Fv107 Scimitar
DJs
Fv107 Scimitar
Post by DJs »
My first topic (it will be a bit long because the build is finished and is now waiting in the spaybooth)
Part1
The FV107 Scimitar, will be build in a Belgium version
The kit is from AFV and will be upgraded with PE from Eduard N°35633 and the tracks will be replaced with Friul ones
Started on the Friul Tracks
2 drills and 2 days further the Friul tracks for the Scimitar are ready
Dryfit off the running wheels, sprocket and Friul tracks
Pe added on the right side off the hull
PE grill mounted after the underground was painted black.
New lit made for the left tool box because the original was damaged
PE Installed on the left side off the hull
Close up from the jerrycan PE holder and belt
Drivers Periscoop with wipers in PE and also the barrel holder
Dryfit off the grid, the turret is just put on to see if it can pass over it.
The PE toolboxes that will go on the turret are bended and soldered
The box that will go on the back of the hull is fitted with PE hooks and i put a heated copper wire true the cover that imitate the original elastic
More detail work on the turret
Front Mud flaps
Right side, here you can see that the rear mud flaps are folded.
Close up folded mud flaps
Nice detail off the barrel
Build 100% finished
So thats it for the build, hope you guys like it
Workbench: Abrams M1A2 Sep & FV107 Scimitar
Waiting: Merkava Mk3 Baz with Mineroller
Fb page : DJs Scalemodelling
Re: Fv107 Scimitar
Very nice work, great idea for the elastic!
arkbuilder2012
Re: Fv107 Scimitar
Post by arkbuilder2012 »
Terrific work with the PE. Really takes this build to the next level. Looking forward to seeing it under paint.
