My Egg build(s) for 2016
peppie
Post by peppie »
YES :banana: , my uhm... kit... finally came in..
Only problem, I don't know what I'm going to build yet... :scratch:: :tongue:
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
Re: My Egg build(s) for 2016
Don't let them sit too long and spoil ;)
peppie
Post by peppie »
Part 1.
Ok, found a subject so time to start my first build.
Not gone tell you what it's going to be, see if you can guess... :dance:
______________________________________________________________________________
I started by opening the sprue bag, to see what's inside.
1 egg, 2 eggs, 3 eggs...... ok, bunch off eggs... :think:
And, wait.... no decals and no instructions... This is going to be a challenge... :wtf:
So, I looked up some pics on the internet and got on with it.
First step was, I cut it in half.
And closed up one piece with some styrene.
Then I cut a cirkel out of some 0.5mm styrene.
And used the hole as a guide for cutting of the top.
Makes it much easier to make a straight cut, and, off course, you can use the cut out as a lid.
The marker is there, because I needed the cap...
And I needed it for this..
Added a ring from the spares box.
Then I made some supports from, again, some styrene.
Can you guess what it is yet? No? :nena:
Ok, I'll add a litle more detail first.
A plate with some pipes.
Which goes here.
And a bracket over it.
And some bigger pipes.
And, yes you have guest it, some more pipes and something of a electric box.
Sorry, it all sits a bit crooked. That's because most off it is not glued on yet.
And this is what I got done up to now, next time some more difficult steps... :shifty:
Thanks for looking.
Comments? Yes please, good and bad.
Peter.
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
gaz45
Post by gaz45 »
iintreaging mate
peppie
Post by peppie »
Thanks.
Done some more work on it, now to find the time to post...
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
pir8hntr
Post by pir8hntr »
I've got to admit, I can't quite figure out what it is. The figure is one of those images you can't place, but is so familiar.
pir8hntr
peppie
Post by peppie »
Sorry, guys....
Could not find the time to finish this one.... :oops:
Piper PA-18-150
Ford GPA
GMC cckw 1947
Ford V3000 "Bello"
No reason you can't finish it now ;)
I didn't even try to start mine...waay too busy
Always next year
