Egg Wulf 190
EasyEight96
Malaysia
Egg Wulf 190
Post by EasyEight96 »
Hey guys this is the kit I'll be using. The kit is not here yet it should be here in two days time
As I'm having finals in a weeks time I'll be posting up my progress on the weekends only.
In -progress
Too many on the bench!!!
Matchbox Kits lover....
Re: Egg Wulf 190
Cool build
She has creepy red eyes :twisted:
EasyEight96
Malaysia
Re: Egg Wulf 190
1st update
The kit arrived today this afternoon so without any delay I started the build
Here is the inbox preview
Progress
I've join the halves together and it a nasty fit so I have to fill up with putty
Once it was dried I sanded it down and glue the wings and the tail wings together
Can't resist dry fitting the parts so here is how it's looking so far
Next is to add some detail for the empty cockpit stay tune
In -progress
TommyKillander
Re: Egg Wulf 190
Post by TommyKillander »
Cool aircraft, good luck with the build!
Re: Egg Wulf 190
Looking good so far, enjoy the rest of the build! :) :thumb1:
EasyEight96
Malaysia
Re: Egg Wulf 190
Thanks mates
So I added some seatbelts for the cockpit I just use some masking tape and here is how it looks like
Next I mask the canopy using Humbrol's Maskol I don't use it that often but since this canopy lines are still visible so why not use it
Since I'm having a lack of space on my desk I decided to use the box as my parts holder. I just have to poke some holes and here is how it looks like
Quite neat tbh I could reduce the amount of boxes lying around my room
I then started on my base. I wanted my fw190 to be on a field so I used this few materials for it
Once the grass was cut according the measurements of the base I cut it out and apply the white glue over the base and vo la here is my simple base for my fw190
Next job shall be priming the plane and starting the paint job
In -progress
Re: Egg Wulf 190
Love it when the effort goes into a diorama as well
Looking good :banana:
EasyEight96
Malaysia
Re: Egg Wulf 190
Twokidsnosleep wrote:Love it when the effort goes into a diorama as well
Thanks :th:
In -progress
EasyEight96
Malaysia
Re: Egg Wulf 190
Some updates....
I painted up the cockpit area and painted up the seatbelts and the seat it was then followed by putting the little cockpit in its place
I gave the bottom another layer of filler as the seam line was still visible
Then it was sanded down and it is as smooth as an egg
I then proceed to priming the plane and the bottom part of the base using Vallejo's black primer
I gave it a few hours to dry and I apply the first colour light blue
Leaving it to dry again I then masked up the areas for the camo scheme I choose the second scheme for this. I choose this because as it was the plane based on the current airfix 1/24 fw 190 boxart and the plane belongs to an ace pilot too
I'll start it camo scheme tomorrow hopefully my mixture for the camo work out like how it should wish me luck boys
In -progress
TommyKillander
Re: Egg Wulf 190
Looking good!
EasyEight96
Malaysia
Re: Egg Wulf 190
Final Update
Continue from the previous progress I spray up all the camo colours. For the lighter grey I mixed XF-22 and XF-1 and the darker grey is XF-63 not sure the pics can do justice but the difference is very clear to my eyes. Later I painted the yellow parts and hand painted the engine with gun metal plus an aluminium dry brushing.
Once it's all done I assemble up the landing gears , prop and the bombs. The exhaust then masked and painted flat black
Next up decalling time!! Most of them go on well but some were bad
Thats the end of this build the finish product is in the reveal section. Thanks for the support :th:
In -progress
Return to “Everything else”
