Iwata neo or h&s ultra
DoubleDigit12
Post by DoubleDigit12 »
Hey guys looking to get a new airbrush to replace my Chinese one and was wondering which is best, iwata neo or H&s ultra :think:
James
Dropis258
Re: Iwata neo or h&s ultra
Post by Dropis258 »
Morning, I recently upgraded my airbrush to a neo ...had no problems with it. Thinking of investing in another one .
Not the best , but I'm learning something new everyday, I'm a sucker for detail may take me longer to do something but it will be done to high level of detail to my abilities :cheers2:
On the bench.... Not enough !
Revell 1/32 Spitfire
Meng Tiger
Ultra all day long IMO and I've owned both, the ultra is a quality german made brush the neo is sadly a chinese airbrush made for iwata (not by them)
Nev
Post by Nev »
Check out
Pauls YouTube reviews and see what you think :thumb2:
On the Bench...
AdamLuscombe
Post by AdamLuscombe »
Check this out
Dragon
1/35 Jagdpanzer IV L/48
Italeri
1/24 Ford Escort Mk. II
Primus1
Post by Primus1 »
I bought an ultra after doing ALOT of research, couldnt be happier with it. I got the 2in1 so it covers all my needs, following Mr Bretlands advice i upgraded to the pinch tip to make it easier to clean.
I use Vallejo paints and occasionally have issues with dry tipping, the pinch tip makes it a doddle to sort out and has really put the enjoyment into airbrushing for me.
What do you hear ? Nothing but the rain
ForbesHutton
Post by ForbesHutton »
The Neo is fine but there's no upgrades or changes available for it (other than the larger cup included).
The Ultra gives you choices in needle sizes, tip styles etc. You'll probably still use the Chinese one for the large, dirty jobs (primers, spraying Ultimate weathering etc) and use the Ultra (probably with a .2 needle) for the finer work. At some point the Chinese one will give up, start acting up, or just not be fancy enough for you any more, and if you get another H&S (Evo, etc) everything but the cup will switch over to the other brush.
The biggest difference between the Ultra and the Neo. The Neo will be taken apart just like the Chinese brush, using a spanner, a nozzle that will be lost if you drop it, and the risk of damaging the brush by over-tightening with the spanner. The H&S line has a bigger nozzle that can be found if dropped, doesn't use any tools for stripdowns, and you can't over-tighten the nozzle, it's fitted into place by compression from the nozzle cap.
The Neo isn't bad, it's just that the Ultra is better.
Augustus
Post by Augustus »
The Neo has rubber seals, I take it the Ultra hadn't?
sheppsea
Post by sheppsea »
Very helpful thread, which has changed my mind on which airbrush should be my first. I had decided on the Eclipse CS but the Ultra seems the better choice for a beginner, if only because of the price point :)
DoubleDigit12 wrote:Hey guys looking to get a new airbrush to replace my Chinese one and was wondering which is best, iwata neo or H&s ultra :think:
I've got H&S Evolution CRPlus and it's lovely got both .2 and .4 needles/nozzles. I've also got a Saprmax Max4 which I have to say is as well made as the H&S not in the same league but still very well made and it has adjustable flow as standard you don't get that with Evolution CRplus and for £40 it's amazing :th: I've also noticed there's a link on H&S web site to Sparmax products and the Max4 looks amazing like Hansa 381 chrome, which I think H&S make.
DoubleDigit12
Thanks for the advice kev, h&s it is!
James
