MicroSet/sol
Augustus
MicroSet/sol
Post by Augustus »
What's the difference, when do use each as in what conditions call for using each one.
Do you really need both of them?
Are there better alternatives?
:banana:
Re: MicroSet/sol
http://www.intscalemodeller.com/viewtop ... et#p213849
set first then sol if needed
quick utube vid......... :th:
tommym
Re: MicroSet/sol
Post by tommym »
For question and answer
I was wondering the same thing
TommyM 8-)
Schoof
Re: MicroSet/sol
Post by Schoof »
It actually says on the bottles themselves which to use first and how to use them..... :D
OneSmallStep1966
Re: MicroSet/sol
Post by OneSmallStep1966 »
Just be careful with those bottles because they're super-easy to knock over. I think more of my solution has ended up on the desk than the decals :(
FuzzSquad
Re: MicroSet/sol
Post by FuzzSquad »
I am recent convert to this stuff, I wouldn't use anything else now
On the bench/cupboard are a Yamaha YZR-M1 Estoril, Honda RC213V Repsol, Revell Ferrari 458 Italia, Aoshima Lambo Aventador Roadster, Revell VW Golf....... The list goes on
Re: MicroSet/sol
Get some water pens ,makes life easier
Re: MicroSet/sol
Paul wrote:Get some water pens ,makes life easier
no leakage or evaporation ??
Re: MicroSet/sol
No they work perfectly :banana:
HIghAltitudeScale
Re: MicroSet/sol
Post by HIghAltitudeScale »
I agree, waterpens have helped tremendously, no more spillage or wasted solutions
Cheers,
thetechcowboy.com
Current build;
1/72 Airfix B-17G
1/48 Hobby Boss Bearcat
Re: MicroSet/sol
Yeah, eager to try mine. Just need to get the liquid in there...and, you know, work on a kit.
Augustus
Re: MicroSet/sol
Post by Augustus »
Ive been looking at these but the only ones I can find locally have very fine 'nibs', are the ones you use like this, yours seem to be fairly broad.
I got the Microset/sol in the post yesterday with some other supplies.
Re: MicroSet/sol
check this out...all you needed to know
http://www.jetpens.com/blog/guide-to-wa ... hes/pt/792
:th:
Re: MicroSet/sol
Augustus wrote:Ive been looking at these but the only ones I can find locally have very fine 'nibs', are the ones you use like this, yours seem to be fairly broad.
Hi,
I think this is the product Paul is using. It has a 'chisel' tip as opposed to a pointed one.
http://www.jarrold.co.uk/departments/ar ... GwodfKIHsQ
Augustus
Re: MicroSet/sol
Post by Augustus »
Cheers guys,
Now just need to find someone round here who sells 'em.
Les0012
Re: MicroSet/sol
Post by Les0012 »
I got a couple of the Derwent ones in Hobbycraft, if you have one near you, cast about £3.50 if I remember correctly.
Les
Re: MicroSet/sol
Les0012 wrote:I got a couple of the Derwent ones in Hobbycraft, if you have one near you, cast about £3.50 if I remember correctly.
Les
Yep. £3.50. They still stock them
