clear coat
johnharrison
clear coat
Post by johnharrison »
Just going to start clear coating and my question is do you have to thin clear coat if you are using an airbrush? If so is it to the same mix as paint
Re: clear coat
Which clearcoat are you using ?
johnharrison
Re: clear coat
I've got tamiya and umbro
Re: clear coat
johnharrison wrote:I've got tamiya and umbro
The tamiya will need thining, the humbrol i would personally throw in the bin I've seen it screw up too many models
johnharrison
Re: clear coat
Thanks for that paul and thank you to the ultimate team I got my goods today can't wait to use them.
50/50 mix clearcoat
erased
Re: clear coat
Post by erased »
Just get the tamiya ts 13 spray can if u are gonna airbrush.
