Dragon 1/35 M4 DV
Jack
Dragon 1/35 M4 DV
Post by Jack »
Hi all for my next build I will be building the Dragon 1/35 M4 DV looks like a great kit and the box was cramed full of plastic :th:
Some photos of the box
Upper hull
Lower hull
DS style tracks
P.E parts, decals and metal cable
Sprue shots
Clear sprue
And finally the instructions
Tamiya 1/35 Tiger 1 mid production
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Re: Dragon 1/35 M4 DV
Post by Jack »
Ok so I made a start on the kit this evening and started on the turrert, went together well, just a few small parts and hatchs left to add
Hopefully I will be able to crack on with it more next week and have it ready for paint by next weekend.
Bandai AT-ST
Dragon 1/35 M4 DV
This is a really sweet little kit bud, it should build up well.
Mine didn't come with those tracks though. I wonder if yours is a newer or older release of the kit.
Interesting.
Jack
Post by Jack »
Coen wrote:This is a really sweet little kit bud, it should build up well.
Interesting.
I think that mine is the 2009 version :cheers2:
Bandai AT-ST
Dragon 1/35 M4 DV
CharleyGnarlyP290
Post by CharleyGnarlyP290 »
I am looking forward to this build. for some reason I really dig the direct vision Shermans. I want to build one like this and one of the type that has the added armor plates over the vision slits.
I have never built a Dragon kit and this may be my first depending on how yours goes.
Mylightweight
Post by Mylightweight »
Looking good so far, I love a good Sherman
On the bench;
Tamiya Dragon Wagon & Jagdpanther
RFM Bergepanzer Tiger 1
Eduard Spitfire mk IXc
Bomber SIG
In the stash;
Too much to list, let alone build
Jack
Post by Jack »
CharleyGnarlyP290 wrote:I am looking forward to this build. for some reason I really dig the direct vision Shermans. I want to build one like this and one of the type that has the added armor plates over the vision slits.
Thanks, so far the kit has gone together very well and I would recommend getting one :cheers2:
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Post by Jack »
Mylightweight wrote:Looking good so far, I love a good Sherman
Thanks mate :cheers2:
Bandai AT-ST
Dragon 1/35 M4 DV
Nige1940
Post by Nige1940 »
Yeah I like those DV Shermans too great looking kit and a superb job your doing of it .
Jack
Post by Jack »
Nige1940 wrote:Yeah I like those DV Shermans too great looking kit and a superb job your doing of it .
Thanks :cheers2:
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Post by Jack »
Finished the turret off this evening
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Post by Jack »
Completed the front of the lower hull today, so far no major fit issues :banana: Image[/URL]
Bandai AT-ST
Dragon 1/35 M4 DV
tferedo
Post by tferedo »
So far so good. I will be watching this build as I plan to get the same kit soon.
Jack
Post by Jack »
tferedo wrote:So far so good. I will be watching this build as I plan to get the same kit soon.
Thanks, I look forward to watching your build when you start it :thumb2:
Bandai AT-ST
Dragon 1/35 M4 DV
HamilkarBarkas
Post by HamilkarBarkas »
I built the model not too long ago and was not really impressed by it. Somehow the front section did not fit well on the lower and upper hull. maybe it was just me :) yours looks good so far, no question!
Jack
Post by Jack »
HamilkarBarkas wrote:I built the model not too long ago and was not really impressed by it. Somehow the front section did not fit well on the lower and upper hull. maybe it was just me :) yours looks good so far, no question!
Thanks :cheers2:
Bandai AT-ST
Dragon 1/35 M4 DV
That's a common fit issue with dragon Shermans. It's a pain, but fixable with some fiddling.
Looks great so far Jack.
Jack
Post by Jack »
Coen wrote:That's a common fit issue with dragon Shermans. It's a pain, but fixable with some fiddling.
Thanks :cheers2:
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Post by Jack »
Finished the lower hull this afternoon, only one fit issue which is when I had to attach the front section to the main section
Bandai AT-ST
Dragon 1/35 M4 DV
Nige99
Post by Nige99 »
Looking good so far!! I really enjoyed my Sherman build recently. Only had two issue's
You can run, but you'll only die tired!
Jack
Post by Jack »
Nige99 wrote:Looking good so far!! I really enjoyed my Sherman build recently. Only had two issue's
Thanks :cheers2:
Bandai AT-ST
Dragon 1/35 M4 DV
Oper8or
Post by Oper8or »
Looks tons better than my build and youre just starting it. I'm watching this one close. Please keep posting so I can learn from this. I've noticed there is a build difference between different armor types. I want to really see what the primary color turns out like. I cant wait to see it finished!
Jack
Post by Jack »
Oper8or wrote:Looks tons better than my build and youre just starting it. I'm watching this one close. Please keep posting so I can learn from this. I've noticed there is a build difference between different armor types. I want to really see what the primary color turns out like. I cant wait to see it finished!
Will do, thanks :cheers2:
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Post by Jack »
Started work on the upper hull this afternoon, going together well so far :dance:
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Post by Jack »
Attached the upper and lower hull this morning, only a small amount of filler was required, only a small amount of photo etch left to add then it's ready for paint
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Post by Jack »
Photo-etch attached
Next up other to the spray booth ready for priming and then a coat of olive drab
Bandai AT-ST
Dragon 1/35 M4 DV
Nige99
Post by Nige99 »
Not built a DV yet but I will at some point. Yours looks a great kit. What olive drab paints are you going to use?
Jack
Post by Jack »
Nige99 wrote:Not built a DV yet but I will at some point. Yours looks a great kit. What olive drab paints are you going to use?
I was thinking of using the Above interactive modulation set or the standard vallejo olive drab.
Bandai AT-ST
Dragon 1/35 M4 DV
Nige99
Post by Nige99 »
I've used them all Jack. I think the vellejo colours are way off the colour of Olive drab. I've just used the Mig ammo modulation which I found to be good. Also tamiya OD for the sides and for the highlights a mix of deck tan mixed in. The true Olive drab colour is a big subject in its self so have a go with a few of them.
Jack
Post by Jack »
Nige99 wrote:I've used them all Jack. I think the vellejo colours are way off the colour of Olive drab. I've just used the Mig ammo modulation which I found to be good. Also tamiya OD for the sides and for the highlights a mix of deck tan mixed in. The true Olive drab colour is a big subject in its self so have a go with a few of them.
Ok thanks for the advice, I'll look into it :th: :cheers2:
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Post by Jack »
All primed next step olive drab
Bandai AT-ST
Dragon 1/35 M4 DV
Nige99
Post by Nige99 »
Looking good so far!! Might see if I can pick up a DV at Telford.
Jack
Post by Jack »
Nige99 wrote:Looking good so far!! Might see if I can pick up a DV at Telford.
Thanks :cheers2: I highly recommend this kit
Bandai AT-ST
Dragon 1/35 M4 DV
Jack
Post by Jack »
Painted in vallejo olive drab next up the decals and tracks will probably do the decals tonight as there's not many
Bandai AT-ST
Dragon 1/35 M4 DV
