Techniques used to Mask off a cockpit?
TheTroyster
Post by TheTroyster »
Just interested in what you guys are doing on this issue? When building aircraft, often you have to paint the plane but you have that exposed cockpit you need to mask off. I've tried a sponge, tape, even toilet paper and they all seem to bring with them their own problems (broken parts, leaks, take forever to do -always that lurking feeling you're doing something really wrong).
What works for you?
Troy :violin:
Re: Techniques used to Mask off a cockpit?
Tamiya masking tape, or just buy a mask set.
RustyWarrior
Post by RustyWarrior »
I've had some moderate success with simple masking tape on the canopy and fix it in place with a tiny piece or two of white-tak. Once spraying has been completed, I can remove the canopy and touch up any aberrations.
I keep meaning to try some of the rubberised lotions and potions (Maskol et al) to see of they work any better. but not got round to it yet. Perhaps when it comes to finishing off my Lancaster will be the ideal time especially with all those fuselage windows.
I just added another one to the, "What the HELL was I thinking list..."
TheTroyster
Avgas wrote:Tamiya masking tape, or just buy a mask set.
I'm talking about masking off something that has no canopy - like a bi-plane or the Piston area of a prop plane / those areas.
Troy :violin:
Willem
Post by Willem »
I usually use some leftover foam sponge from aftermarket kits to mask up wheel wells and engine cowlings. Tamiya tape across the canopy sidewalls though this can be fiddly. I tend not to use damp tissue or white tack as clean up can take ages and because the material is dense can lead to stuff getting broken.
Funnily enough, I'm about to start the process on my corsair. Not my favourite job but at least it means one step closer to paint.
Hope this helps.
Will
Edward R Murrow
Ah gotcha. Depends on the size and shape of the hole you need to mask (just coming up to the same issue with my latest build). I usually use Tamiya masking tape around the edges because it's near on bleed free, then just use a piece of plastic bag or something to cover the hole; attached to the masking tape obviously.
Always48
Post by Always48 »
masking tape for me, i tend to place it on the aircraft sidewall to sidewall then leave it a day before cutting the external edge. i think it gives the tape time to bond a bit to the thin edges before being cut.
engine wise i dont paint the cowling on the plane, always seperatly then glue it on in the end.
flundstrom2
Post by flundstrom2 »
Avgas wrote: I usually use Tamiya masking tape around the edges because it's near on bleed free, then just use a piece of plastic bag or something to cover the hole; attached to the masking tape obviously.
Nice tips! I'll save that to my memory for some appropriate challenge! :D I guess, the thin, semi-tacky-static plastic foil used to wrap food would work as well, if just attached to the masking tape...
Regards, Fredrik
Modelling interests: Aircraft (preferably WWII) and space
Vleugelmoer
Post by Vleugelmoer »
I use Tamiya Tape and burnish it down with a cocktail stick, I cut the frame portions with a fresh scalpel. To prevent paint bleed on the canopy I usually give the edge a thin misting with either gloss varnish or Johnson Clear, Future or how it may be called where you live.
Always48
Post by Always48 »
sorry i must of mis-read, i thought the Op was talking about openings. for glass work i do the same as paul, tape cocktail stick and sharp blade. generally i do a b,ack coat first, then paint the aircraft. if im lucky like on the su9 i mask the inside with blue tack and with a cocktail stick manipulate the tac so that the internal part of the frame is showing and fine coat a thin dash of the cockpit colour. however ive not the skills to do anything complex, just those bubble type canopys.
TheTroyster
Thanks so much for your feedback guys. All great advice which I will put to work.
Troy :violin:
TheTroyster
Vleugelmoer wrote:I use Tamiya Tape and burnish it down with a cocktail stick, I cut the frame portions with a fresh scalpel. To prevent paint bleed on the canopy I usually give the edge a thin misting with either gloss varnish or Johnson Clear, Future or how it may be called where you live.
That's epic! A cocktail stick - who would have funked it? Been using those things for olives all these years - silly me!
Troy :violin:
TheTroyster
Always48 wrote:sorry i must of mis-read, i thought the Op was talking about openings. for glass work i do the same as paul, tape cocktail stick and sharp blade. generally i do a b,ack coat first, then paint the aircraft. if im lucky like on the su9 i mask the inside with blue tack and with a cocktail stick manipulate the tac so that the internal part of the frame is showing and fine coat a thin dash of the cockpit colour. however ive not the skills to do anything complex, just those bubble type canopys.
That's me - stick to bubble tops - that way I can continue to drink beer while building models and masking is simple.
Troy :violin:
NorthernModeller
Post by NorthernModeller »
My preferred is to cover the canopy in masking tape and then use a cocktail stick and score into the frames of the canopy then cut with a brand new sharp blade. Works well for me
See, that's where you went wrong. If you drank cocktails instead of beer then you would have found the toothpick method sooner.
dandonde
Post by dandonde »
Hi. I used to be a member here but can't find my log in. I'm back to the hobby after a 4 year break! I've kicked off my return with a 1/32 Revell Spitfire Mk II but cannot find any pre cut canopy masks for it. Has anybody found any at all as I'm currently at a standstill with this build. Thank you.
dandonde wrote:Hi. I used to be a member here but can't find my log in. I'm back to the hobby after a 4 year break! I've kicked off my return with a 1/32 Revell Spitfire Mk II but cannot find any pre cut canopy masks for it. Has anybody found any at all as I'm currently at a standstill with this build. Thank you.
Well, I found this: http://www.aviationmegastore.com/spitfi ... art=125861 and this: http://www.ebay.com/itm/Montex-1-32-can ... 1652742357
I'm on the go so I can't do more. I'll check in later and see what I can find. :)
wookiee76
Post by wookiee76 »
Not for cockpits but i have used cotton wool and tape for open topped tank destroyers, just get the tweezers ready for any stray fluffy bits.
