Paul's DIY Photo booth
A few of you may have seen the small lighting booth i made a while back, well that that worked ok under my desk lamps but i wanted something more permanent that was always set up and ready to rock and roll.
So using the following materials i built my custom made 600mmx450mmx400m booth, which cost about £40 in total
2 A1 sheets 5mm foamboard £7 from hobby craft
2 600mm T8 fluorescent lights with 6500k 18w daylight tubes £24 from local electrical shop
Cable and plugs £5
Various colours (white, grey, blue and black) a2 card 50p a sheet from local art shop
2 plastruct channel pieces. £2 from local model shop
I cut the foam board to size and glued it together using CA Glue, the light fitted perfectly over head and i added strengthening bars in between, this way i can shot through it form above. I wired the lights up using the 3 core cable, if your not sure get an electrician to do it for you.
I glued two lengths of the plastruct channel to the back and front, this allows the card to sit perfectly with a nice curve at the back and i can switch colours in seconds and store all the card in there if needed.
Ands that it really, i covered the lights with some paper to defuse the light and it works great, I'm no expert with a camera but it defo makes a difference to my pictures so I'm happy with it. Im using a panasonic lumix bridge camera
And some of the pictures I've taken recently
jbellos1
Re: Paul's DIY Photo booth
Post by jbellos1 »
Very nice set up. Good to have a dedicated spot that we can see works very well.
AtomicAndy
Post by AtomicAndy »
Fantastic piece of kit.
stuart66madmodeller
Post by stuart66madmodeller »
Awesome job mate.
:welcome:
kiwigav
New Zealand
Post by kiwigav »
Great set up Paul :th:
Cheers Gav
ke1stcav
Post by ke1stcav »
I can see how nice the pictures came out using the photo booth. But I have a few questions.
1. Why do you have to put paper over the lights?
2. What does the differant color background paper do?
ke1stcav wrote:I can see how nice the pictures came out using the photo booth. But I have a few questions.
The paper diffuses the light making them appear less harsh on the subject and different backgrounds for different coloured subjects to show them properly :cheers2:
RobBye
Post by RobBye »
Nice work Paul.
My Scale Modelling Blog: https://armourinscale.wordpress.com
TheSmoo
Post by TheSmoo »
I wish I had the room for a lightbox like that, top job Paul
TheSmoo wrote:I wish I had the room for a lightbox like that, top job Paul
Cheers, I've changed it a little since then its now a little taller and i tend to use the black background more now :cheers2:
ladip63
Post by ladip63 »
Nice build Paul. I'm going to have to make me one.
Lynn
Metal Earth R2D2
Les
Post by Les »
A nice design with great results! Thanks for a look at it. :banana:
Maverik
Post by Maverik »
Nice work Paul this hobby just gets better all the time I will try nd make one myself to
Angelo
On The Bench
HASEGAWA F15A EAGLE AIR NATIONAL GUARD /
Maverik
Post by Maverik »
Paul do you need the two lights or an you get away with one
Angelo
On The Bench
Maverik wrote:Paul do you need the two lights or an you get away with one
I thin two is needed, i may even add a third at the front :cheers2:
Maverik
Post by Maverik »
Ok no worries I'll take your advice cheers Paul
Angelo
On The Bench
burnie43
Post by burnie43 »
That's great Paul
I had bought one of that CHEAP portable photo booths but it was crap...and dangerous , the lights almost melted.!!
I think having the right camera really helps though...or is that just my excuse for rubbish photos
cheers for the tips
Mark
[/color]
[/b]
spock1701
Post by spock1701 »
Great looking booth there. Have to get me one of those. My photography needs a boost.
chalkyw
Post by chalkyw »
DIY or not that looks like a pro set up......you should start selling those mate, they'd fly out the door I'm sure :th:
kprice52001
Post by kprice52001 »
I love it, You have inspired me! I have $8.00 in my pocket that's burning a hole in my pocket. Thanks for the great Idea!
If it ain't rainin, you ain't trainin!
