Vallejo model colours for WW2 British Paras
chalkyw
Post by chalkyw »
Hi,
I've been trying to find a reference for what Vallejo Model Colours can be used for painting 1/35 WW2 Bristish Paratroopers and have not had much luck. Does anyone have a link to share or what know colours would be suitable, especially for the Dension Smock camo.....I have a rough idea but anything more specific would be most helpful.
Any help is much appreciated in advance.
Cheers :cheers2:
Chalky
privatepete
Re: Vallejo model colours for WW2 British Paras
Post by privatepete »
Hi Chalky this may help, this is for the 2nd pattern dennison smock, also known as the 1944 pattern. Use Vallejo 988 Khaki for the base with 924 Russian uniform and 825 German camo pale brown for the pattern good luck with it :cheers2:
Found this .
Steel Helmet 896 Dark Green
Denison Smock 896 Dark Green
H/L 819 Sand
H/L 846 Brown
Webbing 819 Sand
Trousers 921 Br. Uniform
Metal parts 801 Brass
Wooden parts 879 Brown
Boots H/L 994 Grey
Ropes 951 White
Sten SMG H/L 994 Grey
Rank insignia 951 White
Anklets 819 Sand
Beret 946 Dark Red
Scarves 896
Have a look
http://www.warlordgames.com/wp-content/ ... nt-set.png
http://cdn.shopify.com/s/files/1/0288/8 ... 1397473508
chalkyw
Post by chalkyw »
privatepete wrote:Hi Chalky this may help, this is for the 2nd pattern dennison smock, also known as the 1944 pattern. Use Vallejo 988 Khaki for the base with 924 Russian uniform and 825 German camo pale brown for the pattern good luck with it :cheers2:
Found this .
H/L 819 Sand
H/L 846 Brown
Webbing 819 Sand
Boots H/L 994 Grey
Ropes 951 White
Anklets 819 Sand
Beret 946 Dark Red
Scarves 896
Have a look
Thanks Pete :th: , a superb response to my dilema. I took a trip to the model shop yesterday to get the paint I needed but they didn't have all the colours I wanted so I had to wing it on a couple but here's the fruits of an afternoon of figure painting based on some of your list and a sneak preview of a small bit of a dio I'm working on.
Many thanks again
Cheers :cheers2:
Chalky
privatepete
Hi Chalky no problem glad I could help, if that's a small part of your dio can't wait to see the rest looks fantastic :clap: , well done :cheers2:
AdamLuscombe
Post by AdamLuscombe »
That dio looks cool, do you have a build thread anywhere?
Dragon
1/35 Jagdpanzer IV L/48
Italeri
1/24 Ford Escort Mk. II
chalkyw
Post by chalkyw »
privatepete wrote:Hi Chalky no problem glad I could help, if that's a small part of your dio can't wait to see the rest looks fantastic :clap: , well done :cheers2:
Smashdown101 wrote:That dio looks cool, do you have a build thread anywhere?
Sorry, I started on this dio way before I joined the forum so i didn't document the build. There's some more pics of the whole thing here if you're interested http://www.intscalemodeller.com/viewtop ... 29&t=18193 mostly DAS, garden dirt and twigs, sea foam trees, static grass and a few scratch built bits like the gate but when i finish and post some pics i'll describe what i did in more detail .....I lost my way a bit with it and needed a bit of help so had a rethink and came up with a new direction with the paras.....BTW there won't be a Sherman in it anymore :crazy:
AdamLuscombe
No problem, you answered my main questions now anyway! :th:
Dragon
Italeri
