Tamiya 1/72 A6M2b Zero Fighter
Aliktren
Mauritius
Post by Aliktren »
Hi Gang
so this was my crack at doing this kit :-
The special edition is basically extra decals, which will be a good excuse for me to make another in the future as this is an awesome kit that almost falls together allowing you to get on with the fun part of painting. I used Eduard Canopy mask set which is very tiny and fiddly but better than what I could have done otherwise.
All painted with Tamiya Paints except the prop where I used AK true metal, Ultimate Dark Dirt for the panel wash, which I kinda messed up as I didnt get enough of a gloss finish in some places which caused some bleed, used some AK engine wash and oils for some minor weathering. The model got knocked off the shelf by some building work we had done and snapped the undercarriage and a couple of smaller parts vanished into the carpet and then I couldnt get the aerial line to glue so figured fate was trying to tell me something and called it done :) - highly highly recommend this kit, and will be buying another if I see one at a good price to try and improve.
base is from coastal kits and a painted picture frame.
thanks for looking :) :th:
Metodi
Re: Tamiya 1/72 A6M2b Zero Fighter
Post by Metodi »
Great looking Zero, good job.
TommyKillander
Post by TommyKillander »
This is a great build of a beautiful aircraft, well done :thumb2:
Weathering looks great. Those panellines are amazing- so thin but they really pop out nicely.
Dio is awesome. Great theme
Homerlovesbeer
Post by Homerlovesbeer »
Yep beautiful job....perfect weathering.
Aliktren
Mauritius
Post by Aliktren »
thanks fellas
Goligod
Post by Goligod »
:th: Awesome little Zero you have there! :th:
Yours Truly,
Goligod
