1/72 I-15 bis Winterwonderland (ICM)
rodrant
Post by rodrant »
Well ,
my 4th entry ...
as the SiG only finish on the 30th April , and yesterday I check this little fellow in my LHS , decided to give it a try ! expect a very quick build , sort of 48 Hour crazy build :lol:
THe kit is the ICM 1/72 I-15 Bis Biplane fighter (winter version ) , never done any plane of this brand ...will give a go in a winter wash with the new Ultimate wash and make a small diorama for it !
the box :
What you get ? One sprue , and a very well bagged Clear part
One decal tiny sheet , and some instructions :
5 steps t do , some nasty instructions , but hey this is to be fun and myself must give up my Tamiya addition :th:
two color schemes (all in grey and white , but they are colored , one is all white , but decided to do the top one and make a winter wash on it :
Soft Plastic ...some detail but will be a very tinny little plane
Just to have an idea on how long will be the fuselage !
Start on the cockpit
Painted the interior of the fuselages
Cockpit instruments , MG's and cockpit tubes ..a lot of detail with no idea where all will fit :ooops:
Example , the MG's ...are thy on the bottom of the cockpit or attached to the instriments panel ?
well maybe the first mistake , but decided to place them on top of the instrument panel ...like the Japanese Zero's or a WWI plane :-)
Another nightmare to place all inside the ''Studio'', and it has no kitchen in it , no space ... :lol:
get it and glued both halves , the fit is ....welll...ok atending that you must glue the halves with no support on either side , The new Tamiya Extra tHin Quick Dry give a big help !
So working on this this afternoon and the weekend , but so far what I have is this ...must be crazy to do a kit like this , I hardly can see the 1/35 scale , I must get an Microscope to my bench :-)
Cheers ,
António
a lot of stuff right now :-)
AndreFerro
Re: 1/72 I-15 bis Winterwonderland (ICM)
Post by AndreFerro »
He he !
Good luck !! :shock: :shock:
But quite nice sofar.
Caution while any perforations (ICM soft plastic) while doing the ridging for a biplane.
Curious to see the camo !! :hi:
André
rodrant
Post by rodrant »
AndreFerro wrote:He he !
Thank you ...the riging...well I didn't thought of that , I hate that ! :crazy:
Cheers ,
António
rodrant
Post by rodrant »
One more update on this 'enourmous' build :-)
The plane was easy to build ...well I really hate Biplanes and to fix the supports to the upper wing ...and this littel fellow has no support in nothing , but in the end ...ok , I think !
Still do not know for what I have the work to paint the engine parts , and so much doubts on the Machine guns position ...you can't see nothing as all was closed in the fuselage of Doom :lol:
BEhind you can see two little submarines , actually they are the skis :-)
AS I'm a guy that like to try new stuff and decided to get rid of the good habit that is to do Tamiya kits and using their paints , decided to use ...crypes....Vallejo Paints :wtf:
After a Good Priming using some Vallejo Russian Green Primer ...yes I took the risk this time ...
DEcided to leave the primer itself , and painted the underface in the Blue Sky
Nice result ...but not convinced with the Vallejo Paints ...
Some more steps going to the finish line ...add the propeller , skis ...
exhausts were painted Red Brown ...
AS I painted free hand some blue where should be green ...but will try to corret with the winter wash
Some chiping using aluminium and a sponge , and Vallejo paints , actually was only the primer will look also like the Russian paint in WWII it get weathered soon ...or maybe my Big fingers and hurry to finish this build !
Bombs and sight for the pilot
DEcalling Time !
the decals were ok , but they rip off a little that patriotic phrase on the side , split in three pieces...in the end I win the battle , with some casualties , but was won ! :scratch::
Upside down photo , the first one ...
Now to prepare the base for the diorama , some trees from ModelSCene , Tamiya Texture paint snow , some snow in a pot from Reality in sclae, some Pine forest scatter from Reality in scale ...let's see what I can do on this one :
Let's give the plane a wash
oh my ...what I've done !!! :jd:
I finished using some snow from Tamiya weathering master , in complement of the Ultimate wash , and I like the end result !
And here it is ready to go to the diorama !
Painted the base with Vallejo Black Primer , good to waste in this kind of stuff
DAS Plaster on top
Painted with vallejo Russian Green so after I can start working on the textures and surface .
There is all for now ! Hope that you like ....must do the rigging on the plane ...doesn't feel with too much will to do that ....
Cheers ,
António
rodrant
Post by rodrant »
Last update before the final reveal ...
Finishing the base :
Some white glue to spread the scatter
Added the snow
And one point , I didn't make the rigging in the plane ...I didn't feel to do it , I started doing it with some Ushi Rig , but I just didn't do it , I was stressing doing that ...maybe later I will do it with some streched sprue as could be the better way to do it :
And the final reveal here :
http://intscalemodeller.com/viewtopic.php?f=451&t=17594
Cheers ,
António
