Planemaker's Birdcage!
planemaker
Post by planemaker »
Greetings! My entry is a Tamiya 1/48 Chance Vought F4U-1 Birdcage Corsair. I'll be building it OOB for this time. Because, I wanted to build something easier then the Fine Molds Judy for the Rising Sun GB, that I sadly won't be able to finish, because, OK let me tell the story. :wall:
___________________________________
-After I primed and pre-shaded the Judy I put a coat of Mr. Metal Aluminium on the thing cause I wanted some chipping. I wanted to try a new method of chipping so I used some Vallejo Chipping Medium. BUT after I painted the underside I noticed that the dots of Vallejo chipping fluid I put on the model had gone thru all the layers of paint and primer when it should have just pulled away the top layer of paint to expose the aluminium colour underneath..... :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash: :bash:
:pistols: :pistols: :pistols: :pistols: :pistols: :pistols: :pistols: :pistols: :pistols: :pistols: :pistols: :pistols: :pistols: :pistols: :pistols:
-You don't wanna know how it looks now!
-Let's forget that and go back to the Corsair build!
History
The Chance Vought F4U Corsair was an American fighter aircraft that saw service primarily in World War II and the Korean War. Demand for the aircraft soon overwhelmed Vought's manufacturing capability, resulting in production by Goodyear and Brewster: Goodyear-built Corsairs were designated FG and Brewster-built aircraft F3A. From the first prototype delivery to the U.S. Navy in 1940, to final delivery in 1953 to the French, 12,571 F4U Corsairs were manufactured by Vought, in 16 separate models, in the longest production run of any piston-engined fighter in U.S. history (1942–53).
The Corsair was designed as a carrier-based aircraft. However its difficult carrier landing performance rendered the Corsair unsuitable for Navy use until the carrier landing issues were overcome when used by the British Fleet Air Arm. The Corsair thus came to and retained prominence in its area of greatest deployment: land based use by the U.S. Marines. The role of the dominant U.S. carrier based fighter in the second part of the war was thus filled by the Grumman F6F Hellcat, powered by the same Double Wasp engine first flown on the Corsair's first prototype in 1940. The Corsair served to a lesser degree in the U.S. Navy. As well as the U.S. and British use the Corsair was also used by the Royal New Zealand Air Force, the French Navy Aéronavale and other, smaller, air forces until the 1960s. Some Japanese pilots regarded it as the most formidable American fighter of World War II, and the U.S. Navy counted an 11:1 kill ratio with the F4U Corsair.
After the carrier landing issues had been tackled it quickly became the most capable carrier-based fighter-bomber of World War II. The Corsair served almost exclusively as a fighter-bomber throughout the Korean War and during the French colonial wars in Indochina and Algeria.'
F4U-1 (Corsair Mk I Fleet Air Arm): The first production version of the Corsair with the distinctive "bird cage" canopy and low seating position.[N 6] The differences over the XF4U-1 were as follows:
Six .50 in (12.7 mm) Browning AN/M2 machine guns were fitted in the outer wing panels, displacing fuel tanks.
An enlarged 237 gal (897 l) fuel tank was fitted ahead of the cockpit, in place of the fuselage armament. The cockpit was moved back by 32 in (810 mm).
The fuselage was lengthened by 1 ft 5 in (0.43 m).
The more powerful R-2800-8 Double Wasp was fitted.
150 pounds (68 kg) of armor plate was fitted to the cockpit and a 1.5 in (38 mm) bullet-resistant glass screen was fitted behind the curved windscreen.
IFF transponder equipment was fitted.
Curved transparent panels were incorporated into the fuselage behind the pilot's headrest.
The flaps were changed from deflector type to NACA slotted.
The span of the ailerons was increased while that of the flaps was decreased.
One 62 gal (234 l) auxiliary fuel cell (not a self-sealing type) was installed in each wing leading edge, just outboard of the guns.
A land-based version for the USMC, without the folding wing capability, was built by Goodyear under the designation FG-1. In Fleet Air Arm service the F4U-1 was given the service name Corsair Mk I. Vought also built a single F4U-1 two-seat trainer; the Navy showed no interest.
The Kit
I my opinion this is a good kit. It's got some nice detail here and there and the moulds are very crisp.
I'll be doing the first marking option, the VF-17 one aboard USS Bunker Hill.
Here is a quick look:
To be continued...
Sebastian S.
...and some other stuff too.
Re: Planemaker's Birdcage!
Looks a cracking kit mate good luck buddy.
planemaker
Thanks Nige! :cheers2: Some work done on the cockpit, update will follow this weekend. Stay tuned!
Sebastian S.
shortCummins
Post by shortCummins »
looks a good kit, I'll keep an eye on your build to see what, if any, the issues are as I fancy building one myself :pop:
rgds
John(shortCummins)
mincemeat
Post by mincemeat »
Thanks for the Corsair porn. Man, I love this plane. I need to get one of these kits. It looks really great, have fun. I'll be following along!
Current Builds
planemaker
Update #1
Some cockpit parts to be assembled...
Radiator flaps cut open as Nige201980 did on his Corsair build.
More parts redy for primer...
Parts of the interior and cockpit primed.
And then sprayed in Vallejo Model Air Interior green.
Some detail painting in the cockpit.
I took some old decal sheets and cut out some left over instrument decals to make the IP look better.
The result was quite good. :)
Some decals here too, but these are supplied in the kit.
Chipping effects...
And lastly an oil wash after a clear cote. Gotta love the Mig oils!
And then some Kristal Klear on the dials to get a lens effect.
To be continued...
Sebastian S.
shortCummins
it looks to me that you've got the wear'n'tear on the seat perfect :bow::
great job
John(shortCummins)
Tiger131
Post by Tiger131 »
looks superb the weathering on the cockpit is quality and they are some great pics at the start of your thread
mincemeat
Post by mincemeat »
That looks pretty spanky awesome! Great work. :clap:
I couldn't wait to see how your build turned out, I've already purchased the kit and am awaiting its arrival!
Current Builds
Love the cockpit mate really well done and love the engine cowl flaps :thumb1:
planemaker
Many thanks for the kind comments, guys! :cheers2: Much appreciated.
mincemeat wrote:That looks pretty spanky awesome! Great work. :clap:
Thanks! I hope you like the kit. In my opinion it's great for an old Tamiya kit. Have fun building it! :mrgreen:
Sebastian S.
heel
Post by heel »
That's true craftsmanship on the cockpit. Great finish and crisp but beaten up at the same time.
planemaker
Update #2
Thanks Heel!
Haven't really got time to post here in the past month, everyday life in the way as usual. But now when school's out in the summertime I've got more time for modelling, so will crack on now! :banana:
I added some leftover PE seatbelts from a Bf-109 and modified them a bit to look more like USN seatbelts.
Then I assembled the two halves of the cockpit.
Fuselage halves glued together.
Started some work on the engine.
After a glosscoat I started the weathering on the engine, first off a dark brown oilwash.
And then continued with more oils and pigments.
Engine assembled.
I made an oilwash in the landing-gear bays and some other parts.
To last I made wireing in engine with some copperwire and painted it.
Here are the finished landing-gear bays.
Engine and wing parts assembled.
Engine mounted to the cowling.
More parts of the wing assembled.
Engine and wings attatched to the fuselage.
To be continued...
Sebastian S.
Cracking build so far mate.
mincemeat
Post by mincemeat »
My kit just came in this week. I'm loving your build. Hopefully I can get mine to look half as good!
Current Builds
planemaker
Thanks for your comments Nige and Mincemeat. :)
Sebastian S.
TonyCnyc
Post by TonyCnyc »
The engine definitely looking the business!
planemaker
Update #3
Thanks Tony!
A little update this time. The Corsair is progressing at a steady speed, more to follow.
Flaps mounted to the wings.
Folding parts of the wing attatched.
Horisontal stableisers attatched.
I scratchbuilt the clear part of the gunsight using the supplied kit part and clear plastic sheet.
I scratchbuilt the pitot-tube using super small brass pipes manufactured by Trumpeter.
Gunsight attatched.
Pitot-tube attatched.
Canopy masked...
...and attatched.
Exhausts drilled out.
Masked up and ready for primer.
Some parts to be primed.
Inside colour of the canopy sprayed on.
Primed with AK Grey Primer.
To be continued...
Sebastian S.
gustavlekstal
Post by gustavlekstal »
:bow:: :bow:: some stunning skills buddy! :clap: :clap:
Regards Gustav
Dragon t-34/85 premium mod 44
viewtopic.php?f=29&t=10747
viewtopic.php?f=29&t=12313
Beautiful work mate
planemaker
Thanks for the kind words Nige and Gustav. :cheers2:
Sebastian S.
heel
Post by heel »
Great stuff. The engine work is spectacular.
Superb build so far :thumb2:
Love the instrument panel, seat and engine especially
You are doing a fine job of detailing!!!
kiwigav
New Zealand
Post by kiwigav »
Sweet looking build mate :th:
Cheers Gav
in awe you make it look so easy and matter of fact. :bow:: :bow:: :bow::
planemaker
Many thanks for your comments. Very appreciated. :D
Sebastian S.
planemaker
Update #4
The painting stage has been a bit slow but my Corsair build is picking up speed at the moment. Only ten days left of the SiG, but I only got some weathering and a matt coat to do and this will be finished. :D
Pre-shaded using AKAN Black.-Great stuff!
Underside painted using Hakata Insignia White. -From the US Navy Late paint set.
Hakata Intermediate Blue, slightly lightend mix.
Then I suddenly stumbled across this pic:
You can see that this is the particular Corsair I am building. You can also see that it has got another mast behind the cockpit,
luckily, this mast was supplied in the kit but the instructions never told to add it, so I added it anyway.
I first masked up the outline of the upper colourwith blue-tac to make it easier to get a better coverage on the paint.
After I sprayed the Hakata Semi Gloss Sea Blue on I then free-handed the edge between the semi gloss sea blue and the intermediate blue
to make a soft edge. This took many tries but now I am happy with it. :)
Underside unmasked.
Some other bits'n bobs painted.
I decided to improve the pitot-tube a bit based on pictures I've seen.
Exhaust painted.
Gloss-coated using Alclad Aqua Gloss.
Wing position lights painted.
Decaled. I had to fix some broken decals on two places, so I'll blame it all on the quality of the Tamiya decals. :bash: :shifty:
Exhaust attatched.
Last update and final reveal next week. Stay tuned!
To be continued...
Sebastian S.
planemaker
Lol! I forgot to add this little stripe between the F and 13. :lol: After the decal broke I had to fix it but forgot to fix this stripe. :wall:
Totally my fault. No worries, it's a easy fix.
Sebastian S.
Looking great mate. How did you find those paint? I used them on my Cosair and I found them not the easiest to get on with.
planemaker
Nige201980 wrote:Looking great mate. How did you find those paint? I used them on my Cosair and I found them not the easiest to get on with.
Thanks Nige!
I found the Hakata paints quite OK. I though had some problems getting the semi gloss sea blue to spray well enough to free-hand the soft edge
between the sea blue and intermediate blue. But I finally got it right using my H&S Infinity equipped with a 0.4 needle, one drop of Ultimate thinner
to about five drops of paint and the pressure at 25-30 psi.
Hope that helps!
Cheers! :cheers2:
Sebastian S.
Thanks Nige!
Hope that helps!
Cheers! :cheers2:
Cheers for the answer.
planemaker
Update #5
Final update today! I will post the pics in the final reveal section, be sure to check them out. :D
Final Reveal: http://www.intscalemodeller.com/viewtop ... 66&t=13393
I did a little filter on the decals using Mig oils to tune them down in brightness a bit.
Then I did a pin-wash using Mig oils again.
And then cleaned up.
I made exhaust and gun stains using pigments.
Matt-coated with Vallejo matt varnish.
Landing gear bays unmasked.
Landing gear bay doors attatched.
Landing gears assembled.
The rear landing gear was moulded as one piece.
Finished propeller.
Landing gears attatched.
Canopy unmasked and glued in place.
I made the antenna wires using coloured fishing rod. I used masking tape to get the tension and CA to glue them to the antennas.
After the glue dried I cut off the excess and removed the tape.
I made the light or whatever it is under the wing using a piece of aluminium foil. The clear part was supplied in the kit.
Sebastian S.
She is beautiful mate love everything about her.
planemaker
Many thanks Nige. Very kind. :cheers2:
Sebastian S.
mincemeat
Post by mincemeat »
That is such a beautiful job! Great work on a lovely piece of eye candy.
Current Builds
planemaker
Thank you Mincemeat. Appreciate it. :cheers2:
Sebastian S.
Great build, just read it from start to finish, look forward to seeing the final reveal :cheers2:
planemaker
Many thanks, Paul. :cheers2:
Final Reveal can be found here: http://www.intscalemodeller.com/viewtop ... 66&t=13393 :thumb2:
Sebastian S.
Excellent work! :th:
planemaker
Thanks DB! :cheers2:
Sebastian S.
