Help with paint needed
gaz45
Post by gaz45 »
Hi all I have a mellenium falcon from bandai and all the instructions are in japanese this is not a problem with the build but the color callout is if anyone as built this could you help with the paints used
Many many thanks
Re: Help with paint needed
Here's a color guide from (I think) the Fine Molds, which I mean, the Falcon is the Falcon no matter the manufacturer:
The color call-outs are listed by column, so if you want Sandy Yellow (on the top right hand side) you can use (from left to right) Tamiya XF-60, Mr. Hobby Aqueous H-79, or GSI/Creos 39 (someone correct me on the Creos/Hobby/Color brand names if I got them wrong--I tend to mix them up).
So what this does is give you three brands and their versions of the color plus an English name.
gaz45
Post by gaz45 »
Cheers mate thanks for your help
