Another Tamiya pz kpfw IV ausf d
SteveAFV
Post by SteveAFV »
With the Tamiya Humber into late painting stage I looked at the next kit. I want to get in on two GB/SIGs which I have kits for so that leaves the Tamiya pz IV ausf d. As spoke1701 is building his too I thought an ideal time as I can watch along with someone else's and learn a bit from them.
I'm going to take a different tack though and use a bunch of aftermarket bits and techniques that will give me the chance to upskill and not risk wrecking a more expensive kit. Will be my first time with PE and not sure what bits I'll use yet.
I'll be going with a late version for 1941 eastern front/Barbarossa.
Thinks I'd like to try are -
  • Adding photo etch - limited amount
    Adding additional stowage to portray a "moving toward the front" idea I had after watching various YouTube documentaries
    Researching and discovering inaccuracies, missed detail such as portraying weld seams, adding texture pre-painting, adding rivets etc. More to start comparing the prototype to the model and seeing what's there or not. I'm not going to get too worried about dimensions or feeling I need to add everything. It's only about learning.
    Either preshading or modulation to get me think in more accurate control of an airbrush
This is a tall order so I'm just going to take this as a test bed and do my best. A lot of these things I've read about online and thought that looks cool. Please do offer advice!
Photos to come!
I Heart Tamiya Stug III B
SteveAFV
Re: Another Tamiya pz kpfw IV ausf d
Post by SteveAFV »
SteveAFV
Re: Another Tamiya pz kfw IV ausf d
Post by SteveAFV »
As the figures in this kit aren't very nice I thought I'd use them as practice pieces for painting but look to replace them with something nicer molded. Spock1701 had me interested in putting the MG in the coaxial position with commander and crew. Additional figures might fit in well with the "approaching the front" motif. Can anyone recommend some decent styrene figures please?
spock1701
Post by spock1701 »
SteveAFV wrote:As the figures in this kit aren't very nice I thought I'd use them as practice pieces for painting but look to replace them with something nicer molded. Spock1701 had me interested in putting the MG in the coaxial position with commander and crew. Additional figures might fit in well with the "approaching the front" motif. Can anyone recommend some decent styrene figures please?
I think Dragon makes a good set of figures for Barbarossa.
InitialProduction1
Post by InitialProduction1 »
This looks to be a fun build to watch. Got to get the pop corn out :pop: :cheers2:
clay
SteveAFV
Post by SteveAFV »
Good call. Picked dragon 6375 up
SteveAFV
Post by SteveAFV »
InitialProduction1 wrote:This looks to be a fun build to watch. Got to get the pop corn out :pop: :cheers2:
It could all go easily wrong yet! :doh:
SteveAFV
Post by SteveAFV »
First bit of work on the sofa I feel
SteveAFV
Post by SteveAFV »
Quick update. Was mainly a fill and sand day.
I put the muffler together and got the back plate ready so I can work out what PE I'm going to use on it. I have the Aber set and there is quite a bit that can go on. I definitely want the smoke launcher bracket and chain. I'd like to use the muffler straps. Not sure on the extra plate and rivet detail as if I use it here I'll need to complete the entire model with the same level. I might prep it all and see if I manage to do it correctly.
chalkyw
Post by chalkyw »
:th: Nice start Steve :pop:
SteveAFV
Post by SteveAFV »
Puzzling over muffler end plates c35 in photo on the Tamiya kit that I can't see in any photos. In the HobbyBoss kit these aren't present (second photo)
Anyone have any advice on this?
Also if I am going to use PE straps do I shave off the moulded ones from the muffler or lay them over?
InitialProduction1
That's how Tamiya made the end of the muffler, I know simplified at it's best. that angled piece is supposed to be just a metal strap on both ends, I can get a photo of it. To give you a better picture. Just give me a minute.
clay
InitialProduction1
I can get better if you need it.
clay
SteveAFV
Post by SteveAFV »
InitialProduction1 wrote:That's how Tamiya made the end of the muffler, I know simplified at it's best. that angled piece is supposed to be just a metal strap on both ends, I can get a photo of it. To give you a better picture. Just give me a minute.
Thanks. I came to the same conclusion after a google on the subject. I'll see if I can handle the PE straps first then remove the extra plastic.
Thanks for the photo and advice.
mincemeat
Post by mincemeat »
Was this part of a larger picture or taken by a Panzer IV enthusiast? Other than tank nuts and modelers, who takes close-ups of mufflers?
Lookin' good Steve!
Current Builds
SteveAFV
Post by SteveAFV »
mincemeat wrote:Was this part of a larger picture or taken by a Panzer IV enthusiast? Other than tank nuts and modelers, who takes close-ups of mufflers?
Lookin' good Steve!
Maybe it was one of those quizzes where you have to guess the thing from a tiny extreme close up? :tongue:
SteveAFV
Post by SteveAFV »
Progress update: little actually work but plenty of thinking and research. I've attached the rear fender sections which didn't align that well. No big issue as there is a part (bracing?) that aligns right on the edge that will disguise that. Pity I didn't see it when I test fitted the pieces. I read plenty of build articles on this kit and that issue didn't come up. Filled in the ejector pin marks underneath. I will probably fill the gap in the middle of the sponsons underneath but I will need my helper to be around for that. Lol
As I'm replacing the molded straps on the muffler with PE I assembled it then trimmed the excess and filed it smooth. Has some Mr Surfacer 500 to fill it nicely. Unsure how I will portray the rough rusty nature of the muffler yet. Options are; Mr Surfacer which I've seen used (http://planetarmor.com/forums/showthread.php?t=7272 half way down) or pigments layered at the end. Any advice from you guys?
I've found some photos of 421 in the Soviet Union in June 1941 which is cool. I've bought some Dragon panzer crew figures and I may get some more to have panzer grenadiers traveling on or with the tank. Looking forward to the diorama building.
Feel I need to get going on this build but I'm having fun.
mincemeat
Post by mincemeat »
I found the exact same article! Pigments can do it, but I was also going to pick up some Mr. Surfacer 500 myself and try this method as well. I did some basic filling yesterday with EPM's and the holes in the lower hull, when I have some significant progress I'll start posting.
Current Builds
SteveAFV
Post by SteveAFV »
I'll post the other articles I found tomorrow. It's where I've taken a lot of inspiration for my build. I've gone over the top I feel but I'm learning so much and it's the best fun I've had in ages.
SteveAFV
Post by SteveAFV »
Rear sections of fenders on and filled.
In prep for the photo etch on the rear plate the muffler has been shaved down.
Here's a view of the PE instructions for the rear plate.
SteveAFV
Post by SteveAFV »
mincemeat wrote:I found the exact same article! Pigments can do it, but I was also going to pick up some Mr. Surfacer 500 myself and try this method as well. I did some basic filling yesterday with EPM's and the holes in the lower hull, when I have some significant progress I'll start posting.
Here are the articles I refered to.
http://plastic-battle.blogspot.co.uk/20 ... f-d-1.html
http://plastic-battle.blogspot.co.uk/20 ... amiya.html
http://cs.finescale.com/fsm/modeling_su ... spx?page=1
chalkyw
Post by chalkyw »
Nice job on the exhaust Steve.....watch out for the carpet monster swallowing all that PE though :th:
