MT ANG F-106 Delta Dart (Revell 1:48)
HistoryRider
Post by HistoryRider »
Hello ALL!!!
I get to finally submit my entry into the Homeland GB!! I will be building a 1:48scale Revell F-106 Delta Dart in Montana Air National Guard livery.
The F-106 was the ultimate interceptor built for the USAF by Convair and was solely used for that purpose in the 1960's through the 1980's. The interceptor mission was relegated to the Air National Guard units when the Air Force started to retire the Century Series airframes and replace them with F-4s and ultimately the F-15s and F-16s. The F-106 was a very fast and capable airframe, using all the lessons learned from the F-102 (also built by Convair). It was a notable performer in the William Tell exercises (Montana took home a few trophies)
Here is a little about the F-106 (from Wikipedia)
General characteristics
• Crew: 1
• Length: 70.7 ft (21.55 m)
• Wingspan: 38.25 ft (11.67 m)
• Height: 20.28 ft (6.18 m)
• Wing area: 661.5ft²/61.52m² (Original Wing) or 695 ft²/64.57m² (Conically-Cambered Wing) ()
• Airfoil: NACA 0004-65 mod root and tip
• Empty weight: 24,420 lb (11,077 kg)
• Loaded weight: 34,510 lb (15,670 kg)
• Powerplant: 1 × Pratt & Whitney J75-17 afterburning turbojet, 24,500 lbf (109 kN)
• * Zero-lift drag coefficient: 0.0083
• Drag area: 5.8 ft² (0.54 m²)
• Aspect ratio: 2.10
Performance
• Maximum speed: Mach 2.3 (1,525 mph, 2,455 km/h)
• Range: 1,800 mi (1,600 nm, 2,900 km) combat
• Ferry range: 2,700 mi (2,300 nm, 4,300 km)
• Service ceiling: 57,000 ft (17,000 m)
• Rate of climb: 29,000 ft/min (150 m/s)
• Wing loading: 52 lb/ft² (255 kg/m²)
• Thrust/weight: 0.71
• Lift-to-drag ratio: 12.1
• Time to altitude: 6.9 min to 52,700 ft (16,065 m)
Armament
• Guns: 1 20 mm caliber M61A1 Vulcan 6-barreled rotary cannon (After 1972 refit)
• Missiles:
• 2 AIM-4F Falcon
• 2 AIM-4G Falcon
• 1 AIR-2A Genie nuclear rocket or AIM-26 Super Falcon missile (Prior to 1972 refit)
Cool huh??!!!
I am building an airframe from my home state of Montana's own Air National Guard unit, the 186th Fighter Interceptor Squadron.
MTANG F-106 Tail No. 72478 (courtesy of f-106deltadart.com)
The kit:
1:48 Revell (Re-release of the Revell-Monogram kit of the '80's) It is raised panel lines, minimal detail, and lots of flash and injector pin marks. That is to be expected of the Revell re-releases, but until Trumpeter released a 1:48 scale kit, it was the only one. Decals are rather poor with lots of silvering. The fit is okay, but will require LOTS and LOTS of filling and sanding.
Here is my review:
Here are some pictures from the Open and Review:
Box Art
Decals (Kit on left, MTANG on right)
Delta Wing
Fuselage
Delta Wing and Fuselage
Sprue Shot
Sprue Shot
Sprue Shot
Clear Parts
I am dedicating this build to the late Dane Donnelly. Without his support and encouragement, I wouldn't have an interest in model building.
Rest in Peace Dane, thank you for all the help
That's all for now!
Last edited by HistoryRider on Tue Jun 09, 2015 10:06 am, edited 2 times in total.
HistoryRider
Tamiya 1:35 M4 Sherman
Tamiya 1:35 Panzer IV AusfD
To Be Determined
rwsmith14
Re: MT ANG F-106 Delta Dart (Revell 1:48)
Post by rwsmith14 »
Cool !! :thumb2:
HistoryRider
Quick Update:
The F-106s of the MTANG 186th FIS had a unique cockpit color. It was a type of Blue that was not standard to any other F-106 unit. There are a couple schools of thought how this came about.
Story Number One: Blue is supposedly easier on the eyes, so the Montana ANG decided to test it out on their Interceptor aircraft so the pilots could focus on the instruments easier.
Story Number Two: A Russian MiG-25 Foxbat defected and it had a unique color of blue in the cockpit. The Montana ANG liked that color and decided to paint their aircraft in a similar fashion.
You decide...
MTANG F-106 Cockpit "Foxbat Blue" color
Base color before detailing the cockpit. To get the blue I used a mixture of 50% Flanker Medium Blue and 50% FS35414 Blue Green supplemented by three drops of FS35109 Blue:
HistoryRider
To Be Determined
HistoryRider
Cockpit Update:
I got the ejection seat and cockpit tub all built and painted. Not much detail to the Monogram/Revell kits in this department. Luckily most of the detail or lack there of will actually be hidden. Blessing in disguise really, since I couldn't find ANY aftermarket detail sets for this part of the kit.
Instrument Panel
Cockpit tub with Instrument Panel
Ejection Seat
Cockpit Assembly
Next step will be main fuselage assembly. This will require a bit of TLC with filling and sanding!
More Later!!
HistoryRider
To Be Determined
HistoryRider
Okay gang, here is the latest progress.
I got the upper fuselage halves mated together and the cockpit tub installed.
The tail was a bit tricky and there was a step in the join so I shaved it down with a chisel blade and that got everything flush, but it will still require sanding and filling to get it ready for the primer coat.
Fuselage Left
Fuselage Right (you can see the lousy design that makes the tail a lot of work)
Tail Closeup (fixing this will put the F U in fun)
Cockpit in Foxbat Blue
Next step will be the delta wing/lower fuselage assembly. This will take a lot of work since the mold design is all one piece and has LOTS of surface area to cover.
More Later
HistoryRider
To Be Determined
HistoryRider
Okay gang! Here is a quick update!
I got the wing/lower fuselage assembled. It took a bit of finagling but I got it to look fairly decent. It will require filling and sanding to get rid of a couple of odd steps and gaps, but it will look fine.
I've been working on the landing gear bays and engine/tailcan assembly as well.
Delta wing assembly
Delta wing assembled (not horrible but needs fixed)
Landing gear bay
Engine Assembly (pretty bare bones stuff)
That's all for now! More later! :th:
HistoryRider
To Be Determined
TommyKillander
Post by TommyKillander »
That kit really has some nice detaling, but it seems to have a couple challenges as well. The build looks great sofar! :thumb2:
That Foxbat blue interior looks awesome, great story about it too!
Keep up the good work!
/Tommy
HistoryRider
TommyKillander wrote:That kit really has some nice detaling, but it seems to have a couple challenges as well. The build looks great sofar! :thumb2:
/Tommy
Thanks Tommy! Much appreciated mate! It is a challenge but it will be worth it!
-Nolan
HistoryRider
To Be Determined
