Eduard 1/48 Polikarpov I-16
TomasGould
Post by TomasGould »
Ok guys this will be my first GB ever and my second aircraft build ever....... So I hope I'll handle it :lol:
I chosed the eduard 1/48 Polikarpov for this build just becouse i think its an awesome looking aircraft :)
//Tomas
Mr.T
patrickroos
Re: Eduard 1/48 Polikarpov I-16
Post by patrickroos »
Lycka till!!! :th: :D
In progress:
:pop: Got this in the stash.
TomasGould
patrickroos wrote:Lycka till!!! :th: :D
Tackar :) det kommer behövas :)
Mr.T
TomasGould
Avgas wrote::pop: Got this in the stash.
It looks like a nice little kit :)
Mr.T
TomasGould
Here's some history about the I-16 :)
Mr.T
TommyKillander
Post by TommyKillander »
Good luck with the build! :thumb2:
/Tommy
TomasGould
TommyKillander wrote:Good luck with the build! :thumb2:
/Tommy
Thanx Tommy :)
Mr.T
TomasGould
Started a little bit on the cockpit and dryfitted the fuselage :) I'm waiting for some paints I've ordered
Mr.T
TomasGould
Now the paints have arrived :)
I base painted the cockpit today and i hope i can weather it this weekend :)
Mr.T
TomasGould
For the blue colour i used a mixture of Vallejo 71.008 Pale Blue and 71.001 White. The green colour is a mixture of Tamiya XF-62 OD and XF-2 White
Mr.T
shortCummins
Post by shortCummins »
looking good Tomas
TomasGould
shortCummins wrote:looking good Tomas
Thanks shortCommins :)
Mr.T
martin57
Post by martin57 »
great little kit fancy that one my self , good start . :th:
TommyKillander
Great start, keep up the good work!
Tommy
TomasGould
TommyKillander wrote:Great start, keep up the good work!
Tommy
martin57 wrote:great little kit fancy that one my self , good start . :th:
Thanks Guys :)
Mr.T
TomasGould
i did some detail painting today :) next will be weathering :)
Mr.T
TomasGould
I detail painted little more in the cockpit and gave it a wash and chipping :) next will be seatbelts and some dirt :) I'm pleased so far with the result for bieng the second aircraft ever :)
Mr.T
TomasGould
Seatbelts & dirt is done :)
Mr.T
BaldyBuilderBoy
Post by BaldyBuilderBoy »
Looking good so far mate. Watching this with interest. I almost went for one of these myself,.
In the stash: Revell 1/32 Beaufighter, Airfix 1/48 Lightning, Academy 1/72 Catalina, Academy 1/72 B17F, and THAT Revell Voyager Kit.
TomasGould
BaldyBuilderBoy wrote:Looking good so far mate. Watching this with interest. I almost went for one of these myself,.
Thanks BaldyBuilderBoy :) I think its a great kit, but i don't have so much to compare it with :) lol
Mr.T
TomasGould
Todays work :)
I glued The fuselage halves and painted the engine :)
I also gave the engine a dark wash and a silver drybrush :)
Mr.T
TomasGould
Panel done.... Check
Now time to mount everything in the fuselage :)
Mr.T
loving the look of the cockpit mate
TomasGould
Nige201980 wrote:loving the look of the cockpit mate
Thanx :) Its my second aircraft ever so I think the cockpit turned out ok :)
Mr.T
TomasGould
Today I mounted both the cockpit and wings on the fuselage :)
The only fitting prob was a gap on the underside between wing and fuselage :) But it was easy fixed with some tamiya putty :)
Mr.T
shortCummins
Thomas
dry fit the engine cowling, you may need to alter the fit by either removing part bottom part of the "body" or fill (as I did) the gap between the cowling and fuselage caused because the wings don't fit back far enough
you're doing a cracking job so far, nice little kit isn't it
rgds
John(shortCummins)
TomasGould
shortCummins wrote:Thomas
rgds
John(shortCummins)
Thanks for the advice :) i dryfitted it and it works great :)
I think this is a great kit :)
Mr.T
TomasGould
Now its ready for primer :)
Mr.T
TomasGould
Primed and wet sanded some small imoerfections :)
Tomorrow i will prime it again :)
Mr.T
patrickroos
Great work so far! :th:
After seeing Johns and now this...got to get this kit! :tongue:
:cheers2: :cheers2:
In progress:
TomasGould
patrickroos wrote:Great work so far! :th:
:cheers2: :cheers2:
Thanks Patrick :)
Its a nice little kit :)
Mr.T
TomasGould
A new coat of primer and pre shading done :)
I also decided which markings I will use and it will be Boris Safonovs no 11 :)
Mr.T
TomasGould
The basic painting is done :) The green is a mixture of vallejo model air 71.017 Rusdian green, 71.002 medium yellow and 71.001 white. The blue is a mixture of 71.008 Pale blue and 71.001 White
Mr.T
TomasGould
A clear coat and decals done today :) soon time for weathering :)
Mr.T
TomasGould
Noticed a crack in the canopy but I've talked to eduard and they will send me a new one :)
Mr.T
TomasGould
A wash done.i used artist oils (dark brown) and white spirit.
Next step will be a flat coat :)
Mr.T
TomasGould
Today a flat coat was sprayed and I masked and painted the exhaust outlets :)
I also did some chipping :)
Mr.T
P51dplt
Post by P51dplt »
:th: great detail work!
Simple is better, except when complicated looks really cool.
Sturm
Post by Sturm »
Wonderful!!!!!
TomasGould
Sturm wrote:Wonderful!!!!!
P51dplt wrote::th: great detail work!
Thanks Guys :) I'm glad you liked it :)
I planing to build a nother one in this GB :)
Mr.T
patrickroos
Looks great! :th:
Nice paintwork and the chipping is perfect.
Looking forward to seeing the finished plane.
In progress:
TomasGould
patrickroos wrote:Looks great! :th:
Thanks Patrick :)
I've now mounted the landing gear and painted and weathered the prop :)
Its around 15parts left to mount (9 of them is exhaust pipes)
I hope the new canopy will arrive soon :)
So far i think this is a great kit and couse it was so hard to choose between 2 of the 4 paint schemes I've ordered a nother kit I also will build in this GB :)
Mr.T
Smiffy
Post by Smiffy »
Wonderful looking Polikarpov.
TomasGould
Smiffy wrote:Wonderful looking Polikarpov.
Thanks Matt :)
I've now mounted the exhoust pipes and wires to the landing gear :)
I also drilled out the machinegun barrels and the venturi probe :)
Mr.T
TomasGould
Now is everything ready except for the canopy I'm still waiting for to arrive :)
Conclusion so far :)
Eduards I-16 is a great kit and a real joy to build :)
And for me that only have built one plane before this kit realy opened my eyes for aircraft kits :)
Mr.T
TomasGould
The postman came with the canopy yesterday....... And But I'm 600 miles from home right now....... Lol
Mr.T
TomasGould
Now its finally finished :)
And here is a link to My Final Reveal :)
http://www.intscalemodeller.com/viewtop ... 51&t=16528
Mr.T
