Vallejo wash
Vallejo wash
I'm pretty new to weathering. I know usualy you have to protect your paint work with a clear coat. But I was told I didn't have to with the vallejo ones because they are acrylic base. And So I went ! Applied the wash. Let it dry.when came time to remove the excess my paint work tear off... Did someone had the same problem with them ? Or was I misinformed and should have protected it with a clear kote
Madmattmodels89
Re: Vallejo wash
Post by Madmattmodels89 »
Was your base acrylic also? I think you can use the Vallejo on enamel base without blocking.
Re: Vallejo wash
Madmattmodels89 wrote:Was your base acrylic also? I think you can use the Vallejo on enamel base without blocking.
Yes it was
Tamiya
jmatt
Re: Vallejo wash
Post by jmatt »
I like Vallejo washes less and less. I have never gotten them to wick into a panel line. And as you've experienced, good luck getting excess off the kit.
cptgandy
Re: Vallejo wash
Post by cptgandy »
With Vallejo Acrilic washes are designed to be used in small areas at a time and with water as you have a limited amount of time before they dry.
Here is a guide on how to use them
Paul :tongue:
04Stefan07
Re: Vallejo wash
Post by 04Stefan07 »
Vallejo washes are terrible! When they dry they leave a pastel like matte effect.
I use Games Workshop washes when using a brush and they are the best by far.
Augustus
Re: Vallejo wash
Post by Augustus »
Yep I hate Vallejo washes. The capillary action is rubbish, yes on small areas at a time, and instead of complementing and/or slightly adjusting the base colour it totally changes it.
I bought 4 or 5 of them (should've bought one to test) used one on a Stug and it changed the colour and really, I mean really, darkened the model.
If I'd only bought one I'd have slung it, but cos I bought a few I'm hanging on waiting to see if I can find a use for them.
I mainly use oils now but keep hearing good things about GW.
04Stefan07
Re: Vallejo wash
Augustus wrote: Tue Mar 28, 2017 8:50 am Yep I hate Vallejo washes. The capillary action is rubbish, yes on small areas at a time, and instead of complementing and/or slightly adjusting the base colour it totally changes it.
I am starting to use oils for washes as well which are fantastic.
Grab a GW wash and give it a go, I highly recommend it!
Augustus
Re: Vallejo wash
Post by Augustus »
04Stefan07 wrote: Tue Mar 28, 2017 12:39 pm
I have bought a couple or 3, Seraphim Sepia, Reikland Flesh and Nuln oil.
Being acrylic washes do you use a clear coat for protection of the paint underneath?
04Stefan07
Re: Vallejo wash
Augustus wrote: Fri Apr 07, 2017 1:40 am
You can but once I finish my painting I slap on a wash then clear coat everything.
Return to “Weathering”
