wire cables/rope
wire cables/rope
At your local fishing shop if you buy a spool of leader fishing line. This a stainless spun wire usually coated in plastic which is available in different kg ratings depending on the size fish you expect or HOPE to catch.
Now if you heat this until it becomes red hot burning all the plastic off in the process ( almost no smell ..promise ), there is very little plastic on it.
It becomes very soft and it has the exact same look as a real tow rope or cable and behaves in a similiar manner when bending to fit where you want it with little spring.
Cheaper than buying 20 different tow ropes for various kits.
:banana:
Like this http://www.ebay.com/itm/Professional-10 ... 0932429967
trekfanj
Re: wire cables/rope
Post by trekfanj »
That's a great tip! :th:
Thanks, Digger!
Jarod
-Ralph Waldo Emerson
trekfanj wrote:That's a great tip! :th:
Thanks, Digger!
Just trying to work out how to make the eye let so I can do the whole thing. Needs a former to be able to do it I think.
:th:
