Amusing Hobby 1/35 Jadgpanther II
Darklen
Post by Darklen »
I received the new Amusing Hobby Jagdpanther II in 1/35 last week and spent the last few days building it. This is the first Panther II or variant in 1/35 in plastic since the Dragon 1994 release, which was plagued by accuracy problems. Remember, the Panther II was an actual mid-war project, not some late war fantasy as some believe. The sole (completed) lower hull is on display at the Ft. Knox museum with a Panther G turret installed. The project was canceled and many design elements used on the G. The turret for the Panther II was (as far as anyone knows) never designed or even a mock up built.
I'd like to thank the crew form Modellbau-König for processing my order and getting this kit to me so quickly. Two weeks from Germany to Western Canada! Thanks guys.
The kit details are an odd mix from exquisite to meh average. For example, the torch cuts and weld seams are very nicely done, while the steel wheels aren't really any better than the old Dragon kit. All the sprues in the kit are used with the upcoming Panther II with some additional sprues. The build is going quite well. As this is my first Amusing Hobby kit, I'm pleased with the engineering so far.
Here's some of the torch cuts & weld seams. Very nice.
An interesting shot of the bottom. What I found interesting was the two locator marks at the rear. These would be for the special tow hitch the Panther II was designed to mount. It's not in this kit but is in the upcoming Panther II.
The suspension fits normally with separate torsion bars and swing arms that key into the lower hull. These are somewhat workable if installed as per the instructions. the swing arms don't really line up straight when installed but I'm hoping the weight of the finished vehicle will level them out. Some swing arms had some pretty bad sink marks, requiring putty. Fortunately, most won't be seen once the wheels are mounted. i did compare the suspension to the drawing in the Jentz & Doyle Panzer Tracts 5-4 on the Panther II & Panther F and they are pretty much bang on, unlike Dragons suspension.
There some parts for the drive sprocket housing and tow points that get glued on. A little putty was needed to blend them in but not much.
The lower hull rear plate was easy to assemble. It features a working lower door (there's an upper door on the upper hull, workable as well). The stowage boxes have PE clamps on them with locator points on the boxes themselves.
There's a multi piece jack that looks very nice when built. It mounts to the hull with molded retainers. Check out the wing nut detail. The access ports on either side of the jack are separate as well.
There is some interior detail to the door. I installed it but didn't clean it up much as I glued the door closed.
The tools and tool racks are separate parts and go together well. There are no clamps for the tools nor even molded on representation of them, just some banding. The fire extinguisher is quite nicely done and there are PE parts for the sledge hammer and ax.
The track holders fit the tracks ok but are clunky and not long enough really. They should stick out another mm or 2 as the real holder had a pin & chain assembly to secure the tracks. The Dragon track holders are too short as well but are better molded for thickness than these.
The fender is one piece with 6 individual side skirt mounts.
The drivers side took rack and cleaning tool tube. The instructions show the tube with the 90° angle iron rain shield on it but it's not on the part or anywhere in the kit.
The rear door on the upper hull is similar to the lower, though the inside is marred by ejector pin marks. There is no interior detail other than the insides of the hatches, not even a rudimentary breech.
The tracks. Oh boy, the tracks. There are 4 sprues of track parts and 5 parts for every two links. The tracks can be made workable with care. Lots of care. And swearing. And lots of rum. The parts are, the main link (with the web detail inside of it), the connecting link (rounded on one side, flat on the other), the tiny end link and two different ice cleat parts. An assembly jig in is included but it's pretty small. To do a run, set up the main and connecting links. Be careful to orient the connecting links properly with the rounded side up (facing out). Once those are set up, add the tiny end links. Do I need to say sharp tweezers and a steady hand are needed for this? Once those are done, add a tiny drop of glue one the very end (top in the picture) and the large tab by the sprocket tooth hole and add the appropriate cleat part. There is an orientation to them so pay attention. The cleats should point like arrows to either side away from the main cleat. Note one side of the cleat has a narrowed part at the end, while the other does not. I should note, there is not a single ejector pin mark on any of the track link parts, not one. If you don't want to use these tracks, I test fitted both Fruil and Spade Ace and they both fit fine.
The only other PE are for the engine deck. Not as nice as most aftermarket brands but better than say Tamiya.
The details on the superstructure roof. The commander and gunners hatches can be posed open or closed. I'm leaving the commanders hatch open for a Dragon figure.
The round fan is quite a bit smaller than the normal Panther as are the driver an bow gunners hatches. Those hatches are actually so narrow, I couldn't get a figure in them from above. they'd have to be mounted from the inside. Like after the kit is done and painted? No thanks. The mantlet has a nice cast texture but is smooth on the sides due to molding limitations. I blended it in by using Testors liquid cement and stippled them with a short haired brush. the barrel is hollow all the way through but not rifled unfortunately.
Here's a dry fit of the upper & lower hulls and the rear plate. Fit's ok considering there's no glue yet. All the hatch handles are a bit small for the locator holes, so I'll mix up a small batch if liquid putty (Testors liquid cement & Tamiya Basic putty) and paint it in.
And that's as for as I got...in two days. Very good build so far. The wheels are a little tricky. I'll cover them in the next installment. I like to paint the insides for two part wheels before assembly and mounting. I hope to have this kitty done, painted & weathered by next weekend, time permitting.
On the bench: Dragon 1/35 Panther F x 2
My YouTube Channel
My Facebook Page
Darklen
Re: Amusing Hobby 1/35 Jadgpanther II
Post by Darklen »
So, its taken two days to remove and clean up all the track link parts and assemble enough for one run of 88 links. While they look quite nice, they are quite tedious to assemble and realistically, way too complicated. You have to be quite careful when gluing as well. Too much will make them not workable and possibly glue them to the jig (happened to me a few times) and not enough will make them fall apart when you pull them from the jig.
Oh, and I managed to keep all the wheels operable. this will help with painting. And the suspension does work, so it can be posed with an articulated suspension.
My YouTube Channel
My Facebook Page
CrazyHistorian
Post by CrazyHistorian »
Great start! :th:
Have you decided on the painting scheme? Just curious :D
:pop: :pop: :pop: :pop: :pop: :pop: :pop:
Darklen
Post by Darklen »
There's a fairly traditional tri-tonal scheme in the paint guide I like. I show it in mt in box review video here:
[youtube]m_WnjzVlG2Q[/youtube]
My YouTube Channel
My Facebook Page
CrazyHistorian
Yeah, I saw the review :)
That camo should look really nice on her. Anyway, good luck with the build. Will be watching closely. :th:
SergioSolo
Post by SergioSolo »
Wow, kudos for the super detailed thread! Excellent work so far :th:
Darklen
Post by Darklen »
Build is done and painting started. Built out of the box other than the exhaust pipes which I added from some hollow plastic Q-tip handles. Hope to have a review & reveal video up sometime this week.
My YouTube Channel
My Facebook Page
OneSmallStep1966
Post by OneSmallStep1966 »
This is coming together beautifully and your detailed WIP thread is great too. I'm looking forward to how it turns out :th:
Darklen
Post by Darklen »
Putting the exhausts where I did turned out to be pointless. Once the mesh side skirts are mounted and painted, you can barely see them. Even with a little bit of mudding under there, they're pretty much invisible. The next one I build, I'll just ditch the rear stowage boxes and put the exhausts there instead.
My YouTube Channel
My Facebook Page
Darklen
Post by Darklen »
Decals on. They didn't respond to Micro Set and responded very little to Micro Sol. They went down well with Tamiya Mark Kit Strong. I've got it matt coated and am trying out some Vallejo weathering mud. Goopy stuff to say the least but easy to work with once you get the hang of it.
My YouTube Channel
My Facebook Page
Darklen
Post by Darklen »
My completed build review.
[youtube]H26d_1Lwad4[/youtube]
My YouTube Channel
My Facebook Page
privatepete
Post by privatepete »
Hi first of sorry missed your build totally, I've only just found this kit on the market and was given the heads up that you were building one, watched your YouTube very interesting and I must what a great build and paint job you did,well done :clap:
