Testors Dullcote advise :....
maxsatnav
Post by maxsatnav »
Hi Guys and Gals
sorry if this has been asked before
Im just about to use testors dullcote for the first time over Mr Hobby aqueous paints.
my questions are
1 is it ok to shake/mix the bottle as there is a milky settlement or should i leave it like alcad aqua gloss
2 IS A 50/50 thinning ratio about right.
thanks in advance
Paul...
jelliott
Re: Testors Dullcote advise :....
Post by jelliott »
Sorry, I am unable to help you much with this one. It has been years since I used that stuff. Last time I used it, I believe that I brushed it on and it had to be cleaned up with lacquer thinner. I'm sure others may have used it through an airbrush and can comment on the thinning ratio.
I would think that you would need to shake or stir it up to distribute the milky settlement in the bottle. One thing I do remember when using this stuff was to make sure that the base coats were fully cured (letting sit for several days to make sure). I remember I applied this over an enamel paint and it wrinkled up like crazy. It may have been due to many factors.
Hasegawa F-4G 1/48
Academy U-2S 1/48 (temporarily on hold)
OliveDrab
Post by OliveDrab »
Yes, absolutely mix/shake the Dullcote very well before use.
As for thinning for airbrushing, I don't really measure the mixing ratio but my guess is about 70% Dullcote to 30% lacquer thinner. Of course it will always be a good idea to test first.
Curt :cheers2:
I am not putting down the Testor product; I heard good things about it.... but... what is "it" you are modelling ?
cuz if your next step is to Weather the model using Enamel products then... maybe an "Acrylic Dull coat" might be a better choice which would enable you to use the Enamels or oils with turpentine without... any possible ill effects over your Testor dull coat !
just saying...
Best of luck :cheers2:
Yes shake it to mix it, thin it approx 50/50 with lacquer thinner and spray at about 15psi, job done :thumb2:
maxsatnav
Post by maxsatnav »
ALL...
thanks very much for the heads up on shaking as i wasn't too sure..nice thin coats
@schwienhund227 it will be the final flat coat on a aircraft, all weathering done over a previous alclad 11 aqua gloss cote.
i have a test mule already glossed so will try that first
maxsatnav wrote:ALL...
No problem mate !
it may not apply to you... but some here might benefit ! :thumb2:
