WIP Meng TS-010 BMPT Terminator
Ether
Russia
Post by Ether »
Hi everyone.
I've recently returned in scale modeling and want to show some photos of my progress in building the first kit, Meng kit BMPT Terminator. Used the camera of a mobile, so the quality of the photos isn't good enough. Sorry for it.
I've almost completed building the body, just need to add some pieces on the rear side. Wheels, tracks, and additional side armor shields are done too. As you can use, I had to use putty to fill gaps between some pieces, but it wasn't a big problem. After sanding applied with an airbrush the tiny layer of Tamiya liquid primer and everything is looking pretty good. At least, I hope so.
Right now I'm in the middle of building the tower and have met more problems with gaps between pieces. That is surprising for me because everyone says that Meng kits have super high quality. However, I don't think it will be hard to fill and sand these gaps.
I have some experience with glueing kits but can't say the same about my painting skills, so hope you will find some time for helping me. I'm going to use the following painting scheme:
I've already bought appropriate Vallejo paints and Mig washes for sand and brown vehicles. Do you have any advice about filters which I might use?
Also, I have doubts about how to paint tracks. They are made from dark plastic and workable. What should I do with them in order to make them look more realistic?
Thank you for your attention.
PS Will post more photos asap.
mincemeat
Re: WIP Meng TS-010 BMPT Terminator
Post by mincemeat »
Looking good so far! I'm not an accomplished AFV builder, but as far as your tracks go, take a look into Ammo by Mig for "Dark Tracks". I think that would be a good color, but I'm not 100% on that. I'll be using that for the first time when I build my Mk A Whippet.
I take all my model pictures on my phone!
Current Builds
Nice work so far
I have build one myself and it is a nice kit to build
As for the filters , you don't have to use one if you don't want
Filters are good for a used vehicle to make certain parts look older or replaced
This vehicle is brand new and is for a expo so it is hardly used at all
Bit if you do eant to use them a orange brown or light brown filter could work
Ether
Russia
Post by Ether »
MarkVerploeg, I think about using a filter due to flatting and shading differences between the colours of the camo. Otherwise, it will be too bright. I might be wrong, so need to see results after airbrushing.
mincemeat, my LHS don't have a huge variety of Ammo, so I prefer to use Tamiya or Vallejo. Will try to find analogues or just mix Tamiya brown, black and nato black paints. Think that the result will be rather good.
