Lockheed F-80C - from "PACAU" Sqn - Brazilian Air Force - 1/72 - Airfix
AndreFerro
Post by AndreFerro »
Hi everyone!
And I keep my duty of building the kits of planes used by FAB (Brazilian Air Force) as much as possible.
This is an old kit (back from the 60ies, I think!) which I ihave bought on e-bay sometime ago.
The kit:
Artbox:
Inside, most of the pieces were out of their sprues:
Instructions (damm old! Like egyptian papirus!): :mrgreen: :mrgreen:
Decals (damm old as well, but I won´t use them...):
These are the decals I will use! a decal set from FCM, a Brazilian manufacturer! :th:
...which could be used on several versions: (Mexico, Portugal Chile !)
The one I choosed:
Well... Starting over !
First issue: The wingtip tanks used by FAB, was the "Fletcher" ones! And the kit has only the "Lockheed" and "Mizawa" ones... :doh:
But.....
A good friend modeller, contacted me and kindly and generously offered a copy of the "Fetcher" tanks in resin:
So.... I started with the tanks !!
After some sanding and filling.... here is one of them (portside one):
But still missing the Starboardside one !
After competed the Stbside tank, a quick dryfit :
And the airbrush started to work!
Yellow green on the wheel-wels, internal landing gear doors and cockpit:
Seat & pilot: DONE !
Front landing gear bay glued, as well as some ballast on the FWD part:
Landing gears: check!
Two halves of the fuselage glued, stabilyzers and wingtip tanks as well!
Pilot installed at his 'office' as well !
Filling the gaps !
Excess puty removed:
First coat aluminium airbrushed :
Some details in red on the wingtip tanks:
Masking for a different tone of aluminium:
A mix of XF-32 (Titanium Silver) with X-19 (Smoke) both Tamiya :
Masks removed:
close up:
Some decals which I have decided not to use...
But will airbrush instead:
tip of tanks:
masks off:
Close up and masked for anti glare strip painting in black:
Which was also done, also some preshading:
After a thin coat of aluminium, started decalling:
Finishing decalling, and glued landing gears and bombs:
... and DONE :
And that´s it !
Hope you liked it !!
André
Smiffy
Re: Lockheed F-80C - from "PACAU" Sqn - Brazilian Air Force - 1/72 - Airfix
Post by Smiffy »
Good looking FAB F-80 :th:
Elve1984
Post by Elve1984 »
Nice looking F--80, great result on the old kit. Did you encounter a lot of fit issues?
AndreFerro
Elve1984 wrote:Nice looking F--80, great result on the old kit. Did you encounter a lot of fit issues?
Thks!!
Surprinsigly no, Mate !
André
