Eduard 1/48 Polikarpov I-16 Type 10 Profipack
TomasGould
Post by TomasGould »
Ok I will build one more I-16 in this GB
This time it is spanish war ace Mikhail Nesterovitch Yakushins Type 10 from Stalins Red five aerobatic team 1939 :)
Mr.T
TomasGould
Re: Eduard 1/48 Polikarpov I-16 Type 10 Profipack
Here's some info about the I-16 :)
https://en.m.wikipedia.org/wiki/Polikarpov_I-16
Mr.T
rodrant
Post by rodrant »
waiting to see it complete ...I assume that you have some special connection with the I-16 :tongue:
well nice little plane and really one more to follow ! Even I will buy another as all the camo schemes are real nice , will have to check the ICM's one with skis ...all white , should be awesome , do not know about the kit if it is good or not !
Good luck with this one , master of the 'Ratas' :th:
Cheers ,
António
a lot of stuff right now :-)
Always48
Post by Always48 »
Lovely little fighter, im looking forward to another stunning I16 :pop:
TomasGould
rodrant wrote:waiting to see it complete ...I assume that you have some special connection with the I-16 :tongue:
The only connection I've got with the Rata is that i think its an awesome aircraft :)
I really think you should get one more :)
Always48 wrote:Lovely little fighter, im looking forward to another stunning I16 :pop:
The I-16 is one of My three favorite WW2 fighters :)
Mr.T
TomasGould
A little done on the cockpit tonight and i dry fitted the fuselage and wings :) I really like this Eduard kit :) all parts just fall together :)
Mr.T
TommyKillander
Post by TommyKillander »
- "Once more unto the breach, dear friends, once more...."
You're stamping out great looking aircrafts like a wartime factory.
I actually tried to buy a couple of these kits the other day, but guess what - the are out of stock :lol: :crazy:
Good luck with the build, I'm sure it will turn out as beautiful as the other ones :thumb2:
Tommy
TomasGould
TommyKillander wrote:- "Once more unto the breach, dear friends, once more...."
Tommy
Thanks Tommy :)
Offcourse they are out of stock.... I've bought them
all :) lol
Tonight I've painted the blue base colour of the interior and I also base painted the engine :)
For blue I used a mix of val air
2 parts 71.008 Pale Blue
1 part 71.001 white
And for the engine i used Vallejo metal color 77.716 semi matte aluminium :)
Mr.T
TomasGould
All PE and cockpit ready for paint :)
I used a mix of Tamiya acrylics for the details in the cockpit :)
3 parts XF-62 Olive Drab
1 part XF-2 White
Mr.T
TomasGould
I gave the fuselage halves a pinwash with oils
A mix of
1 part black
2 parts brown
Mr.T
AdamLuscombe
Post by AdamLuscombe »
Looking great so far. I cant wait to see it finished as i might get one!! :th:
Dragon
1/35 Jagdpanzer IV L/48
Italeri
1/24 Ford Escort Mk. II
TomasGould
Smashdown101 wrote:Looking great so far. I cant wait to see it finished as i might get one!! :th:
Thanks Smashdown101 :)
I've mount all the small details on the inside of the fuselage halves :)
Now a little detail painting is needed before putting the fuselage together :)
Mr.T
TomasGould
The fuselage halfes is glued together and the seam is primed and wet sanded :)
(I forgot to take pics on the detail painting i did on the inside but its identical as my to other I-16 in this GB)
Mr.T
TomasGould
I've weathered the cockpit and mounted the cockpit in the fuselage :)
I also glued the stabilizers :)
It have to be something wrong with me and this GB lol
Mr.T
TomasGould
Engine and dashboard done :)
I painted around the aluminium with val air 71.057 black and gave it a wash with a mix of brown and black oil paints :)
I've mounted the dasboard in the fuselage and after that glued the wings :)
Mr.T
TomasGould
Everything ready for some primer :)
Mr.T
TomasGould
Primer on!! I used tamiyas white spray primer :)
This weekend my wife will work so i hope i got time to paint a lot :)
Mr.T
Always48
Post by Always48 »
That IP looks soo real mate. :jd: rest of the plane looks great too, but im crazy about that IP! :th:
TomasGould
Always48 wrote:That IP looks soo real mate. :jd: rest of the plane looks great too, but im crazy about that IP! :th:
Thanks Always48 :) the IP is PE so i cant take the cred for that one :)
Some preshading done so far. I used a mix of tamiya acrylics 1 part XF-2 White and 2 parts XF-69 Nato black.
Mr.T
TomasGould
I base painted the model with a mix of vallejo model air 71.057 black and 71.001 white
14 parts white
1 part black
I also masked and painted the red fin with Tamiya XF-7 Red
After that i masked and painted the cowling black with val air 71.057 black. Next step will be a clear coat :)
I
Mr.T
Always48
Post by Always48 »
looking good fella. :th:
TomasGould
Always48 wrote:looking good fella. :th:
Thanks :) I'm glad you liked it :)
I painted the prop with vallejo metal color 77.716 semi matte aluminium and gave the whole plane a coat of Humbrol clear and added the decals :)
This is how it looks so far with prop and cowling dry fitted :)
Mr.T
Schoof
Post by Schoof »
Just under 2 weeks left but that shouldn't be a problem for you.... :thumb1:
TomasGould
Schoof wrote:Just under 2 weeks left but that shouldn't be a problem for you.... :thumb1:
I really hope so :)
I've drilled out the machineguns, venturi probe and also started on the landing gear :)
Mr.T
TomasGould
A light grey pin wash was given. I mixed black and white oils for the wash. After that I gave the whole plane a coat of Humbrol satin acrylic varnish :)
Mr.T
TomasGould
All small parts ready for primer :)
Mr.T
TomasGould
Painted today :)
Base painted the exhoust pipes with tamiya XF-64 red brown and machine guns with vallejo metal color 77.712 steel.
http://s1182.photobucket.com/user/tomas ... 8.jpg.html
I also masked and painted wheel bays :)
I used the same mix as in the cockpit
Vallejo model air 2 parts 71.008 Pale blue and 1 part 71.001 white.
Mr.T
TomasGould
I've got alot done tonight :)
I mounted the landingear together and gave it a wash, drybrushed pigments on the exhoust pipes and mounted them in the fuselage, painted the last on the cowling and also mounted machineguns and venturi probe :)
I used a mix of oils as a wash on the landingear doors
A 50/50 mix of dark brown and black
On the exhoust pipes I used Mig productions old rust and soot and fixed it with white spirit.
The silver ring on the cowling was painted with a silver pencil from Pilot :)
And this is how it looks with the machinegun mounted :)
I hope I will finish it tomorrow :)
Mr.T
TomasGould
Its finaly finished and here is my final reveal
http://www.intscalemodeller.com/viewtop ... 51&t=17776
Mr.T
JudgeDredd
Post by JudgeDredd »
Great work. Very striking.
I AM the Law
TomasGould
JudgeDredd wrote:Great work. Very striking.
Thanks JudgeDredd :)
Mr.T
