Problems with "New Posts"
Suggestions for the forum, share any ideas you may think would improve the forum
peppie
Post by peppie »
Hi guys,
Since a couple off weeks I'm having problems with getting New Posts.
Normally I would select New Posts at the Quick Links on the top left, which would give me only the new posts (duh). Now since a couple off weeks I'm getting like 26 pages :wtf: when I select this, and when I look to the dates there are maybe 6 or 7 pages new (I check almost every day) and the rest is older.
Am I doing something wrong or is there a problem with this "button". :think:
Thanks :th:
Peter
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
Re: Problems with "New Posts"
Can't help you with the new posts but have you tried unread posts instead? I check it every day, respond or not as the case may be to any I'm interested in then go to 'clear forums' on the main page when I'm done. You don't miss a post in any of the sub sections that way.
Yeah its doing it to me too, but you can see where you were at with unread posts
peppie
Post by peppie »
OK, so it's a website problem.
I'll try your way next time.
Thanks guys. :th:
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
peppie
Post by peppie »
Also, I don't get a notification anymore, when there is a reaction on a topic which I subscribed to.
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
There are some hooky things happening at the moment, which we're trying to sort out :th:
peppie wrote:Also, I don't get a notification anymore, when there is a reaction on a topic which I subscribed to.
Avgas wrote:Can't help you with the new posts but have you tried unread posts instead? I check it every day, respond or not as the case may be to any I'm interested in then go to 'clear forums' on the main page when I'm done. You don't miss a post in any of the sub sections that way.
peppie wrote:Hi guys,
Thanks :th:
Peter
All sorted now guys :th:
peppie
Post by peppie »
Yep, just got a notification on this topic :cheers2:
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
peppie
Post by peppie »
Hi guys,
It's happening again, got 9 pages now. :scratch::
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
peppie
Post by peppie »
Nobody else have this problem?
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
Not I.
andygif290368
Post by andygif290368 »
Yes, it does it a lot especially if you use multiple devices.
Clear the site cookies and it should be good for a day or two.
On bench: nothing, it's all hidden so the wife doesn't see it or the cats mess it up!!
Current "Black" projects include: Sci-fi kits and 1:35 tanks.
It's never been fixed for me.
I have to sign in everytime I visit the forum on my iPad, and I haven't received a notification of any posts in months. I've never changed any settings. They're the same as when I first joined the forum.
For months now I've had to manually check unread posts and scroll through the notification tab to see what's going on here.
I gave up ages ago trying to figure it out.
I'm used to it now, so it doesn't bother me.... Except of rthe signing in every time.
Its just the forum and how it works, its not the end of the world guys.
peppie
Post by peppie »
Paul wrote:Its just the forum and how it works, its not the end of the world guys.
No, it's not.
But this only started like a week ago, and also happened in the past. Then it was solved in some way.
Lee wrote:All sorted now guys :th:
Just wondering if it could be solved again.
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
No, it's not.
Maybe with a forum update, its takes a fair bit of work and money to keep this place going and with personal lives too it is a lot of work.
Sorted :th:
Return to “Site Feedback & Suggestions”
