Revell 1/48 Mig-21PF
I may be late to start this GB but I wanted to get in on it. This is my fifth model to start, so I'm looking forwarding to learning a lot as I go through the process. I decided on a Mig-21PF because I've always liked this plane and the local museum has a cockpit cutout from one. Plus some of the planes in the museum shot down Mig-21's.
First thing is first, Box shot!
Sprues, not a lot of detail in this kit; which is a bit disappointing; but, it will give me a lot of practice with paints. Queue some awesome Russian paint in the future!
Started on the cockpit pieces. Again, not much detail for a 1/48; but, this looks to be a closed canopy build so I'm not fretting it too much. And Turquoises! Such a lovely color. Much better than the dull grays and chromate green I'm used to.
Re: Revell 1/48 Mig-21PF
Nice start. Anymore progress made on this?
Gav0909 wrote:Nice start. Anymore progress made on this?
Made a little progress. Finished painting the nose cone and afterburner and nozzle. Glued the two halves together. Started on the wings and realized I hadn't put the cockpit in the plane. Queue me prying the plane apart. Thankfully the glue hadn't set for too long.
Reglued the halves and it came out a bit wonky. As you can see below. I have an idea how to fix it. We shall see what happens. Also, I think I've decided on a paint scheme and weathering options. Any opinions on the Tamiya weathering eye shadow stuff?
Cheers,
A
Well, I spent the better part of yesterday fighting with some plastic. This kit just doesn't want to go together. However, I'm learning a ton on how to fix screw ups and brute force stuff together.
I got the two halves together. This surprisingly was the easiest thing I ended up doing yesterday.
Tail went on with the avionics houseing. The thing was oversized quite a bit and I couldn't get the tail to set properly with the engine nozzle.
So, after cursing a bit and changing netflix over to a new show I started doing that moddeller stuff so many people talk about. Took me a very long time as I'm not very good at this; but, I think this model is starting to atleast look like a Mig-21.
It's hard to see; but, I fixed the connection to be smooth and not oversized.
The entire length of the avionics housing and tail section needed filling. Sooo, yeah.
One day I'll start buying nice kits that don't require house of filling. Another gap to be filled. I think my model might be mostly putty by the end.
Got the wings on; and, you guessed it. Needed more putty and loving.
Well. It atleast looks like a Mig-21. Thud for scale.
I'll be doing a lot more of this build over the next few days. I think I've decided on a paint scheme.
Found out that I should have put weight in the nose cone so the model doesn't sit on its tail.
Sweet. So, I decided that putting weights in the fuel drop tank would work out perfectly. Went out and bought some split shots, super glued them in. Placed the halves together and went to glue on the tail cone. At this point, I became rather confused. There is no possible way that the molds could be that far off, right? Right. I did a bit of research on the shape of tail cones for Mig-21's and my assumptions were correct. Revell had Brad Pitt the bed on this one. Spent about 20 minutes trying to make it work. It won't. There is no way.
Revell 1 - Me 0
So, a bit upset but not down trodden I figured there would be another way to do this. The nose gear bay was open and if I smashed the split shot weights a bit, I could shove them in. They should rest nicely in the nose cone. No problem. Just dab a bit of super glue in there, and you'll be fine, right? Right.
The plan started out great. Smashed maybe eight of the little weights dropped them in the gear bay and they fell into the nose cone. Awesome, maybe Revell ain't so bad after all, you know, for having so few details that I can correct gross mistakes via their lack of engineering. Now comes time for the super glue. I drop in a few drops. Rotate the model and do a few more, you know to get it all in there.... Then I feel something wet. And oddly warm. What the? (expletive deleted)! The super glue was running around the nose cone and onto my hand. Not good. First thing first, I grabbed a paper towel for my hand, not really thinking and watch the model drip super glue on the floor.
Revell 2 - Me 0
At this point I wiped the floor quickly, and wiped my gluing hand on the paper towel and it comes back all papery and very slightly gummy. Dammit. So the bright part of me said, "hey, you should rub your fingers together and the left over paper towel will come off.
Revell 3 - Me 0
Nope. I as a 26 year old male had-for the first time in my life-glued not just two but three of my fingers together with super glue. Terrific. So I spend the next 30 minutes trying to pry and pick off the super glue. Then I google searched and figured out that acetone will cut super glue. Awesome. I did that and cleaned up myself and the floor.
I also think my canopy is fogged a bit.
Revell 4 - Me 0
The nose cone looks bad for the glue. I don't know if I'll respray it, or just roll with it. Could be a good conversation topic, "Hey, why is the nose cone all funky looking." "Oh, that's from the time I tried to shower with super glue and glued myself together. Great times! AHahaha." Yeah. I did get the missiles glued together; but, I don't know if I'm going to keep them around. Depends on how they come out looking painted.
Anyways, I snapped some pictures in the aftermath as my hands were a bit occupied while this transpired.
Best solution at the time.
The damage to my lovely nose cone. I may just sand it and re spray it...
Thanks for reading. Comments, suggestions and critiques are always welcome.
NonProlificModeler
Post by NonProlificModeler »
Mate, this kit is really giving you a hard time! Added to that you're not too experienced yet, are you. I guess you will still master this build though. Built my first plane in 1976 (1/72) and most kits were like yours is, but in my opinion you can learn so much by building a poor kit and improve your skills. You still got two months to go. Try to stay calm and patient and you'll do it! All the best and greetz from Germany. :) Jens
Jens
On my bench:
Howdy!
Primed the Mig and found a couple of errors from the great glue tour de force. Namely some glue that ran down the nose and under its chin.
Sanded down the primer and mistakes and reshot the primer. Ended up looking much better.
Also shot all the gear doors and stuff on the sprue. I think my paint mixing skills are quite bad when it comes to white paint. I don't know what the problem is.
I'll wait for the gear stuff to dry and I'll start on the masking and painting. Yes. I didn't paint the nose gear bay... :doh:
Eh, forgot to post the picture of my mistake, lol.
Howdy,
Got around to thinking I should paint the bottom. According to internet pictures the gear bays are painted that blue color. So the white was a bit over kill. Meh, it will make painting the bottom easier.
So to start things off, the bottom coat sans preshading!
Yup, got to this point. Said to myself, "Shouldn't there be lines or something?" Then I remembered that preshading is a thing. A thing I happened to forget to do not only on this model; but, also the last model I painted. I'll learn one day.
Shaded the bottom, pretty easy.
Then came the top. Also, not bad.
Finally, queue me not being able to get a good mix of paint/thinner. This actually got be a bit frustrated. The first blue I shot we mixed perfectly. When trying to apply after the preshading, I just couldn't get the ratio right. Eventually I think I got a good consistency; but, by that point I'd covered the bottom in a couple of really soupy layers. Also, being afraid for color continuity I kind over did a once over the whole bottom again. This seems to nearly have negated all of the preshading I did on the underside. Lesson learned. Also, I need to find a good airbrush cleaner. Ultimate is still back ordered here in the USA.
Comments, suggestions and concerns are always welcome.
Howdy,
Scraped myself together and decided to work on the Mig-21 today. I spent a good four hours yesterday finally getting decals on another project I was working on. By the way, The Wonder Years is a hilarious TV show. Anyways, Taped off the whole bottom of the Mig. The shot doesn't show it; but, I did remember to paint the front part of the RWR? thing. Ha, Revell, take that! Also, writing out what I need to accomplish for the day or project really helps me out. I make lists for normal work and life things, I'm surprised I took this long to apply it to this hobby.
Went with a desert theme. Wanted to see how these colors came together. Plus, I was drooling over some pictures of a IAF Kfir and it was painted sort of like this. Paint went on wayyyy easier than earlier. The mix paint/thinner in a something other than the airbrush worked very well. Helped me out a ton. It's life changing. Tomorrow will be a very big clear coat day. Both sealing in the Thud and the Mig. Or I'll go shooting, haven't figured it out yet. I'm still having problems with spraying white paint. Mixed in a cup today and still got a really spitty spray. I think the
I'm very happy with how it came out. I think in the future I will do actual planning on how the camo/paint scheme will work out. I just came up with this as I went along. I would really like to find a desert or suppressed decal kit for Russian markings. Buuuutttt, I don't really want to wait on the mailman to bring it. Yeah, this might be the wrong hobby for impatience, lol!
I'm also very excited to finish my other project; a F-105D. I've been putting the F-105 off because I really wanted to do it justice. I've read this book now twice in the last month or so about F-105's flying as wild weasels in Vietnam. The Hunter Killers by Dan Hampton is the book. I highly recommend it! The Thud was the third model I started and the Mig is the fifth (I think.) They'll make a really cool Vietnam era pair. :D Plus, this Mig is my first group build. Anyways, I'm really glad everything went so well airbrushing today. I had been getting pretty frustrated with the Mig. It just didn't want to go together. Oh well, live and learn ¯\_(ツ)_/¯ I haven't looked at the decals other than verifying that they're Russian. Hopefully they have some detail to them. The F-105 is also a Revell kit and it had really good stuff.
Comments, suggestions, concerns and critiques are always welcome. I'm new to this hobby so any help is appreciated!
Got to admire your tenacity! Looking good so far and if it's any consolation lots of folk have trouble ( me included) getting a good white paint finish.
Avgas wrote:Got to admire your tenacity! Looking good so far and if it's any consolation lots of folk have trouble ( me included) getting a good white paint finish.
White paint is quite literally my White Whale. Lol. My English teacher would be proud... The F-105 I mixed some grays and white together, airbrushed amazingly well. The straight white is one of the universes great mysteries. Alas, a newbro at modelling is a newbro. One day I'll crack the white to thinner mix, cook a perfect steak, get married and become a fighter pilot. Oddly, only one of those things is in my future.
Cheers!
So this newbro modeller forgot to take pictures. Anyways, clear coated just about everything and painted the wheels. Tomorrow will either be decals or drinking in town. I'm leaning towards a party to end the world. Or... Start to put on the final touches on the Mig.
Little song about the Mig-21 to make up for my lack of photo documentation.
[youtube]Rx2Fs4AYrBs[/youtube]
I'm finished. Well, I still have to take pictures. Tried taking some picture on top of my mailbox today (for the natural lighting) and had a wee bit of an accident. I'll try to get some this weekend.
Finally finished and had good photographing weather to boot. The seam on the nose is a bit, how would you say it, noticeable. I've chalked it up to learning both how to fill seams, and to not buy kits from 1977. The gap in the dash is way worse than I thought it was going to be. Oh well, I have a plan for the next dash that comes out like that.
I'll post a lot more pictures in the Final Reveal thread for this one. Cheers!
Comments, concerns, critique and pointers are always welcome!
Willem
Post by Willem »
You overcame a lot of problems to get a great result bud. Nice one. Like the sense of humour in the thread too.
I've not read the F-105 book you mentioned so I'll look for it. Recently read Ken Bell's '100 Missions North' and of course Jack Broughton's 'Going Downtown. Great reads.
Will
Edward R Murrow
