Saab Viggen and F-51 Mustang
EasyEight96
Malaysia
Post by EasyEight96 »
Hi this will be my entry to the Shiny things SiG
So here is my first kit yes a matchbox kit
The contents
and my second entry the korean war mustang
The contents
I'll try to update frequently hopefully I could finish in time
In -progress
Too many on the bench!!!
Matchbox Kits lover....
mperegrinefalcon
Re: Saab Viggen and F-51 Mustang
Post by mperegrinefalcon »
The airfix kit looks good, but be prepared to do a lot of work on that kit from matchbox, it already looks like it will be a pain.
Looking forward to see what these turn into!!!
Too much
up next:
finishing the kits I have started
Why finish a kit when you can start a new one?
EasyEight96
Malaysia
Update on the Viggen, I'll post the mustang later after I've finish some work on it
So I started it few days ago
Once I primed up all the parts,
I started by painting the cockpit interior neutral green and the exhaust compartment metallic grey. I then glued the fuselage
together immediately there's a tone of gaps need filling
Here's the shot once I add on the filler
The seats were too painted in neutral grey and khaki drab on the cushion
The intakes was next I hand brush it with aluminium before mating it together that too has bad fitting issues
Nothing cant be solve with a help of fillerrr!
To get the best fit when I glued the intakes to the fuselage I removed the pins on the intakes although there were still gaps but I manage to minimize the gaps. Then I glued on the wings of the viggen with surprisingly very little fit issues
Still it needs some filling up
As the instructions asked for some weight to be applied to avoid tail sitting I added some screws and bolts
The nose then glued on to the fuselage it's looking more like a saab viggen now
Landing gears were quite simple to build
The weapons and fuel tank were filled and now looking cool
The canopies are masked up using normal masking tape and the new tamiya flexi masking tape. The pitot tube was glued in and filled too as it have a massive gap jeezzz
So with all that it was ready for priming today afternoon
Letting it to set for a few hours I continued with the paintwork
I started with painting the nose with gaianotes ultimate black
I masked the nose up using the flexi tape and normal tape and I painted it with tamiya aluimium. For the undercarriage I used ak metal aluminium
and here is how the viggen looks like
Thats for the work so far will update more soon
In -progress
EasyEight96
Malaysia
Update on the mustang
The cockpit parts were sanded down and prep for painting last night
and today I painted up the cockpit parts together with the other mustangs I'm working for the PTO GB
Once it was dried I hand painted the details gave them a dry brush of silver
Decals applied to the instrument panel
I gave the cockpit a nice wash from Mig and installed the cockpit to the fuselage
Thats all for the mustang as I need to paint the spinner and the props before I could close the cockpit
In -progress
Les
Post by Les »
How is your planes coming along? We have less than 13 days left in this SiG!
EasyEight96
Malaysia
Les wrote:How is your planes coming along? We have less than 13 days left in this SiG!
I've completed the Viggen I will put an update later. The mustang is not done so I'll put it aside
In -progress
EasyEight96
Malaysia
Very late update
So the viggen is now completed here are the photos step by step to the end. As for the mustang I'll try to pump extra work to get it done by this week
Landing gear glued on...
Fuel tank installed and pitot tube painted. So after a coat of clear its time for decalling
Anti shipping missile all painted up
After a final coat of clear I pulled off the masking tape from the canopy and here is how the viggen looks
and finally once the missiles were installed and volla the viggen is completed more pics in the reveal section
In -progress
