What type of glue do you use?
slickmick
Post by slickmick »
For 1/35 Tank
What type of glue do you use to Glue the end of the Rubberband Tracks ??
Thanks SlickMick
slickmick
Re: What type of glue do you use?
Post by slickmick »
I tried using regular model glue left alone for 24 hours and it still came apart.
Then I tried Tamiya glue & it still wouldn't hold.
Any suggestions would help a lot
Thanks SlickMick
ForbesHutton
Post by ForbesHutton »
Most of the band tracks, especially the older ones, are meant to be melted closed. I have an old screwdriver that I heat up over a candle and get it hot before melting the nubs down.
For the modern styrene types that can be glued (Dragon's DS track for example) I just use my normal Tamiya Extra Thin and then clamp the joint.
slickmick
Post by slickmick »
Oh ok thank you.
I guess that's what I'll have to do Melt the track together..
SlickMick
slickmick wrote:Oh ok thank you.
SlickMick
What model is it ? Brand and Kit N#
Please...
It has to be listed in the instructions how to approach that step isn't it ???
Some vinyl glue exists... but are quite expensive...
but knowing what you are building would be useful !
Return to “Glues and Fillers”
