Pin Wash Recommendations?
Filmman586
Post by Filmman586 »
Guys,
Any good recommendations for pin washes?
Lou
My YouTube Channel
Omi
Re: Pin Wash Recommendations?
Post by Omi »
Is it for panel lines or over all color ?
If you are just starting out....
You can use small enamels paints, diluted to the right consistency !!!
same with artist oil paints...
Remember to use a good quality Acrylic clear coat to protect your paint work before hand.
I myself use often pré-made ones for convenience sake... like
Ak interactive or Ammo, Mig and the like... but often use Artist oils....
to vary the sauce....
:thumb1:
Filmman586
Thanks Norm!
Lou
My YouTube Channel
Filmman586
Omi wrote:Is it for panel lines or over all color ?
panel lines
Lou
My YouTube Channel
m0rce
Post by m0rce »
Hi.
Just started using citadel "shades" they call 'em.
I like them. Practical and works well over a layer of future/klear
Good luck
S.
Omi
Post by Omi »
Haven't tried the citadel, but what I use is Indian ink diluted with airbrush thinners, or black ink good quality, thin it very heavy say 2 drops ink 20 drops thinner.
Try it on a test piece first, remember don't brush it every where as it's hard to get off your klear coat when dry.
It has great capillary action and drys a little softer, play around with the mix and you'll find it great for panels and crevices.
As I said test first it's not like a wash.
The rivets on this model were done in this method.
All the best.
Martin
Good tip Martin, going to try that ink trick
For rivets and panel lines I am envisioning using a really small brush and just a smidge of the mixture ?...as opposed to slopping it everywhere and wiping it off like a traditional wash
You do really need to seal your paint first or the black stays everywhere...ask how I know
MikeyKb
Post by MikeyKb »
Best acrylic gloss coat you should lay down is Alclad Aqua Gloss. Phenomenal stuff, that!
Mikey
MikeyKb wrote:Best acrylic gloss coat you should lay down is Alclad Aqua Gloss. Phenomenal stuff, that!
Ok I am going to try that stuff
My Future acrylic isn't as predictable
Filmman586
Thanks Guys! I did use alclad Aqua gloss coat! Great stuff!
Lou
My YouTube Channel
Oil wash Lou, so much easier to use
MikeyKb
Post by MikeyKb »
It's amazing. and it's acrylic, unlike all of their other products. cleans up great with water, usually goes down in one coat.
:thumb2:
Mikey
Just don't do what I did. Buy the alclad klear kote, then start spraying, then realise you bought the Matt not gloss! Lol!
Filmman586
Paul wrote:Oil wash Lou, so much easier to use
Paul what's a good oil wash?
Lou
My YouTube Channel
My favourite oils are the mig productions 502 ones, mixed with some odourless mineral spirits you can make you own washes, filters, effects etc
You can also pin wash with Ultimate washes ;)
Filmman586
Thanks Paul! :cheers2:
Lou
My YouTube Channel
JohnModeller
Post by JohnModeller »
I like using the Tamiya dark grey pin wash. It oil based and has a very fine applicator.
John
If I see you shooting at someone in a parachute, I will shoot you down myself- Gustav Roedel, JG 27, Afrika Korps Desert Squadron, Luftwaffe
Return to “Weathering”
