0.1mm drill
ElCapitan
0.1mm drill
Post by ElCapitan »
Hi All,
I've got a couple of AOA probes that need holes drilled - 0.1mm! Anybody know where I can get a drill/bit that small? I've seen a couple of drills online by Tamiya and Revell but can't find any bits that small to go with either of them.
Thanks in advance.
ElCapitan
Re: 0.1mm drill
http://g02.a.alicdn.com/kf/HTB185w9HVXX ... et-PCB.jpg
look for a store or distributor in your area !
RobBye
Re: 0.1mm drill
Post by RobBye »
I ordered a couple of sets of these (they're quite brittle, so spares are handy to have). May not be any use to you though, as the smallest is 0.3mm.
My Scale Modelling Blog: https://armourinscale.wordpress.com
Re: 0.1mm drill
RobBye wrote:I ordered a couple of sets of these (they're quite brittle, so spares are handy to have). May not be any use to you though, as the smallest is 0.3mm.
I use these, very handy to have the same size shank. You are right about these being some what fragile. They must be kept straight at all times or they will snap. Even placing drill back on your desk, be careful. I have broken about 4 of these so far, always when I have been careless. They are very sharp and will very easily drill a hole deep into a finger...it hurts like a BI%*CH !!
You can get these in 0.1 to 1mm sets....0.1 is super small though. This size maybe harder to source perhaps. I do have one set, but haven't used it as yet as the 0.3 to 1.2mm sets have been adequate. :th:
04Stefan07
Re: 0.1mm drill
Post by 04Stefan07 »
Smallest I have got is 0.3mm, I can't image how much smaller 0.1 is!
ElCapitan
Re: 0.1mm drill
Post by ElCapitan »
I got one eventually and it's almost invisible to the naked eye. So fragile looking but it'll not be out the case very often!
ElCapitan
Technophobe
Re: 0.1mm drill
Post by Technophobe »
I get mine from Banggood, cheap and quick deliveries.
http://www.banggood.com/10pcs-PCB-Drill ... 21651.html
...and pray that there's intelligent life somewhere up in Space cos there's bugger all, down here on Earth!
Re: 0.1mm drill
digger303 wrote: Tue Nov 01, 2016 11:16 pm
I have done that..drilled right into my finger. They really dive in after you get through the surface
Also dropped the little plastic case fully closed off the bench to the floor and broke EVERY SINGLE DRILL
Bought a bigger set of multiple diameter drills with spares...look on e bay
Return to “Tools”
