Tamiya Polishing Compound
Marzoo
Post by Marzoo »
Just bought all three types of Tamiya Polishing Compound. Can someone advise on when to apply it? is it only applied after the painting is complete or do you apply it after primer coat?
Dave Marzola
kprice52001
Re: Tamiya Polishing Compound
Post by kprice52001 »
Hey Dave, I'm no pro and I can only offer up what works for me but, I only polish my primer when I am going to do a high gloss shine like a metallic finish or a Gloss Black that requires a smooth surface. I find that when I do the prep work for these types of coats it helps with orange peel. The smoother I can get the primer the smoother my color coats will look. If i don't want to see my reflection in the top coat then I don't bother to prep my prime job. I hope this helps.
Kevin
If it ain't rainin, you ain't trainin!
Marzoo
Post by Marzoo »
Thanks Kevin. I will try that on a NMF I have coming up.
Dave
Dave Marzola
kprice52001
Ya, The secrete is to get a smooth finish, Any orange peel or roughness that you have in you primer will be amplified with that type of finish. I even go so far as to buff it out with a polishing sanding stick. If you have the patience it will show in your final product.
Good Luck, I cant wait to see how it turns out
Kevin
Marzoo
Post by Marzoo »
Thanks again
Dave Marzola
