Eduard MiG 21PF **Reveal**
Joesdad
Post by Joesdad »
The Mikoyan-Gurevich MiG-21 (Russian: Микоян и Гуревич МиГ-21; NATO reporting name: Fishbed) is a supersonic jet fighter aircraft, designed by the Mikoyan-Gurevich Design Bureau in the Soviet Union. It was popularly nicknamed "Balalaika", from the aircraft's planform-view resemblance to the Russian stringed musical instrument or ołówek (English: pencil) by Polish pilots due to the shape of its fuselage.
Early versions are considered second-generation jet fighters, while later versions are considered to be third-generation jet fighters. Approximately 60 countries over four continents have flown the MiG-21, and it still serves many nations a half-century after its maiden flight. The fighter made aviation records. At least by name, it is the most-produced supersonic jet aircraft in aviation history and the most-produced combat aircraft since the Korean War, and it was previously the longest production run of a combat aircraft (now exceeded by both the Boeing F-15 and Lockheed-Martin F-16)
The MiG-21 was the first successful Soviet aircraft combining fighter and interceptor characteristics in a single aircraft. It was a lightweight fighter, achieving Mach 2 with a relatively low-powered afterburning turbojet, and is thus comparable to the American Lockheed F-104 Starfighter and Northrop F-5 Freedom Fighter and the French Dassault Mirage III. Its basic layout was used for numerous other Soviet designs; delta-winged aircraft included Su-9 interceptor and the fast E-150 prototype from MiG bureau while the mass-produced successful front fighter Su-7 and Mikoyan's I-75 experimental interceptor combined a similar fuselage shape with swept-back wings. However, the characteristic layout with the shock cone and front air intake did not see widespread use outside the USSR and finally proved to have limited development potential, mainly because of the very small space available for the radar.
Like many aircraft designed as interceptors, the MiG-21 had a short range. This was not helped by the poor placement of the fuel tanks, which caused the airplane's center of gravity to shift rearwards once two-thirds of the fuel had been used. This had the effect of making the plane statically unstable to the point of being uncontrollable, resulting in an endurance of only 45 minutes in clean condition. Additionally when more than half the fuel was used up, violent maneuveurs prevented fuel from flowing into the engine, thereby causing it to shutdown midflight. The issue of the short endurance and low fuel capacity of the MiG-21F, PF, PFM, S/SM and M/MF variants—though each had a somewhat greater fuel capacity than its predecessor—led to the development of the MT and SMT variants. These had a range increase of 250 km (155 mi) compared to the MiG-21SM, but at the cost of worsening all other performance figures (such as a lower service ceiling and slower time to altitude).
The delta wing, while excellent for a fast-climbing interceptor, meant any form of turning combat led to a rapid loss of speed. However, the light loading of the aircraft could mean that a climb rate of 235 m/s (46,250 ft/min) was possible with a combat-loaded MiG-21bis, not far short of the performance of the later F-16A. Given a skilled pilot and capable missiles, it could give a good account of itself against contemporary fighters. Its G-limits were increased from +7Gs in initial variants to +8.5Gs in the latest variants. It was replaced by the newer variable-geometry MiG-23 and MiG-27 for ground support duties. However, not until the MiG-29 would the Soviet Union ultimately replace the MiG-21 as a maneuvering dogfighter to counter new American air superiority types.
The MiG-21 was exported widely and continues to be used. The aircraft's simple controls, engine, weapons, and avionics were typical of Soviet-era military designs. The use of a tail with the delta wing aids stability and control at the extremes of the flight envelope, enhancing safety for lower-skilled pilots; this in turn enhanced its marketability in exports to developing countries with limited training programs and restricted pilot pools. While technologically inferior to the more advanced fighters it often faced, low production and maintenance costs made it a favorite of nations buying Eastern Bloc military hardware. Several Russian, Israeli and Romanian firms have begun to offer upgrade packages to MiG-21 operators, designed to bring the aircraft up to a modern standard, with greatly upgraded avionics and armaments.
The MiG-21 has a delta wing. The sweep angle on the leading edge is 57° with a TsAGI S-12 airfoil. The angle of incidence is 0° while the dihedral angle is −2°. On the trailing edge there are ailerons with an area of 1.18 m², and flaps with an area of 1.87 m². In front of the ailerons there are small wing fences.
The fuselage is semi-monocoque with an elliptical profile and a maximum width of 1.24 m (4 ft 1 in). The air flow to the engine is regulated by an inlet cone in the air intake. On early model MiG-21s, the cone has three positions. For speeds up to Mach 1.5 the cone is fully retracted to the maximum aft position. For speeds between Mach 1.5 and Mach 1.9 the cone moves to the middle position. For speeds higher than Mach 1.9 the cone moves to the maximum forward position. On the later model MiG-21PF, the intake cone moves to a position based on the actual speed. The cone position for a given speed is calculated by the UVD-2M system using air pressures from in front and behind the compressor of the engine. On both sides of the nose there are gills to supply the engine with more air while on the ground and during takeoff. In the first variant of the MiG-21, the pitot tube is attached to the bottom of the nose. After the MiG-21P variant, this tube is attached to the top of the air intake.
The cabin is pressurized and air conditioned. On variants prior to the MiG-21PFM, the cabin canopy is hinged at the front. When ejecting, the SK-1 ejection seat connects with the canopy to make a capsule that encloses the pilot. The capsule protects the pilot from the high-speed airflow encountered during high-speed ejections. After ejection, the capsule opens to allow the pilot to parachute to the ground. However, ejecting at low altitudes can cause the canopy to take too long to separate, sometimes having resulted in the death of the pilot. Starting from the MiG-21PFM, the canopy is hinged on the right side of the cockpit.
On the under side of the aircraft there are three air brakes, two at the front and one at the back. The front air brakes have an area of 0.76 m², and a deflection angle of 35°. The back air brake has an area of 0.46 m² and a deflection angle of 40°. The back air brake is blocked if the airplane carries an external fuel tank. Behind the air brakes are the bays for the main landing gear. Also on the under side of the airplane, just behind the trailing edge of the wing are attachment points for two JATO rockets. The front section of the fuselage ends at former #28. The back section of the fuselage starts at former #28a and is removable for engine maintenance.
The empennage of the MiG-21 consists of a vertical stabilizer, a stabilator and a small fin on the bottom of the tail to improve yaw control. The vertical stabilizer has a sweep angle of 60° and an area of 5.32 m² (on earlier version 3.8 m²) and a rudder. The stabilator has a sweep angle of 57°, an area of 3.94 m² and a span of 2.6 m.
The MiG-21 uses a tricycle type undercarriage. On most variants the main landing gear uses tires that are 800 mm in diameter and 200 mm in width. Only the MiG-21F variants use tires with the size 660x200 mm. The wheels of the main landing gear retract into the fuselage after rotating 87° and the shock absorbers retract into the wing. The nose gear retracts forward into the fuselage under the radar.
MiG-21PF (1961; Izdeliye 76; NATO "Fishbed-D")
P = Perekhvatchik ("Interceptor")
F = Forsirovannyy ("Uprated")
Production version of the all-weather interceptor. These were powered by the R11F2-300 turbojet and, starting with the seventh production batch, fitted with the RP-21 radar (the first six batches used the older TsD-30T radar (aka RP-9-21). Further, the weapons control system was modified from that of the F-13 to allow use of the RS-2US (aka K-5MS) beam-riding AAM in addition to the IR-seeking K-13.
Mig 21 PF
Version for export to Warsaw Pact countries; only difference from domestic version was the IFF equipment.
702nd UAP
Chernigov Air Base
Soviet Union
Circa 1980
Tim (Ted)
British Aviation In Scale
Icemannique
Re: Eduard MiG 21PF **Reveal**
Post by Icemannique »
Awesome build with a lot of information from Mig-21. Nice ! :thumb2:
Jari alias Jerry
Joesdad
Post by Joesdad »
Icemannique wrote:Awesome build with a lot of information from Mig-21. Nice ! :thumb2:
Cheers Ice :th:
Tim (Ted)
Great build, paintwork is very subtle, I like it. Also a great way to break up the information putting it between the pics like that. I feel like I know everything about that aircraft now!
newpapajack
Post by newpapajack »
Beautiful paintwork, love it, stunning detail :thumb1:
Jack :cheers2:
In progress -
1/72 Revell B-17F 'Memphis Belle' - detailing interior
1/72 Airfix Ki-46 II 'Dinah' - Eye Spy Sig - scribing, riveting and detailing
1/72 Airfix Bristol Blenheim mk.1 - complete, creating vignette
1/72 Academy Focke-Wulf 190A-8 - building
Portfolio - http://intscalemodeller.com/viewtopic.php?f=69&t=12581
wappynutter
Post by wappynutter »
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
Looks awesome Tim, well done.. Top notch paint job and weathering!..
:bow:: :bow:: :bow:: :bow:: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
All the best mate.. :thumb1:
Regards Andy...Image
rodrant
Post by rodrant »
Just love every single detail on this Build ! Love the cockpit , love the camo , love the paint job , love the weathering and what you did on the exaust !
It is really an awesome build that you have here my friend ! It's so good ! :th:
Cheers ,
António
a lot of stuff right now :-)
Joesdad
Post by Joesdad »
Avgas wrote:Great build, paintwork is very subtle, I like it. Also a great way to break up the information putting it between the pics like that. I feel like I know everything about that aircraft now!
Cheers Dave :th: you know what photobucket is like, at any moment I could have lost the post :o
newpapajack wrote:Beautiful paintwork, love it, stunning detail :thumb1:
Thanks Jack :thumb1:
wappynutter wrote::clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
:crazy: steady on Andy!
Much appreciated mate :shifty:
Tim (Ted)
Joesdad
Post by Joesdad »
rodrant wrote:Just love every single detail on this Build ! Love the cockpit , love the camo , love the paint job , love the weathering and what you did on the exaust !
Wow Antonio :eeek: kind words indeed.
I might go back and flatten down the exhaust a bit, it seems to shiny. I'm rapidly going off PE though mate, on the next kit I do I might try out a resin seat or something like that.
Thanks Tony :th:
Tim (Ted)
OliveDrab
Post by OliveDrab »
WOW, what a spectacular build! That's one very awesome jet fighter :bow:: :bow::
Curt :cheers2:
Willem
Post by Willem »
Great job mate. Love that camo scheme.
Will
Edward R Murrow
Joesdad
Post by Joesdad »
Willem wrote:Great job mate. Love that camo scheme.
Ta Will
It might the last one I do using masking, I'm going to try freehand next time. Tamiya bendy tape isn't as bendy as it makes out..
Tim (Ted)
rwsmith14
Post by rwsmith14 »
That is Nice ! !!!
shortCummins
Post by shortCummins »
:jd: top job :th:
Absolutely stunning finish!
Wow!
I call that nailed dude. Wonderful work. :thumb1: :thumb1: :thumb1:
Willem
Post by Willem »
Ta Will
Yup. Having the same problems with the tamiya bendy stuff.
Will
Edward R Murrow
Joesdad
Post by Joesdad »
Coen wrote:Absolutely stunning finish!
Wow!
My God!! :banana: very kind your Lordshipfulness *doffs cap* thank you. I thought I'd buggered it with the matte cote, but I think I got away with it.
Cheers Mike
Willem wrote:
Ta Will
It's got it's place Will I guess. When I find that place I'll dig it out of the cupboard.
Tim (Ted)
TommyKillander
Post by TommyKillander »
Amazing paintwork with a wonderful cammo scheme :th: :clap: :clap:
I love the detailed work with the cockpit :thumb2:
Congrats to a great build and an awesome result.
Tommy
Joesdad
Post by Joesdad »
TommyKillander wrote:Amazing paintwork with a wonderful cammo scheme :th: :clap: :clap:
Tommy
Thanks very much Tom.
I can't say I enjoyed the PE work (it felt like work), but it turned out ok. I might try decal dials soon see if they're a better experience.
:cheers2: Tommy
Tim (Ted)
