Oil/Enamel washes for aircraft
portonion
Post by portonion »
Hi dudes/dudettes.
I'm normally an armour builder, but I'm giving winged things a go, but I'm a bit stumped for pin washing.
Do you guys wash the rivets as well as panel lines?
Re: Oil/Enamel washes for aircraft
Same stuff as your Armour stuff.... either home made using artist oils diluted with Turpentine or white spirit of your choice to the right consistency... and apply as per normal! or go with pre-made stuff of a complementary colour to your camouflage or base coat !
make sure your work is protected under a good quality Acrylic Clear Coat !
but you just need to match the Aircraft color scheme...
Happy modelling ! :cheers2:
Ultimate Modelling Washes are great fro aircraft (and armour) easy to use and quick too, check out our website www.umpretail.com
Maverik
Post by Maverik »
Hi can you use normal turpintine or dose it have to be the oddourless one and was that acrylic for the clear coat or are they all acrylic
Angelo
On The Bench
HASEGAWA F15A EAGLE AIR NATIONAL GUARD /
Maverik
Post by Maverik »
I do want to get the ultimate wash to paul but i like to try other stuff to
Angelo
On The Bench
Return to “Weathering”
