Figure stand advice?
fly1ngdutchm4n
Post by fly1ngdutchm4n »
I made a steel Figure stand on the lathe at my work for my Vietnam 200mm bust.
I'm planning of let it rust, and twist some home made scale barbed wire around it, with 2 old planks from balsa wood with the name on it.
But this figure is already on a resin mini stand. So my question to you guys is: whats best? Let the bust on the resin stand and put all together on the bigger stand, or take the bust off and place it alone on the new stand...
Got any advice?
Re: Figure stand advice?
I think that the new stand is to big to have the bust on it itself but then it dose not look quite right as is if that makes sense. I personally would bevel the top of the steel one to match the curve the resin one so they match it would bring it all together as one but that's just me.
wappynutter
Post by wappynutter »
Saw off the resin base then mount a rifle on his back to use as the anchor to the steel one... :th:
Just an idea... :wtf:
Regards Andy...Image
fly1ngdutchm4n
Nige201980 wrote:I think that the new stand is to big to have the bust on it itself but then it dose not look quite right as is if that makes sense. I personally would bevel the top of the steel one to match the curve the resin one so they match it would bring it all together as one but that's just me.
Just took off the old stand, and I think you are right on this on...
Way out of scale...
Well back to the drawing board with this on... :(
fly1ngdutchm4n
But, maybe it's an idea to pin the bust on a piece of Tubbing? Drilling a hole in the metal stand and pin the bust like the the one here?
That could work also...
fly1ngdutchm4n wrote:But, maybe it's an idea to pin the bust on a piece of Tubbing? Drilling a hole in the metal stand and pin the bust like the the one here?
Yeah that could work I think but might be too wide still if it was a couple of mm to 1/2 cm either side that would work I think.
HamilkarBarkas
Post by HamilkarBarkas »
I personally don´t bother too much about the stand for a bust, usually a small one is included but they provide not enough stand safety so i add my own.
Here are three examples how i solved it:
For my Norman Knight i used a plastic figure base from MiniArt, a section of the Bayeux Tapestry was glued on it aswell as the included bust stand. Not complicated at all and it serves its purpose.
The Roman Legionary had a small stand included aswell, so i glued it on a wood plate and added a map of the Roman empire.
I placed the German WW1 assault trooper on a muddy battlefield with some rusty barbed wire on it.
Of course my bust stands do not look as precious as the ones of the professionals but i think they are quite creative and don´t look too bad. Maybe you can do something similar aswell, you could place some jungle leaves and mud on a wooden plate and then glue the bust with the included figure stand on the self made base. Just a suggestion :)
fly1ngdutchm4n
HamilkarBarkas wrote:I personally don´t bother too much about the stand for a bust, usually a small one is included but they provide not enough stand safety so i add my own.
Thank you!
A brilliant idea!
especially that last stand is a good idea for my vietnam bust.
with some jungle leaves, this would definitely work!
And for the record, you're figures are awesome :thumb2:
HamilkarBarkas
You are welcome :)
Not too sure FD my friend. I don't have any experience with these guys. But I would say that if the base is taller/wider than the bust, it could detract from the main focal point (your hard work)!
I think Hamilkar has hit the sweet spot with his last pic, the actual support doesn't draw your eye away from the bust, yet the base gives an impression of the subjects environment.
What about a bit more turning to thin it down, but leave it wider at the bottom. Then let the bottom part rust, and have rusty barbed wire wrapped around the shiny stem?
Just a quick thought, you should probably ignore it right now! It'll look Brad Pitt! Lol
Anyway, I look forward to seeing what you decide on in the end.
Cheers!
For Brad Pitt, read poo! Lol
NovYank
Post by NovYank »
The idea of the personalized base is a good one. Some red clay which is typical of Vietnam, and some barbed wire with the wooden sign. I don't know how available this is, but another idea is to mount the bust on a spent cartridge (shell from a bullet). I've seen it done before to great effect!!
^^ oooo, yeah, I like the sound of that one! Good drills Nov!
fly1ngdutchm4n
thank you all guys!
got a lot of ideas now!
Shell idea sounds great, but don't know where to get one :scratch::
The wooden display with the ground and barbed wire sounds better tho.
I can turn a better steel display, but I think to that it draws away the attention of the figure.
I have to think what to decide now. I'll let you guys know! :thumb1:
fly1ngdutchm4n
Ok, Did a lot of thinking about a stand/base for my Vietnam "the grunt" figure.
I saw and read a lot of great idea's and I desided to make a personalized base like the awesome ones from Hamilkar :thumb2:
The metal one I turned earlyer will be turned down to round 30 top to round 60 bottom. (mm that is)
I will use that stand for future figures.
Now, I did pin my bust on a piece of wood, and I covered the base with some red clay/sand.
Grow some jungle plants on it, and made a scale piece of barbed wire.
There is a piece of tree branch planned, but the ground cover has to dry first.
The name plate wil be made out of 2 or 3 pieces balsa wood, and I will hand paint the name.
Here is what I've got so far....
wappynutter
:clap:
Nice recovery of the base my friend....
Will look good when completed..
Looks great mate just right
Whoa... I think that my eyes just exploded.
I think that you fixed it Dude.
Or at least well patched... fixed is a permanent condition.
Great job.
fly1ngdutchm4n
:D :D Thank you all guys! Appreciate all nice comments :thumb2:
Yep - That looks the dogs dangleys now :th:
HamilkarBarkas
Looking awesome mate! (my busts are not that great actually)
I´m happy that i was able to provide some help and inspiration here :)
fly1ngdutchm4n
Final result of the base for this 200mm nam bust.
Made the sign from balsa wood and dry transfers.
Tried to make a old lid from a ammo crate ;)
The wooden stand needs one more dark wash tho..
Hope you guys like it!
Thank you for all advice, hints and tips, much appreciated!! :thumb2:
Again... Master Class Frans.
Superb.
The sign knocked it out of the park as they say.
Many thumbs Dude. :th: :th: :th: :th: :th: :th: :th: :th:
McLeod
Post by McLeod »
That looks amazing :th: :th:
There can be only one!
My Youtube Channel
fly1ngdutchm4n
Coen wrote:Again... Master Class Frans.
Superb.
McLeod wrote:That looks amazing :th: :th:
:D Thank you guys!
HamilkarBarkas
Very nice!
T3hGuppy
Post by T3hGuppy »
Great base dude. love the sign. :th:
Too much to list. !!
fly1ngdutchm4n
HamilkarBarkas wrote:Very nice!
T3hGuppy wrote:Great base dude. love the sign. :th:
Thank you for the compliments! :D
Fantastic work mate,the base really sets it off
fly1ngdutchm4n
Paul wrote:Fantastic work mate,the base really sets it off
:cheers2: Cheers Paul! :D
bdr65
Post by bdr65 »
Captured the mood dude :th: Looks wickedly good mate.
