German VK4502(P) VORNE
privatepete
Post by privatepete »
Hi this is the next one up for slaughter on my bench of doom it's a bit of a big beastie.
thank you for dropping by :cheers2:
Nev
Re: German VK4502(P) VORNE
Post by Nev »
Wow Pete you are going for it matey! :thumb2: :thumb2:
On the Bench...
privatepete
Hi Nev this is going to a slooooooooooooow build,I know there quite a lot wrong with weld lines /bits missing I looked this one up a lot of white card & filler required :cheers2:
privatepete
Parts
Thank you for passing by
wavelet
Post by wavelet »
Great kit, great start!
I scream, you scream, we all scream, for ice cream.
On the Bench: Trumpeter 1:35, BMP-1 IFV; Meng 1:35, VsKfz 617 (Minenräumer); Tamiya 1:35, S.A.S. Land Rover Pink Panther.
privatepete
wavelet wrote:Great kit, great start!
Thanks a long way go to go and a lot of mods :cheers2:
thelittleprowler
Post by thelittleprowler »
Really love the attention to detail you're showing. Keep up the good work :th:
:bash: nothin a little squadron can't fix
On The Bench: 1/35 Tamiya M4A3 105mm dio, 1/72 Airfix Bf-109 E-4
privatepete
thelittleprowler wrote:Really love the attention to detail you're showing. Keep up the good work :th:
Thank you very much I'm tryimg,and there a lot more of at to come the weld line's are not that good or totally missing I'm afraid so keep watching :cheers2:
InitialProduction1
Post by InitialProduction1 »
I didn't know this kit was still out there, where did you get it from? Do you know if that was an idea from Porsche or did the German staff became of with this vehicle on paper? With that crappy drivetrain, I wouldn't think anyone would have wanted to use it. anyway good start looking forward to the next update.
clay
privatepete
Hi Clay thanks, it was waiting for me when I got ,a nice present :cheers2:
InitialProduction1 wrote:I didn't know this kit was still out there, where did you get it from? Do you know if that was an idea from Porsche or did the German staff became of with this vehicle on paper? With that crappy drivetrain, I wouldn't think anyone would have wanted to use it. anyway good start looking forward to the next update.
still available
http://www.ebay.com/itm/Hobby-Boss-8244 ... 1632541319
InitialProduction1
Nice thanks, man does that shipping sucks.
clay
privatepete
Notice the weld running through the tow lug.
used a razor saw to created the rough cutting marks on the extensions.
Used white card and used a razor saw to created the wider welding seams marks.
Made the jack, r/light.
Thank's for looking :cheers2:
hansolo
Post by hansolo »
This is what I call "Upgrading a kit!"
Very nice work!
Hansolo
privatepete
Hi Hans thank you for the nice comment I get a lot of inspiration from your work which I can only hope to emulate some day or even get close :cheers2:
privatepete
Got a bit more done, fitted the jack block, cleaning rods, tow cable, tools etc, the jack block I roughed up to give the wood some texture ,four hooks for the spare track links. One error is the last link in the spares does not have link pin so I removed the head of the link pin on both sides drilled a hole through both links and added a piece of cooper wire.
Fixed the headlights added some wire to a connection cap.
Replaced the M/G from my spares box.
Added lead wights to give some body .
Thank you for looking :cheers2:
privatepete
Finished the hull.
Started the turret.
Added internal weld seam.
Removed tack links, 64 sprues , 24 cuts per spues, 1,536 cuts in total.
Sdkfz250
Post by Sdkfz250 »
Well I am rather surprised I missed this when it was first posted, since I absolutely love German armour. Best of luck with this one Pete, I have the same kit myself along with the Hintern so I am looking forward to seeing how it all comes together.
Roses are Red, Violets are Blue, I'm stuck on the Ostfront...and so are f**king you!
Sdkfz250
Post by Sdkfz250 »
The design was created by Dr. Porsche leading on from the rejected VK 4501(P) which was his contender for the contract of the Tiger I tank. This and the VK 4502 Hintern were the two designs he proposed to Hitler in contention with the Tiger II. This vehicle was rejected and never had a prototype hull produced, but the turrets that Krupp manufactured for it were instead used on the first Tiger IIs known as the "Porsche Turret" design.
chalkyw
Post by chalkyw »
Love the detail you're putting in to this Pete :th:
privatepete
Cut & cleaned up & pre assembled track links as far as possible.
Odds & bobs in the turret.
privatepete
I gave the hull a coat of Gesso to give it a little bit of texture I used a stippling brush for this,
Then primed.
Yes I used a hairy stick.
The commander’s hatch can be made to be open, but to do this you need to add a length of rod so the hatch can stay open in the normal position.
Made up the other hatch's.
The loaders hatch opening bracket is not connect to anything.There is a part of the hydraulic mechanism that connects to the hatch used to open and close the hatch. I will make a plastic rod with a U couple from strip plastic to connect the hatch.
privatepete
Made up missing hydraulic rod that connects the hatch to the cylinder which is used to open and close the hatch. I used plastic rod and made a U couple from strip plastic to connect the hatch.
Cleaned up all the shells.
The racks do not fit however without modification. There are two tabs on the inside top of the turret where these racks are supposed to mount. In order to get these to mount the rear side of the rack needs to be sanded to fit
Thank you looking :cheers2:
Augustus
Post by Augustus »
privatepete wrote:Hi Nev this is going to a slooooooooooooow build,I know there quite a lot wrong with weld lines /bits missing I looked this one up a lot of white card & filler required :cheers2:
Good, I'm having trouble keeping up!
Great work too.
privatepete
The drive mechanism has several fit and instruction issues.In the instructions part G47 is installed where G46 is supposed to go, so beware .The assembly that fits to part G25 cut off mounting pins .
OneSmallStep1966
Post by OneSmallStep1966 »
A great build you've got going on here Pete. I'm really liking your modifications to the kit and your attention to detail is superb.
privatepete
Thank you just trying to my best,its beginning to take shape ,the hardest bit of build is to come :crazy:
privatepete
Finish off the rest of the gun breech assembly and the turret MG, the instructions are not good at this point. I also found that the mounted MG’s did not have a shoulder stock so I cut it off.
Made up the barrel. There are up grade barrels available but what I have found out is everyone has had big fitting problems
Thank you for looking.
chalkyw
Post by chalkyw »
Wow, that's one detailed kit you got there Pete
Augustus
Post by Augustus »
There's a lot of work going on in there! Very nice Pete.
privatepete
chalkyw wrote:Wow, that's one detailed kit you got there Pete
Yes and the crazy thing is I'm adding to it :crazy:
privatepete
Augustus wrote:There's a lot of work going on in there! Very nice Pete.
Thank you it's getting there slowly,the next part going to be the worst :o
privatepete
Finish of the turret basket .
privatepete
Small up date
chalkyw
Post by chalkyw »
:jd: ....i'll say that again :jd: ......great to see this back on the go Pete
Madmattmodels89
Post by Madmattmodels89 »
chalkyw wrote::jd: ....i'll say that again :jd: ......great to see this back on the go Pete
I'd second that! Look at the weathering inside that turret! Amazing!
privatepete
I'm glad you like it not totally finished still a bit to do.
SergioSolo
Post by SergioSolo »
great start! Thanks a lot for sharing the detailed process :cheers2:
privatepete
Thank you kind sir,there's more to come.
Augustus
Post by Augustus »
Them kit shells turned out nice.
privatepete
Small U/D.
chalkyw
Post by chalkyw »
Very nice Pete.....that interior just amazes me :th:
privatepete
chalkyw wrote:Very nice Pete.....that interior just amazes me :th:
Hi nice of you to say so it's not finished yet but its coming along slowly.
privatepete
Hi I have finish it :banana: But there are a lot of pics missing so there a big gap in build sorry.
Pete :cheers2:
wavelet
Post by wavelet »
Great work mate :thumb1:
privatepete
wavelet wrote:Great work mate :thumb1:
Thank you,most kind.
Pete :thumb2:
chalkyw
Post by chalkyw »
Awesome job Sir :clap: :clap:
