canopy question
ToddS
canopy question
Post by ToddS »
Hey guys
I be looking at pica for the up coming build. I notice that the rear portion of the canopy on the tigermeet bird is tinted.
Here is the question: How do I tint it?
Any help much appreciated :cheers2:
Navcom
Re: canopy question
Post by Navcom »
Which model kit are you using?
Jeff
My scale model photography book...
http://www.scalephotography.com
MN Scale Modeler Virtual Museum
http://www.mnscalemodeler.net
Re: canopy question
Tamiya smoke airbrushed in very high coats will work
ToddS
Re: canopy question
Post by ToddS »
Building the Rebelled 1/72 2009 Tigermeet bird.
Never thought about airbrushing! Airbrush the inside of the canopy to preserve finish from masking?
Re: canopy question
I have heard that tinting Klear works just putting a couple of drops of paint in some klear and dip your canopy in.
sheppy
Re: canopy question
Post by sheppy »
Alclad 2 do a tinted canopy paint
ToddS
Re: canopy question
Post by ToddS »
Dug thru my spares box. Found some old clear parts. Will try a couple of things and post results with actions taken..
Thanks for the suggestions and feed back. Now, come on 1-1-16
ToddS
Re: canopy question
Post by ToddS »
Morinin folks,
Well I spent several hours yesterday playing with the clear tint thing. Tried coloring Klear, not the best results! As I was building up layers, to darken the color shade, it began to leave waves that could be seen. I am thinking that it was either, A) I should have waited maybe a day between applications, or B) Just not the best approach.
I then tried mixing up an oil wash. This MIGHT work, but, I think it would leave a thick coating on the part that would be easily removed by masking or any handling even with several Klear coats after.
I did find a video on YouTube by a guy building an E-6 Intruder, with their colored canopies. He mixed up a VERY VERY thin, mix of Tamiya Copper Metallic XF-6 with a touch of Tamiya Smoke X-19. He thinned this with straight 90% IPA. sprayed it from a fair distance, so as he put it "spray on dry coats to build up the color". I think that is the route I am going to attempt as well. I will post a pic of what I end up with, I still have the original spare canopy I was playing with to use..
