Russian KV "Big" Turret. "From Russia with Love" GB
felisbarcinonensis
Post by felisbarcinonensis »
[youtube]1-YXEuCrFpA[/youtube]
A heavy assault tank with the M-10 152 mm howitzer, the KV-2 was produced at the same time as the KV-1. Due to the size of its heavy turret and gun, the KV-2 was slower and had a much higher profile than the KV-1. Those captured and used by the German Army were known as (Sturm)Panzer kampfwagen KV-II 754(r) and often used for artillery observation due to its height. Few were produced due to its combat ineffectiveness, mainly the decreased speed due to the weight of the new gun and turret. The enlarged turret also offered a much bigger target, resulting in it being easier to hit and destroy than other KV tanks. Due to the increased turret weight due to expanded dimensions and a heavier gun, the turret traverse mechanism could work only on level ground.
I'm going to build this Trumpeter Kit
Looks like an interesting kit and I hope to have loads of fun! Cheers! :cheers2: :cheers2: :cheers2:
MassterOzymandias
Re: Russian KV "Big" Turret. "From Russia with Love" GB
Post by MassterOzymandias »
Excellent choice! Looking forward to see this work.
Greetings!
NAMBiohazard
Post by NAMBiohazard »
I still really want o build one of these....
Looking to forward to seeing yours coming along :pop:
Keep the glue on the Sprue
Bjorn
TommyKillander
Post by TommyKillander »
Great stuff, more KVs :banana:
Great intro and good luck with your build !
Tommy
felisbarcinonensis
Thank you guys!!! :cheers2: :cheers2: :cheers2:
KV "Big Turret" From Russia with Love GB Update 1
[youtube]qxNYSXIpVEc[/youtube]
Pincer Movement
A brand new kit!!!
Crab's famous pincer movement
Suspension (No crabs)
Wheels (Cat)
Wheels are finished
Tracks fitted
Fenders added
Barrel and turret almost ready
A little bit of putty
Almost done...
Ok. ready for the painting phase
:cheers2: KUTGW
That a lot of Armour.... I fear that beast in WoT !!
That gun is devastating.....
See you around !
felisbarcinonensis
schweinhund227 wrote::cheers2: KUTGW
See you around !
Thank you Norm :) Cheers!! :cheers2: :cheers2: :cheers2:
MassterOzymandias
Great build, Felis. I like the Trumpeter's KV family and this kit is nota exception. I will follow the paint and weathering stages because you are an expert in these issues. Keep it up, my friend. Greetings from México.
felisbarcinonensis
MassterOzymandias wrote:Great build, Felis. I like the Trumpeter's KV family and this kit is nota exception. I will follow the paint and weathering stages because you are an expert in these issues. Keep it up, my friend. Greetings from México.
Thank you mate you're too kind! :cheers2: :cheers2: :cheers2:
KV "Big Turret" From Russia with Love GB Update 2
[youtube]_z5f2nvv8Tw[/youtube]
KV "Big Onion"
Surfaces needed a little bit of character
It was primed with black primer
Hull red was airbrushed
After a layer of matt varinsh I added scratches effects fluid
Once dry, I airbrushed it with protective green
I scratched it and fixed the result with varnish
Scratches fluid was airbrushed again...
I used 4BO as base colour and gave it some shines with olive drab shine
I scratched it... again!
Looking good!
Chipping fluid... AGAIN!?
Yes! It's a Russian winter! White camo is needed
I chipped it with water and fixed it
I wanted more drama and added additional fake chipping :)
I enhanced scratches with olive drab shine
I worked with the hull as well
Tracks were painted with Revell iron
Wheel rims were enhanced with iron pigments
Tracks were weathered with tracks wash
Then I gave it a general filter and a pin wash
Happy with the result :)
I also added subtle rust streaks
...and streaking grime on flat surfaces
Exhausts needed rust
This time I went from light to darker
Black soot was fixed
Some final rusty touches
Metal parts were given some shine too on top of that rust
Track rims were enhanced as well
And that's it. On the next update I'll deal with figures
See you on the next update! Chers!! :cheers2: :cheers2: :cheers2:
felisbarcinonensis
"From Russia with Love" GB Update 3
[youtube]_SjfZKllymk[/youtube]
Figures
There we go...
Seams were sanded carefully
That's a job for Mr Putty
Here he comes to the rescue
More filing and sanding
Mr Surfacer offers some help too
They have received their equipment
Impaling has been unavoidable...
Surfaces have been primed
Cenital grey lights have been added too
Uniforms have been painted with this basic combination
Equipment has been painted
That amo can has been painted in black
I've rubbed some metal pigments on it
Shadows and lights have been added
I've dealt with those weapons too
...and used metal pigments again
Weapons have received some Revell iron lights
Finally, they have received a filter and a pin wash
Done... Next step... The diorama
NonProlificModeler
Post by NonProlificModeler »
I love it, Felis! The KV looks so real and - as usual - your figures are fantastic! Superb! :D Jens
Jens
On my bench:
rwsmith14
Post by rwsmith14 »
NICE !!! ..KV-2 looks awesome.. figures look better then the box art !!!!!! WEll Done !! :thumb2: :thumb2: :thumb2:
felisbarcinonensis
Thank you guys!!!! :cheers2: :cheers2: :cheers2:
"From Russia with Love" GB Update 4 & Final Reveal
[youtube]50pcv_-zzcM[/youtube]
The Final Act
Styro-Base
Two levels were created
That's white clay, of course!
Real stones were added
A big tree was palnted
Different soils were mixed
Don't forget to prime that base!
Mud attack
Too much mud, I think I'll water it down a bit...
Mud Fest
No launderettes around :(
Looking good :)
Wheel mud is given lights
...shadows...
Flat surfaces are washed carefully with dust effects
More shadows are added on those wheels
...and some fresh mud joins the party too
More dirt on those flat surfaces
Fuel leaks are added
Dirt is splashed on the rear
Oil, fuel and engine grime is added too on these lower areas
Different mud effects are splashed, but let each layer dry first!
Russian earth pigments, of course
Iron pigment is dabbed on key friction areas
Kursk soil is used as "lights"
...and dark mud is used as shadows
We sharpen those shadows with fresh mud
Some slimy grime effects are included too on the forest area
Looking good!
Some grass is planted
Don't forget to seal those branches!!!
A great duet
Two layers have been needed
The final touch; some wet effects....
FINAL REVEAL: http://www.intscalemodeller.com/viewtop ... 51&t=16757
Last edited by felisbarcinonensis on Sun Feb 28, 2016 7:07 pm, edited 2 times in total.
wappynutter
Post by wappynutter »
:jd: Wow Daniel.... So many products used... but damn the finished results speak volumes... :th:
The KV itself is just superbly done, added to the perfect groundwork and figures and you have created one awesome scene..
I'll nip off and find the final reveal now.. Well done again mate.. :thumb1:
Regards Andy...Image
felisbarcinonensis
wappynutter wrote::jd: Wow Daniel.... So many products used... but damn the finished results speak volumes... :th:
Tnahk you Andy!!! I've just posted the Final reveal. Cheers!!! :cheers2: :cheers2: :cheers2:
NonProlificModeler
Wow! That's great! I love this dio! A stunner! Now I'll watch the vid! :D
Jens
On my bench:
felisbarcinonensis
NonProlificModeler wrote:Wow! That's great! I love this dio! A stunner! Now I'll watch the vid! :D
Thank you buddy!! I'm glad you like it! :cheers2: :cheers2: :cheers2:
