Zvezda GAZ-MM
Novorus
Zvezda GAZ-MM
Post by Novorus »
Well here it is, my entry to the 'Russia with love' group build
The idea is to make a diorama around it, but the end build will be re used in to the 'Storch Down' project in which shows one side of the theory of what happened to Major Reichel on the Eastern front in June 1942.
The sprue are ok nothing much to say either way, neat and tidy :th:
Shouldn't be to hard a build really lets see how it goes. :clap: and see what i can add as well :dance:
James
wappynutter
Re: Zvezda GAZ-MM
Post by wappynutter »
I do like the Soviet Gaz trucks... :thumb2:
Gonna hopefully be a sweet build for you James.
Good luck mate, will be dropping by for a look as you go.
All the best.. :thumb1:
Regards Andy...Image
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Thanks Andy for looking in
Well not much done at the moment due to family commitments but here is the progress so far
The engine really did not go well alot of cleaning and mucking about. :wall: :wall: :oops:
on looking over the kit a little closer there is some major cleaning needed and it really does not look like the easy build i had hoped for. But hoping to put some time in to get this one done as the bench is really filling up with lack of time and mojo suffering :evil:
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Been away from the bench to much as its been the last week of the mother in law's visit. But here is the latest update
Engine is now primed and ready for paint as with the body frame and back of the truck
hoping to spend the day at the bench today
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Well the first coat down on the body and the engine
a little more detail and paint work
work is slow as time on the bench is not what i would call free.... :( :( :( :roll:
James
Re: Zvezda GAZ-MM
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
thanks Avgas
Well hoping to get this finally put together at the bench today finally. This is the first kit I have used an airbrush on and trying some new techniques. Hoping to get some pictures up later.. :tongue: :bash:
James
felisbarcinonensis
Re: Zvezda GAZ-MM
Post by felisbarcinonensis »
Great progress!!! I guess it has involved a lot of cleaning like MiniArt but the final result makes worth all the pain :cheers2:
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Thanks Felis. :th:
I had been quite kind about the amount of flash but as I have gone along with it it has been a bit of a pain, the Zvezda kit is what it is. :ooops:
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
So sometime at the bench, although while multi tasking :bash: :wall:
Suspension and steering rack on completing the under side and engine fitted
Steering looks wrong and is a nightmare to fit together
dry fit rear on to see how it looks
Still not sure on the color looks right but :roll: :? :?
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Well a small update.
Wanted to try some weathering and different ways of getting the effect. So using pigment and decal fix, something i have never done before but managed to get this done.
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Well today been trying to button this up, but the cab and body is a complete nightmere :crazy: :crazy:
want to left the door open to be able to see inside and maybe a little aid to the story line.
But the roof has proved so hard to line up and make fit have to look at giving up and starch build the canvas lid. :wall: :wall: :wall: :bash:
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
frame work done, so no happy at moment with this thing :pistols: :pistols: :pistols:
James
OliveDrab
Re: Zvezda GAZ-MM
Post by OliveDrab »
Keep at it, the canvas roof sounds like a neat idea :th:
Curt :cheers2:
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Thanks for your comments, not going to get to this until middle of next week if luck.... :shifty:
But yer I think it could work out well.
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Finally in the den, now I'm feeling better and tried to get my head around the replacement canvas roof. :tongue: :lol:
not sure, think it's looking ok
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Well got some paint down on it, think it is looking ok but will leave it alone and maybe repaint. the colour is not easy to match :bash: :bash:
bit of touching up to be done as masking tape did to good a job :doh:
James
Icemannique
Re: Zvezda GAZ-MM
Post by Icemannique »
That looks real good so far ! :th:
Jari alias Jerry
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Icemannique wrote:That looks real good so far ! :th:
Thanks mate
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Finally managed some time in the den, after a very busy birthday weekend..
o my god never had a set of wheels like these, what a pig to put together :wall: :wall: :bash:
well with just a few bits and pieces to go may just get the beast together not i will be able to finish the paint work all done today but so close. :crazy: :crazy:
James
Schoof
Re: Zvezda GAZ-MM
Post by Schoof »
Just under 2 weeks left.....
Hope you'll be able to finish in time
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
Yep update soon just as soon as I get to the bench, been very slow but has had some movement will add the pics later.
I'm sure hoping to button this one up real soon, as it was meant to be an easy one. :wall:
James
Novorus
Re: Zvezda GAZ-MM
Post by Novorus »
work play a nightmere out and life keeping me away from the bench. but some more done
muddy pup coming along :roll: :roll:
with only today to go i think I'm close to done
James
