Pete's Hyakuren (IRON-BLOODED ORPHANS)
privatepete
Post by privatepete »
Hi this is my very first Sif-fi build ever I normally build 1/35 armour mud & rust so this is totally alien :lol: sorry, so if I'm going wrong please give me a shout .I'm building this little chap " Hyakuren" but with a lot of mods ie scratch building. Image
A Bit History
The STH-05 Hyakuren is a mobile suit featured in the Mobile Suit Gundam IRON-BLOODED ORPHANS television series.
Technology & Combat Characteristics
The Hyakuren is the main general purpose mobile suit used by Teiwaz and its subsidiaries such as Turbines. Teiwaz's engineer acquired the blueprints of a high output machine that was planned to be developed during the late stages of the Calamity War, and based on it, developed the Hyakuren.Unlike the mobile suits used by Gjallarhorn, the Hyakuren's Ahab Reactor is from ancient times, as such it cannot be said to be a machine that was produced completely by Teiwaz..This is also partly due to the fact that Gjallarhorn has a monopoly on Ahab Reactor technology in the present day.Nevertheless, it remains an important achievement as it is the first non-Gjallarhorn MS frame completed in recent years.Development of the Hyakuren's frame was difficult and took a long time, evidence of this is that the mass production line is not ready yet.
Currently, there are only 44 Hyakuren in operation, and the initial 9 machines are known as 'Single Number'. These 9 machines, of which the Hyakuren Amida Custom is one, differ from the later machines in that they have better materials internally as well as better performance.All the 44 machines operates primarily in the asteroid belt and debris zone, and are equipped with heavy armor.Although this causes the suit’s weight to increase, it also grants better resistant to collision. In MS battle, this characteristic allows it to have excellent performance in close combat.When the suit is deployed under gravity, the heavy armor would be switched out for ground combat equipment with lighter armor.
Hyakuren's weapons are designed to strike a balance between ranged and close combat, and as a versatile machine, the suit is unhindered by its operating environment as seen in its ability to operate in the harsh debris zone.During combat, the Hyakuren usually operates in pairs, but they are also often deployed in a three unit team together with a Hyakuri.In Teiwaz, information about suit is widely shared, this allowed a version up of the machine at the system level to be accomplished easily.The Hykauren is considered to be a symbol of Teiwaz in the Outer Sphere and serves as a deterrence.
Armaments
JEE-201 100mm Rifle Cannon
A lightweight rifle made by Euro Electronics, a subsidiary of Teiwaz that is engaged in heavy industries. The rifle has a sliding stock structure.
JEE-202 Single-Edged Blade
A close combat-use blade made for Hyakuren's use, it is stored in a sheath mounted on the rear skirt armor. The sheath can also be mounted on Hyakuri's backpack.
JEE-203 Knuckle Guard
Stored on the bottom of the side skirt armor, the pair of knuckle guards are hand held when in use. The close combat-use knuckle guards can deliver an electric shock when they come into contact with the enemy.
JEE-103 Four-barreled Rocket Launcher
An optional weapon, it is a relatively light weight rocket launcher. Depending on the objective, the rocket launcher can be loaded with different warheads such as explosive shell, smoke shell, napalm shell,
JEE-102 Revolving Grenade Launcher
An optional weapon, the grenade launcher fires explosive shells
privatepete
Re: Pete's Hyakuren (IRON-BLOODED ORPHANS)
The Kit
Instructions
Parts
Thank you for looking.
Pete :thumb2:
privatepete
Update 1
Body
Thanks for looking.
:thumb2:
Great start, and welcome to the SiG, Pete!
I suppose this means at some point I need to build some armor ;)
privatepete
Lysus wrote:Great start, and welcome to the SiG, Pete!
Hi Jason good to try something new, as for building some armor we could have a mini poll just the people doing this SIG let them choose one for you, how that sound :crazy: , it will get the old banter going.But I can choose one if you like :banana:
Pete :thumb2:
privatepete
Update 2
Head
Right Arm
Left Arm
The same assemble procedure as above.
L/R Arm assemble
Am not putting together yet, will modifier & paint first.
Left & Right Feet
Pete :thumb2:
privatepete
Update 3
Right Leg
Left Leg as above
Waist
Weapons
Thank You For Looking :cheers2:
Pete :thumb2:
privatepete
Update 4
Sub Assembled ,will be breaking down for scratch building and paint.
Now the fun begins :banana:
Thanks for looking.
Pete :thumb2:
Sweet! And some scratch building on the way? Sweeter.
How are you liking it so far?
Astaroth
Post by Astaroth »
Did someone say scratchbuilding? I'm in. :-)
privatepete
Lysus wrote:Sweet! And some scratch building on the way? Sweeter.
Hi Jason,home them, hope you enjoyed the beak apart from the " internet " :x .As for the build,good, different from the norm but it has improved my clean up finishing with armor you can get away with a lot more not Sif-fi/space every thing is a lot cleaner (where's the mud :lol: )
Pete :thumb2:
privatepete
Astaroth wrote:Did someone say scratchbuilding? I'm in. :-)
Hi yes I'm hopeful l'll build a outer armour suit but old school with rivets, nut's & bolt's and make him old & beaten looking, a bit of rust, probably not the norm with these little chap's.
Pete :thumb2:
Astaroth
Post by Astaroth »
Pete :thumb2:
I'm so looking forward to what you come up with. :-)
privatepete
Update 5
Started with his boots, add toe and ankle guards, made some 0.6 rivets for this boots, add shin guards.
Pete :thumb2:
:eeek:
Astaroth
Post by Astaroth »
Coming along really great, Pete. :-)
I need to get me one of those punch tools at some point.
privatepete
Astaroth wrote:Coming along really great, Pete. :-)
Just finish this, so I can now concentrate 100% on Hyakuren biuld.
Pete :thumb2:
privatepete
Update 6
Made a start on the shoulder armour.
Pete :thumb2:
Were those skulls included? They're sweet!
Really liking all the touches you're adding.
Astaroth
Post by Astaroth »
I really dig that look. :-)
privatepete
Lysus wrote:Were those skulls included? They're sweet!
Hi Jason thanks, the skulls are leftover from my warhammer day.
Pete :thumb2:
privatepete
Astaroth wrote:I really dig that look. :-)
Thanks, I do have a plan :scratch::
Pete :thumb2:
privatepete
Update 7
Finished the arms, added some more rivets,elbow spikes,guards and some mec looking plates then primed.
Pete :thumb2:
Astaroth
Post by Astaroth »
Damn you Pete, now I need to go and find me some spikes. :evil:
Looks great, man. :th:
privatepete
Astaroth wrote:Damn you Pete, now I need to go and find me some spikes. :evil:
Cheers,you can never have to meany spikes :twisted:
Pete :thumb2:
1975GinjaNinja
Post by 1975GinjaNinja »
Looks really impressive. But more importantly that us a fantastic paint drying stand thingy!
privatepete
Nigel1975 wrote:Looks really impressive. But more importantly that us a fantastic paint drying stand thingy!
Thanks Nigel, they are small wooden file handle with a small crocodile clip in the end x10 plus stand, just something I made up, its easier to hold than a small stick.
Pete :thumb2:
privatepete
Started making some of the body armour
A lot more to come.
Pete this is awesome. Looks like you're really getting into this stuff :)
Astaroth
Post by Astaroth »
That looks awesome, Pete.
Is the waist still movable this way?
BTW, I'm getting lots of inspiration from your build for my own. :cheers2:
privatepete
Lysus wrote:Pete this is awesome. Looks like you're really getting into this stuff :)
Thanks Jason, yes i am it make's a change from my norm :D
privatepete
Astaroth wrote:That looks awesome, Pete.
Hi thank you, yes the is still movable,side to side and 360.
privatepete
Sorry I'm pulling out of this build I have lost all my photos I don't know why ???
Astaroth
Post by Astaroth »
Oh no, you better stay. This is such a promising build.
Do you mean your old photos or the one you took just now?
Ack! Don't pull out just yet, Pete. Lots of time to go yet. Work on this awesome thing, take your pics and once it gets sorted we can watch it. The goal is to have fun so don't let that stop your build :)
privatepete
Just a few Pic.
Thank you for lookig.
Tiger213
Slovakia
Post by Tiger213 »
Impressive :th:
privatepete
Tiger213 wrote:Impressive :th:
Thanks :cheers2:
Astaroth
Post by Astaroth »
So, you're still in then? Great :-)
privatepete
Astaroth wrote:So, you're still in then? Great :-)
Yes but I'm certainly out off me depth plus someone is building the same thing :violin:
privatepete
Finished one side one or two rivets to go.
Thanks for looking.
All that detail! Looking great, not sure how you haven't lost your mind with the rivets yet ;)
privatepete
Lysus wrote:All that detail! Looking great, not sure how you haven't lost your mind with the rivets yet ;)
Hi Jason, yes I will be glad when I finish the riveting :crazy:
privatepete
Finish all the rivets and the build stage :banana:
privatepete
Now on to the paint stage :eeek: which I apologise in advance for Yes I use hairy sticks :oops: sorry to all the sci-fi purists out there.
Got the primer coat on.
Awesome. Nothing wrong with hairy sticks, not one thing. In many ways it easier to use them on so many tiny parts ;)
privatepete
Lysus wrote:Awesome. Nothing wrong with hairy sticks, not one thing. In many ways it easier to use them on so many tiny parts ;)
Thank you kind sir, it take's a lot longer to paint with a hairy stick than a A/B :x
Astaroth
Post by Astaroth »
There's one thing wrong with them ... calling them "hairy sticks". ;-)
But other than that, the figure looks badass in primer.
privatepete
Ok then,there my yard brooms :lol:
privatepete
A bit of paint by number's with my "Astaroth Mk2 yard brooms".
Stage 1
No they are not eyes.
Stage 2
Stage 3
