Tamiya 1/48 A6M2 and Hobbycraft P-40C
peaceduringwar
Post by peaceduringwar »
Hello all,
Working on a second Tamiya Zero and decided to build Hobbycraft's boxing of the Academy P-40C. The Zero has the cockpit finished and wings joined and filled to the fuselage and, the P-40 just has the cockpit started. The Zero I am going with sky over green, and the P-40 will be RAF green and brown over sky. Hope to post more pics of progress soon.
Thanks Everyone :cheers2:
Chris
Why must I have insufficient funds?
1/72 Italeri B-25B
1/48 Tamiya A6M2-N
1/350 Dragon Ohio Class SSBN
1/700 Tamiya IJN Kinu
peaceduringwar
Re: Tamiya 1/48 A6M2 and Hobbycraft P-40C
Alrighty then, got the P-40 cockpit done and installed, and the engine w/prop finished on the zero.
Chris
1/72 Italeri B-25B
1/48 Tamiya A6M2-N
peaceduringwar
Another update for the current builds,
The P-40 now has camo and a few bits glued on and painted. Tried using paper masks for the camo but didn't turn out great (had a lot of touch up to do). Overall I am satisfied with how it turned out. I need to try other masking techniques for this style of camo. The zero is on hold for now until i find a new canopy for it, as the one that I was masking was a critical failure. A dull knife will do that. Overall both are coming together quite nicely so far.
Chris
1/72 Italeri B-25B
1/48 Tamiya A6M2-N
patrickroos
Post by patrickroos »
Nice work!
Clean build and camo looks great. :th:
In progress:
peaceduringwar
I finally have sourced a replacement canopy for the Zero, and can continue with that build. :dance: In the mean time I have finished the P-40. Going to post more pictures of the P-40 in the gallery soon.
Chris
1/72 Italeri B-25B
1/48 Tamiya A6M2-N
