So this is my entry to the rising sun Gb. I'll be using both kits supplied.
Boxart
Inbox
This my progress so far on the twins
This kit has tones of FLASH!!!
Here is the the cockpit before and after sanding ( left is sanded while right is not sanded yet)
Both cockpit glued up awaiting for some paint
The fuselage has now nasty flash at the side where you place the canopy
This is how it looks like after sanding
I'll post more photos once I get some more progress tomorrow
In -progress
Too many on the bench!!!
Matchbox Kits lover....
Les
Re: 1/72 J2M3 Raiden
Post by Les »
Looks like some work is needed with clean up, but you got it well in hand! The parts seem to have cleaned up nicely. The fuselage on these look fairly detailed and I like the body shape of these planes. I will look forward to your updates to see how they fit together. :)
ToddS
Post by ToddS »
I hate injection marks....... :evil: Nicely fixed... :th:
EasyEight96
Malaysia
Les wrote:Looks like some work is needed with clean up, but you got it well in hand! The parts seem to have cleaned up nicely. The fuselage on these look fairly detailed and I like the body shape of these planes. I will look forward to your updates to see how they fit together. :)
ToddS wrote:I hate injection marks....... :evil: Nicely fixed... :th:
Thanks for the support guys I'll be posting my update tonight so keep an eye ya
In -progress
EasyEight96
Malaysia
Update
Primed up the cockpit parts and the fuselage using Vallejo's black primer and painted it with XF-71. Wings also now glued up with a lot of flash again and glued up the fuel tanks too. I will start doing some detailing tonight
In -progress
EasyEight96
Malaysia
Did some weathering on the cockpit and side walls this morning and now all is glued up and join to the wings
I had to drill a hole on one of the sidewall to fit this in any clue why did this particular aircraft installed this?? :wtf: :wtf:
Twins are now looking more like the raiden now
In -progress
panzerman
Post by panzerman »
Double the fun on this build....2 Raidens....cool.
Are you adding the pilot figures?
Keep up the good work.
Bill.
EasyEight96
Malaysia
panzerman wrote:Double the fun on this build....2 Raidens....cool.
Bill.
Thanks Bill :th: I tried putting in the figures but I cant fit so I left it. So I did the most horror job of all on the raidens the CANOPIES!!!! :eeek:
not only the raised lines on the canopy is gone it had a very bad fitting too. Anyway I did manage to kill them and one canopy took an hour to mask up so total is 2hours :wall: aiyayayieeee
First canopy
Second canopy ( was in progress )
Both canopies glued to the twins after much swearing
Now the two amigos are ready for paint
In -progress
Porta
Post by Porta »
Sometimes model building is a agony. :lol: They start to look good! Are you going to make them very weathered? ( classic look of these Japanese plane's) Good luck and have fun!
Gr Porta
Like Germans said in this branch there will not be wounded, only dead.
On the bench: Ta-152 1/48 HobbyBoss, Hawker Hurricane 1/48 Airfix (old tooling)
EasyEight96
Malaysia
Porta wrote:Sometimes model building is a agony. :lol: They start to look good! Are you going to make them very weathered? ( classic look of these Japanese plane's) Good luck and have fun!
Gr Porta
Thanks. :th: I'm planning to weather them as it's the first I'm doing I'll do it in a smaller amount to avoid disaster
In -progress
EasyEight96
Malaysia
So after a long break I started it back by giving em a coat of silver and I manage to screw up the second one but it's repairable so stay tuned
I'll be applying maskol over the places that always have heavy chipping on it
In -progress
Aliktren
Mauritius
Post by Aliktren »
awesome, excited to see someone use that technique! :pop:
Homerlovesbeer
Post by Homerlovesbeer »
I'm following with interest. Nice so far.
EasyEight96
Malaysia
So..... after leaving it aside for a longggg time I've decided to finish it before the dealine
The photos of the step by step of applying the maskol chipping on one of the raiden has mysteriously when corrupted so all photos of it are gone
Here is the photo of both raidens all painted up
So once it's dried I used a stiff brush and removed the maskol on the raiden the second one will receive my normal sponge chipping which I'll do it later
In -progress
