Cleaning Dried TET From Plastic
Post by Joe »
Hey Guys,
The TET is working as it should but I wonder how I can clean off the residue from around joints and seams. I typically build 1/72 scale aircraft where panel lines/rivets are usually very close to where I maybe joining wings to the fuselage. I invariable wind up with TET covering some rivets or get some small blotches on the plastic. Is there any other way to remove dried TET from styrene other than sanding?
Re: Cleaning Dried TET From Plastic
Use the green then white side on the Ultimate buffer and that will remove all the glue marks without removing detail
http://www.umpretail.com/collections/bu ... riple-pack
If you're trying to clean it out of really close in detail then a fibre glass pen might be a solution. That's what I use. The larger sanders and buffers have a hard time getting in there.
I got mine here...
But you can find them on eBay and the American Amazon as well.
Post by Joe »
Thanks Paul and Coen!
I like the looks of the pen, I think it will be most useful in this case. And since I am probably due for new sanders, I will check out the Ultimate line of sanders.
Thanks Gents!
Coen wrote:If you're trying to clean it out of really close in detail then a fibre glass pen might be a solution. That's what I use. The larger sanders and buffers have a hard time getting in there.
I got mine here...
Is there a problem with the fibre's getting stuck in fingers ?
I've been using mine for a couple of years and I've never even seen a fibre come loose.
I wouldn't stick my face up close to it while I'm using it, probably not wise.
Works great for roughing up paint or weathering/fading panels as well.
Coen wrote:I've been using mine for a couple of years and I've never even seen a fibre come loose.
Thanks for that.
I have another question. I have been trying to find aftermarket rifling and doesn't seem to be any available. Do you have any sure fire techniques for home manufacturing such an item.I'll start another thread. :th:
Rifling?
As in rifling of a barrel?
yes that's it, sorry I was a little obtuse
