Eduard Danger Zone F-14A
JonMW
Post by JonMW »
For this SIG I'll be building Eduards limited edition Danger Zone kit. All the plastic is from Hobby Boss and then Eduard added some resin, PE and decals. Also bought some more PE from Eduard for it to add some more details.
The box
The plastic sprues, there is a lot of plastic in this kit.
The PE included in the kit, nose cone and masks.
Two decal sheets.
The hamster coffin.
Resin parts
Extra PE and fabric seatbelts.
Just a few more days until I can start this, can hardly wait.
DaveTheMinion
Re: Eduard Danger Zone F-14A
Post by DaveTheMinion »
I have the same kit, but wont be starting my build for a couple of months yet, that will give me time to see how you get on and nick your ideas :nena:
Where did you buy the extra PE and seatbelts from?
looking forward to your build
all the best
Dave
Old Age: More experience but can't remember it..
Under Construction
1:72 HMS Victory.
1:250 IJN Akagi.
LudvigN
Post by LudvigN »
Loads of goodies! Looks like an epic build. Jag har samma kniv! :)
Ludvig :cheers2:
Airfix 1/72 A-4 Skyhawk
Last one finished:
Bandai 1/72 A-Wing Gallery
Lego
Ireland
Post by Lego »
Ha ha the knife out for the pe when you decide to end it all.
Lego wrote:Ha ha the knife out for the pe when you decide to end it all.
Lmao
Great kit hoping to start mine for this build too :thumb2:
1001kjk
Post by 1001kjk »
I to am lucky enough to have this in the stash and will bookmark and join you for the "journey" :th:
RoscoRSA
Post by RoscoRSA »
If you don't mind me asking, what Livery are you going to go with?
I have the Academy 1:48 Tomcat in the VF-111 Sundowners Livery (Cartograf Decals) that I am going to enter into this SiG.
Tamiya 1:48 MIG-15
On Hold
Academy 1:48 F-86 Saber
DaveTheMinion
Here are your music choices for building this model...
Open the box
For when you start work on the PE parts
For when you have successfully picked up all the parts from the floor, your wounds are healing and you can see again.....
Under Construction
1:72 HMS Victory.
1:250 IJN Akagi.
JonMW
Post by JonMW »
I got all the extra stuff from Eduard. Not sure what livery I'm going to do, I think either Sundowners or Jolly Rogers.
I think I'll enjoy this build even if it didn't start off to well. Was looking though the parts for the cockpit and saw this.
Half of the back wall is missing, guess they didn't inject all the plastic needed. So I will be sending Eduard en e-mail and asking for a replacement.
gaz45
Post by gaz45 »
I have this kit but not sure i have the confidence to do it justice at the moment so will be watching this build
EasyEight96
Malaysia
Post by EasyEight96 »
Nice choice the title of the box say's it all now I'm busy listening to the song lol
In -progress
Too many on the bench!!!
Matchbox Kits lover....
JonMW
Post by JonMW »
Finally got the replacement cockpit from Eduard so now I have been able to get started on this. Started off by removing all the molded in details that will be replaced by the PE using a small chisel and then sanding it smooth using some Thinny Sticks. The Hobby Boss parts are really nice and would build up to a well detailed cockpit and then the PE adds that little extra. Every thing fits really well. Next up will be the front landing gear bay and then I can get painting.
robertw
Post by robertw »
Just don't do what I done and forgot to put the landing gear bays in before you put the fuselage halves together... Ruined it and had to buy another kit.
m0gb0y74
Post by m0gb0y74 »
gaz45 wrote:I have this kit but not sure i have the confidence to do it justice at the moment so will be watching this build
Same here :lol:
JonMW
Post by JonMW »
Thanks for the warning, I was looking at that for a wile and saw that it would be a big problem not to put the landing gear bay in before gluing the half's together. I have gotten the cockpit painted and finished, used Model Air 046 for the overall color and then some flat black and Khaki. The back part where given a Ultimate Concrete wash, the other back parts where dry brushed in a light grey and finally I applied a dark enamel wash to all the parts.
Not sure if this will be a tail sitter or not, there is nothing in the instructions. But just to be on the safe side I added a few scrap nuts to the front and glued them in using CA glue.
RoscoRSA
Post by RoscoRSA »
This is starting to really look great.
As for it being a tail sitter, it isn't, but you can never be to safe :thumb2:
Tamiya 1:48 MIG-15
On Hold
JonMW
Post by JonMW »
Thanks!
Time for a small update. I had to trim some of the PE parts for the air brakes to make them fit which I thought was a bit strange.
After seeing Paul using the Tamiya Extra thin and sprue mix for filler I thought I would give it a try. I used this method something like 15 years ago when my local hobby shop couldn't get any good filler for some reason. But at that time I didn't have TET so I used some other glue, and I hated it. It never dried was hard to put on and just didn't work. But now with TET I found it working really well, so thanks to Paul for the tip.
Got the fuselage glued together, the front part and stabilizers are just dry fitted for now to make it easier to rescribe some of the lines. This thing has a pretty good size.
rwsmith14
Post by rwsmith14 »
NIce looking Cockpit !!! she's looking good !! :thumb2:
shortCummins
Post by shortCummins »
wow, she looks huge, nice job so far :th:
rgds
John(shortCummins)
m0gb0y74
Post by m0gb0y74 »
Looks awesome - I can see me losing all those small bits of etch though!
JonMW
Post by JonMW »
Thanks for the comments!
JonMW
Post by JonMW »
A bit more work. The underside of the ailerons don't have any details at all, but should have some panel lines.
So I used 3M fine line tape to make a guide for the scriber. The tape is pretty thick plastic and if you are careful works well as a guide.
And a bit more PE.
The fit of most parts is really nice, but then there are some places that have big gaps like this.
It's a bit better you push it in, but there is still a gap, so that will need some filling.
Cracking work mate loving that PE gun bay.
JonMW
Post by JonMW »
Thanks!
Its ready for paint, well mostly I managed to loose two parts, both of them took a flight from the tweezers across the room. So I think I'll have to scratch something to replace them.
mincemeat
Post by mincemeat »
That's a mighty fine aircraft you have there sir. Can't wait to see it painted!
Current Builds
Homerlovesbeer
Post by Homerlovesbeer »
Looking REALLY good! My kit is tempting me now....hmmmm
JonMW
Post by JonMW »
Thanks!
Have added the two parts that flew off. Pretty simple parts, made them from some sheet sanded to shape.
ladip63
Post by ladip63 »
Looking good. That cockpit is awesome. I'm going to have to get this kit!
Lynn
Metal Earth R2D2
JonMW
Post by JonMW »
Thanks!
Got it primered and preshaded today, with a bit of luck I should have the first coat of paint on tomorrow.
Some very nice work you have got there :clap:
I have this kit too and i went crazy and got me the other pe aswell
Are you using the weapons set aswell that is advertised on the back of the instructions?
JonMW
Post by JonMW »
MarkVerploeg wrote:Some very nice work you have got there :clap:
Thanks, No I will just go with the ones included in the kit, I think they look pretty good.
I think the kit missles are good like you say
I just got the set out of pure lazyness so i don't have a lot of sanding to do on them
JonMW
Post by JonMW »
You know what my superiors told me when I was in the army? "A lazy soldier is a smart soldier", so I guess you're the smarter one ;)
Got the grey and the yellow painted today, will wait a few days before I start masking for the black to make sure the paint is fully cured.
JonMW
Post by JonMW »
Got the rest of the paints on as well as the first coat of clear. I had some problems with paint pulling off in a few spots, but I managed to fix it so it's not too noticeable. Next up is decals.
shortCummins
wow, that splash of black and yellow really bing her together :clap:
rgds
John(shortCummins)
kiwigav
New Zealand
Post by kiwigav »
Sweet looking machine. Nice build :th:
Cheers Gav
Nice paintjob Jon
There is no doubt from wich unit it is now
I will paint mine in the same colors when i build mine
Just to match the Phantom i have
Keep up the good work
mincemeat
Post by mincemeat »
Beautifully done!
Current Builds
Homerlovesbeer
Looking REALLY nice Jon! How did you go fixing the gaps underneath where the nose joins the fuselage?
Any pics as that was quite a decent gap to fill....
JonMW
Post by JonMW »
Thanks for the comments! I totally forgot to take any pictures of the gap beeing filled. But I used sheets of plastic pushed down in the gap and then trimmed and sanded to shape. Can't remember if I used Tamiya putty or molten sprue to smooth it out. It's pretty much the same method I used on my Ju-88 and I did take some pictures of that.
Have done a bit more work, the fuselage is glued together. There is a big gap on the bottom between the two halves of the fuselage and the lower part.
There is also a hole on the top of the fuselage.
I didn't want to just use filler as this would most likely shrink over time and leave a mart. To solve this I cut a piece from a sheet of styrene a bit thicker than the width of the gap (maybe 0,05mm). The small notch on one of the sides is to clear a tab that locates the lower part of the fuselage.
This was then pushed in to the gap and glued in place using Tamiya thin cement. The piece was made quite big so that I could get a good grip of it and really push it all the way in.
Cut it down with a knife.
And finished off with some sanding sticks. It will still need a bit of filler, but still a lot less than what would be needed to fill the gap.
mincemeat
Post by mincemeat »
Very nicely done. I had to do something similar with a Revell Stuka. The elevators were just to be slid in a large wobbly hole. Shimmed it with some styrene strips, some extra thin, trim, putty sand, gone.
Current Builds
wesleye18
Post by wesleye18 »
looks really nice man! :)
JonMW
Post by JonMW »
Thanks!
Managed to get all the decals on. It's really nice to use Cartograf, they all fit and conform really well.
1001kjk
Post by 1001kjk »
Looking good :thumb1:
gaz45
Post by gaz45 »
Great work there mate im looking forward to starting mine
JonMW
Post by JonMW »
It's getting close to done! Got pretty much all the detail painting done, next up will be final weathering and clear coats and then seats and weapons.
Painted the engines in AK Xtreme Metal Jet Exhaust followed by a light dusting of Burned Metal and finished with a but if Tamiya transparent blue at the edge.
As it stands now.
Howard
Post by Howard »
Wow!! How darn good does that Turkey look!
Awesome job
Howard
kiwigav
New Zealand
Post by kiwigav »
Very cool, got some xtreme metal on order...looking forward to it. Nice finish :th:
Cheers Gav
Ads24
Post by Ads24 »
Looks absolutely stunning, mate.
Revell 1/32 Hawker Hunter
JonMW
Post by JonMW »
Thanks for the comments!!
