Pre shading
Droflet01
Pre shading
Post by Droflet01 »
Hi guys quick question. Can you pre shade panel lines with a brush? I do t have space to use an airbrush in my military accommodation
Cheers matt
Re: Pre shading
If you plan to brush paint the whole thing.... you risk re-activating the pre-shade layer... due to brushing action and paint thickness !
I would opt for Post shading using pastels... in the range of colour your model will be painted in... but a tad darker... that way you can control how much you apply !!! and you won't risk having a sticky mess...
Just saying !
There is the Sharpie Marker solution but once again.... How would you father the top layer to let the pre-shade show through ? would be very hard...
Pastel post shading seems a better solution ! (my 2cents)
Droflet01
Re: Pre shading
Post by Droflet01 »
Cheers mate I'm new to all this and never even heard of pastel post shading. Will have a read up on it.
Return to “Weathering”
