Weathering mud using MUD...!!!
A great little how to vid from AlexModeling on how to use real mud to appear like mud! Check his youtube channel out :)
[youtube]88SKt3KmUuQ[/youtube]
UKscalemodeller
Re: Weathering mud using MUD...!!!
Post by UKscalemodeller »
I may think about doing this on my StuG, it's a great vid.
ComradeBrad
Post by ComradeBrad »
I have been looking for a cheap way to get some mud effect on my model. Why did I never think of using real mud? Do you think plain white elmer's glue would work for the white glue?
If the glue is one of the thicker types of white glue then you would need to thin it a little with water and an tiny bit of dish soap (dish soap thins the meniscus or surface tension of the glue/water making it flow better)
I use real dirt, sand, rocks, ground leaves... you name it.
Nothing makes better dirt than dirt.
ComradeBrad
Coen wrote:If the glue is one of the thicker types of white glue then you would need to thin it a little with water and an tiny bit of dish soap (dish soap thins the meniscus or surface tension of the glue/water making it flow better)
Lol well I'll have to give it a try. Thanks for the help.
ScaleModelling1105
Post by ScaleModelling1105 »
I use this technique on my tanks and it works really really well. My favourite thing is that it's virtually free and being able to add paints in to change the colour gives it a wide variety of uses. Definitely a great idea and would recommend it.
Will
Will Hall
ScaleModelling1105
Check out my channel:
What's on the bench:
ForbesHutton
Post by ForbesHutton »
So do you use the displaced worms as crew? The snails will be so upstaged!
Schoof
Post by Schoof »
Coen wrote: I use real dirt, sand, rocks, ground leaves... you name it.
Wont that make your model a bit ....uhm....dirty ?????
:mrgreen: :mrgreen: :mrgreen:
:th: Yeeeesssss!!!!! :th:
:banana: :banana: :banana:
Dirty tanks!!! :drool: :drool: :drool: :drool:
Return to “Weathering”
