Help with Vallejo paint
InitialProduction1
Post by InitialProduction1 »
I see a bunch of people using Vallejo paints, so I started buying it, a lot of it, and it seems to work very well for them, but when I used it I can scratch it off with my fingers, what am I doing wrong? I like Tamiyas paints and never had anything like this. Love humbrol paints, but never enough paint in the can/tin or what ever they call it. So what am I doing wrong With Vallejo?
clay
Re: Help with Vallejo paint
Don't know, never had any problems with it. When you say you scratch it off with your fingers do you mean you are scraping it off with your fingernails?
InitialProduction1
Yea, I was looking at it and admiring the way the paint looked, then I had seen a blemish on it, took my finger and tried to rub it down, and my finger nail scratched the paint , then I looked up on YouTube to see if anyone else had this trouble, yes some but no one knows why, so I'm looking for why? Or should I go back to my old way. By the way the paint primer with black Vallejo.
clay
HamilkarBarkas
Post by HamilkarBarkas »
Observed a similar thing with my Vallejo air paints. When you sand over the paint it peels off like a foil. never saw that before with my Revell paints. I do not consider that to be an issue though. Since i know about it i act accordingly.
JET
Post by JET »
I had this happen when I tried this paint, it peels off like a skin of latex lol. Never used them again.
gustavlekstal
Post by gustavlekstal »
I use vallejo with a brush. The bestest to brush. Outstanding qualities. To airbrush... No... Nothing beats tamiya or Gunze. Its more no peeling friendly aswell as you noticed. :eeek:
Regards Gustav
Dragon t-34/85 premium mod 44
viewtopic.php?f=29&t=10747
viewtopic.php?f=29&t=12313
StarFar
Post by StarFar »
HamilkarBarkas wrote:Observed a similar thing with my Vallejo air paints. When you sand over the paint it peels off like a foil. I do not consider that to be an issue though.
Yes, it's not an issue, because Vallejo paints contain acrylic resin. I think, that's why it is so good for brush painting but you can't sand it. From my experience, Vallejo has slightly worse adhesion compared to Gunze or Tamiya paints and the main requirement - apply it in thin layers, giving some time to dry between them. In the other case, adhesion will be very poor.
InitialProduction1
Thanks to all! back to tamiya. I do love the range of colors Vallejo give us. But looks like all brush from now on with the Vallejo.
clay
Warren
Post by Warren »
Saw a few youtube videos on Vallejo paint peeling. It seems the consensus was that the primer was not allowed to cure properly before the paint application. According to these commentators, the Vallejo primer needs to cure for 48 hours. They indicated that if the primer was hand brushed not to dilute it. If the primer was airbrushed a very very small dilution only.
I am not an expert on this subject having just returned to modelling after 30 years. I am just passing on what I have seen on various youtube videos.
Warren
Madmattmodels89
Post by Madmattmodels89 »
I recently bought a good amount of Vallejo paints, I use them thinned in my air brush with no issues. I also use self etching primer allowing it to dry 24 hours before I apply the Vallejo colors. I love the way the color looks after dry.
This tank is all done with Vallejo ( base and shades)
lv2bf111
Post by lv2bf111 »
Remember that Vallejo is a pure acrylic paint unlike Tamiya or Mr.Hobby. This means that you have to have a good primer coat and they must be sprayed a little differently. This video shows how to spray Ammo colors, but they are the same technology as the model airs so it works well. The point is they are different then non pure acrylics and have to be handled a little differently. I had to learn this the hard way trust me. I have found that with the proper technique they tend to be as strong if not stronger then Tamiya. The other benefit I have seen from the pure acrylics is they seem to be much stronger and less visually affected after a clear coat.
Current builds: Shinny things: Revell 1/48 B-17 with a 1:48 Tamiya P-51B Mustang Blue Nose | Revell 1/48 Apache
Vleugelmoer
Post by Vleugelmoer »
As Vallejo have several color / paint lines out there it would be nice to define which paint line / range of paint you are experiencing difficulty with..
I use the Vallejo Model Color line of paints both with the old hairy sticks as thru the airbrush. And have experienced something similar to what is described in my early day back in the hobby back in 2012. It was cause my surface contamination that I did not remove and the lack of a good primer. After dealing with those two issues never had a problem with them again. Do steer clear of there own line primer that wouldn't even stick if its life depended on it.
gaz45
Post by gaz45 »
I have just started having issues with my vajello air paints they are still fine for brush painting but as for through an airbrush even when thinned they are not so good. I have only had them for about 12 months and they are kept inside
InitialProduction1
I sprayed just the Vallejo primer black, and let it set three days, and it came right off? Did this twice, oh I thinned the first time two drops in my color cup. second time, I used nothing. I love the range of colors they have, but wow what a pain. , I bought Vallejo model air, and model color, and Panzer Aces, can anyone help please.
clay
Vleugelmoer
Here's a little something that might help. Model Air 15 to 20% thinner and two drops of flow improver (71.262, 17 ml; 71.362, 32 ml; 71.462, 60 ml and 71.562, 200 ml) for every 10 drops of paint. For model color and panzer aces 65 to 70% and same amount of flow improver should get you to a workable paint @ around 15 to 20 odd PSI.
Hope this sorts out your problem.
I must be dense , but I.m confused as to what you mean.
71.562, 200 ml....
I can understand 20% thinner, 2 drops of retarder and 10 drops of paint( which ain't much, but for me this 71.262, 17 ml....do you mean 71ml of thinner to 17ml paint...which doesn't make sense either....confused I am.
Vleugelmoer
digger303 wrote:I must be dense , but I.m confused as to what you mean.
71.562, 200 ml....
Digger mate, the 71.### numbers, are the Vallejo product numbers. The ml's indicated after the product number are the bottle sizes.
As to the thinning ration of 20% dilution of the paint, comes to two drops of thinner to every 10 drops of paint.
And this ration is for the Vallejo Model Air range only. Other paints by Vallejo or any other manufacturer will require different thinning ratios.
Hope this clarifies it for you. If not just quote me and I'll get back to you on this matter.
71.562, 200 ml....
bottle numbers.....the penny drops....thanks
Vleugelmoer
digger303 wrote:bottle numbers.....the penny drops....thanks
Welcome mate, glad to be able clarify this conundrum for Ya :th:
Have a nice one.
