Hobby Boss T26 Model 1938
Chip1942
Post by Chip1942 »
Hi fellas
Its been a while since i posted anything(busy time at work) however things have eased down, so i can get some more time at the bench!
Its a bit late but as soon as i saw this group build i knew i had to join in the fun!
This is the Hobby boss t26 the kit itself is very good and lightyears ahead of the Zvezda the only problems i found was a fit issue with the turret fitting onto the hull and the poorly casted tracks. I added cast texture with the 'Tamiya cement method' as well as a set of fruil tracks, i used a 0.6mm pin vice and 0.5mm brass rod as i find the wire provided to be very flexable. The final modification was using solder to wire ip the turret lights and the front headlight. I will post some painting progress soon(hopefully) :thumb2:
http://wwwplasticmetal.blogspot.co.uk/
In Progress:
Hobby Boss T26 1938
Tiger 1 initial production turret number '121'
Re: Hobby Boss T26 Model 1938
Nice, not seen one of those before.
Chip1942
Post by Chip1942 »
Avgas wrote:Nice, not seen one of those before.
Thanks for the reply
I usually build more 'obscure' subjects such as early German and Russian armour, I must say the T26 has quickly become one of my favourite tanks :o
In Progress:
Hobby Boss T26 1938
Chip1942
Post by Chip1942 »
Now onto the painting, here I'm aiming to achieve a varied(messy) base-coat :banana: , a mess i know, but it will provide an interesting foundation for my whitewash.
:crazy:
In Progress:
Hobby Boss T26 1938
NonProlificModeler
Post by NonProlificModeler »
Cool! "Cute" liitle tank with great details. I'll keep an eye on this build, hehehe! Greetz from Germany. :) Jens
Jens
On my bench:
Chip1942
Post by Chip1942 »
I thought it was cute too :cheers2: thanks for watching :thumb2:
Time for whitewash...
In Progress:
Hobby Boss T26 1938
Chip1942
Post by Chip1942 »
A small yet important update, the washes! :jd:
Next oils :dance:
In Progress:
Hobby Boss T26 1938
OliveDrab
Post by OliveDrab »
Looking Fabulous so far! :th: (This is the first T26 I've seen built) :thumb2:
Curt :cheers2:
Chip1942
Post by Chip1942 »
OliveDrab wrote:Looking Fabulous so far! :th: (This is the first T26 I've seen built) :thumb2:
Thank you :cheers2: i have to say any Russian tank other than t34s and KVs i rarely see on forums, anyhow heres the next update...
Nearly there...
In Progress:
Hobby Boss T26 1938
JimJ
Post by JimJ »
I could NOT build that small, my eyes & fingers would never cooperate, but you have done a superb job..........the detail & weathering are impressive!! :) :)
Chip1942
Post by Chip1942 »
JimJ wrote:I could NOT build that small, my eyes & fingers would never cooperate, but you have done a superb job..........the detail & weathering are impressive!! :) :)
Thank you! I am truly honoured, it certainty felt very small to start with but once I got a 'feel' for it was fine :D
In Progress:
Hobby Boss T26 1938
