Revell 1/24 Jaguar XK SS
polar57
Post by polar57 »
Hello all!
As per usual, i am late for something. And thus i am just joining this fine GB :P
My subject will be Revells 1/24 Jaguar XK SS. I think the moulds on this kit date back to early 90's, but the detail seems pretty nice. There is some flash evident, and it is riddled with ejection pin marks, but time will tell whether they are an problem or not.
Nice pile of plastic :)
Sprue shots
The clear parts were packed separately inside the bag which housed the body of the car.
The tires are really well made! i can't find any seam line and the detail is really crisp!
And the tiny decal paper. they seem a bit thick to me, but we'll see how they will settle down.
The plan
I can only work on this kit on the weekends (atleast most of the weekends) as i am currently in the army i don't have too much spare time. But hopefully i get the Jaguar on its wheels before july :P
That's all for now.
Take it easy!
Ilmari
Workbench is being occupied by:
Eduard Westland Lysander in use of the Finnish airforce 1:48
FineMolds Yokosuka Ohka
Tacoman2000
Re: Revell 1/24 Jaguar XK SS
Post by Tacoman2000 »
Looks like a nice kit. Thank you for your service, even if its not for America. Every military service is respected here.
On the bench: I don't have a bench right now :violin:
I'm not a complete idiot! I have pieces missing.
William
Never seen this car before, looks meaty! Good luck with the build :th:
Late but coming in but very classy
Great choice, looking forward to it :thumb2:
EricM
Post by EricM »
These older jags are my favorites! Cant wait to see how it turns out :thumb2: :pop:
On The Bench
1/72 Finemolds ME410/A-1
Homerlovesbeer
Post by Homerlovesbeer »
Oooo this should be sweet! :pop:
polar57
Post by polar57 »
Hello again!
Thank you all for nice words! :)
i haven't had any real modelling time lately, but fortunately i finally got something done this weekend. So... it is time for...
Update 1
I have done some work on the sub assemblies on the Jag
Rear drivetrain
Engine
Still have to slap some putty on the engine. Everything did not fit too well. Also the exhausts need some removing of the parting line.
Radiator
Intake manifold
Some parts already attached to the body
Steering wheel
Now this being an older Jaguar i wanted to make a wooden steering wheel for it. This is my work process for that.
The shiny part from the box
The steering wheel got some AK3012 light flesh on it
Then i drybrushed quite heavily AK3011 on the wheel
Now for the important step... X-26 clear orange
I have used this method earlier on my 1/6 AK 47
This method is in my opinion really easy and quite fast to get it done. You can change the tone of the finished "wood" finish with the base colour and the amount of drybrushing and the color of the drybrushed paint.
But that is all for this update! :)
Hopefully i can get the next update done in a shorter timeframe :D
Thank you all for coming and taking a look!
Ilmari
polar57 wrote: Steering wheel
This is a fantastic trick, I almost want to buy something with woodgrain details just so I can try it. Looks great!
I agree, will try that flesh down first technique for wood as well
Looks like you are in for a battle with that Revell. I am sure you will turn her into something beautiful
polar57
Post by polar57 »
Hello all!
Thank you guys for the nice words again! :)
I greet you all with a warning. This update is a bit picture heavy.
Update #2
Odd bits
In my opinion, the heat shield for the exhaust needed drilling out.
As you can barely see in this picture, Revell has done quite nice job on the moulding of the heat shield, but we cannot expect the part coming pre drilled from the box now can we :P
Here is the now drilled part fitted on the exhaust.
Talking about the exhaust, (smooth segue) it too needed the drill treatment.
Before
And after. i think that is an improvement.
The dashboard detail is really amazing! Revell has gone through the trouble of moulding in the crisp numbers on the meters!
Dry fitting
Everything fits rather well.
Engine
At first i had planned to build the engine without any modification, but after i had shot the black base for the upcoming polished aluminium i had the bright idea of doing spark plug wiring for the engine. The wires are just stretched sprue.
Painting
Ready to gloss!
Finally! I got to painting some parts.
These assemblies were sprayed with Testors metalizer stainless steel. absolutely beautiful paint to spray, no problems at all. Also it is buffable, as i demostrated on the flat part of the firewall.
Exhausts manifolds got a coat of Testors metalizer burnt metal.
These assemblies were painted with Alclad chrome. also the intake manifold has had a coat of Tamiyas x-19 smoke on it.
And these got some Alclad polished aluminium on them.
All metal paints were basecoated with black, then glossed with Alclads aqua gloss and after the gloss got sprayed with metal paint of choice.
Interior was basecoated with black and then painted with Testors leather. I flocked the floor with Zero Designs charcoal flock.
And here is the Jag a few steps closer getting paint on it :)
But of course i had to mess something up. As i was installing the intake manifold to the engine (i really should have done that earlier) some of the sparkplug wires got ripped away from the engine. But that shouldn't be too big of a problem to fix. Also i have to clean up that paint near the cylinder head cover and the spark plug wires.
But i think that's it for this update. Hopefully i can get painting the car body next weekend.
Hope you all have a great week! See you in the next update!
Ilmari
:jd:
AWESOME!!!!!!
Thanks for all the pictures, you are making a mediocre kit into something great
Look how much better the drilled heat sheild for the exhaust looks, and a bit of wiring and the engine comes alive!
Really impressed :thumb2:
polar57
Post by polar57 »
Update #3
First of all: thank you so much Scott! :)
It is time for an colorful update!
Priming
This was the starting situation. I took the opportunity and primed my Toyota Supra project as well. I cocked up the clearcoating on it the last time, so after a quick sanding it was ready for another round of painting :D
Aaaand primed. I absolutely love the Zeropaints' grey primer.
This was an interesting reaction. The surface was unusually rough. But it just needed a bit of 3600grit sanding and it was fine. Left side of the bonnet is done in this pic.
Painting and clearing
Painted in their base colors. The supra had one more coat of red mica pearl tinter after this pic, but i didn't take a picture of that.
This wire thing worked out really well in painting the Jag :D It was the only solution i would come up with as i had to paint the bottom of the car aswell so i couldn't really put it down in any point. But anyway here is the Jag cleared. Just a bit of orange peel, but nothing terrible.
Speaking of terrible... Proper moonsurface level of orangepeel right here.
The body of the Supra is still saveable with sanding. I am not sure why the Supra ended up so bad after the clearcoat but i am sure i can still polish it up :D
Anyhow. That's it for this update. Thank you all for following my build!
Ilmari
pir8hntr
Post by pir8hntr »
One of my favorite cars in real life and as a kit to build. Great looking work.
pir8hnter
polar57
Post by polar57 »
Update #3.5
Hi guys!
Thank you pir8hnter!
This is just an quick update of the re-clearing.
There are still dust particles in the clear, but some polishing should get rid of it. I think the mixture i was using was wrong the last time. Too much thinner. But now it worked much better! :D
The paint used for the Jag is Zero paints' BRG by the way. And the clear is Zero paints 2K clear. Forgot to say that in the previous update :)
Hopefully i can bring you some more update related stuffs regarding the Jag sometime soon, but this is it for the time.
Have a nice weekend everyone!
Ilmari
Timplastic
UN
Post by Timplastic »
That is some very nice work on the jag. Racing green looks a real nice colour on those jag body's.
Will keep an eye on the progress :th:
